31/05/2012 10:18 am
does anybody know if there is a way i can set my pitch slider knobs to be the effect knobs?
everything i try doesnt work at all.
31/05/2012 11:51 am
With Wich Software ?
31/05/2012 2:02 pm
Im sorry, Virtual DJ. I would like to be able to get the knob on deck A to control effect slider 1 and the one on deck B to controll effect slider 2. is that even possible?
01/06/2012 4:37 am
Yay! Found it! Thx anyway.
Key: PITCH
Action:
deck 1 effect active ? action_deck 1 ? deck 1 effect slider 1 : deck 1 effect slider 2 : deck 2 effect active ? action_deck 1 ? deck 2 effect slider 1 : deck 2 effect slider 2 : pitch
02/10/2013 4:44 pm
agent17, can explain to me, because in my parent failed Console MK4 Hercules, I use the buttons pith sliders to manipulate the effects when active, but I could not, what you did well.
