help with mapping m...
help with mapping my mk4
does anybody know if there is a way i can set my pitch slider knobs to be the effect knobs?
everything i try doesnt work at all.
With Wich Software ?
Im sorry, Virtual DJ.  I would like to be able to get the knob on deck A to control effect slider 1 and the one on deck B to controll effect slider 2. is that even possible?
Yay! Found it! Thx anyway.
Key: PITCH
Action:
 deck 1 effect active ? action_deck 1 ? deck 1 effect slider 1 : deck 1 effect slider 2 : deck 2 effect active ? action_deck 1 ? deck 2 effect slider 1 : deck 2 effect slider 2 : pitch
agent17, can explain to me, because in my parent failed Console MK4 Hercules, I use the buttons pith sliders to manipulate the effects when active, but I could not, what you did well.
