help ! rmx and trak...
help ! rmx and traktor - kills dont work
hi guys,
probably someone faced this case, but i didnt find the answer yet.
i used t3_dj_rmx.tks file from hercules site (rmx and traktor 3.4.1)
all kill buttons and eq-mid knobs dont work despite of traktor feels them correctly in midi learn mode in midi setup.
also stop buttons (under jogs) dont stop the playing.
please help to resolve this issue.
thank you in advance
hello salez,
with rmx and t3_dj_rmx.tks file in traktor 3.4.1
- for the eq and kill buttons: make sure you use the classic mixer in traktor 3
- for the stop buttons: as described in rmx-traktor3_config_pc.pdf file (zipped with the tks file), this map doesnt use the stop buttons for playback but for scratch (keep the stop button down to activate scratch on deck’s jog wheel).
hi maxdjack !
thank you - it works !
definitely this issue should be putted in faq
