help with volume
help with volume
hey, so my virtual dj is installed, my dj console rmx is connected and everything is good.. but the problem is i cant hear anything at all.. i went out and got head phones and everything and it still isnt working...... what do i do so i can hear the music?
Have you connected speakers to Output 1-2 on the back of the Rmx ?
This is necessary since VDJ can only use the Rmx integrated audio interface.
As for headphone preview, The most important knob on the Rmx is the monitor Mix, right next to the headphone volume.
- When in the CUE position, you will hear the deck for which the CUE SELECT has been activated
- When in the MIX position, you will hear what comes out of Output 1-2, according to the crossfader position.
- If you want to hear a bit of both (when preparing a track), simply put down the middle position.
