(help)settings for ...
(help)settings for 4 decks at tractor scratch pro in hercules dj console rmx
hi all ,i need some help here , anyone knows how we put 4 decks at hercules dj console rmx any settings or documents pls ? thanks . . .
the best advise i can give you is to start from a basic 2 deck configuration (such as the midi profile provided on the hercules support site) and modify it to suite your needs:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=5
i would strongly suggest reading the user manual , which is very detailled regarding the midi configuration, and if you need more information, you can also consult the traktor bible web site :
http://traktorbible.com/en/traktorbible.aspx
nothing special , any mapping anyone have ?
i find some tsi files but they change all the bottons from factory settings , anyone have a tsi file only 4 decks to play change ? thanks
The best advise I can give you is to start from a basic 2 deck configuration (such as the MIDI profile provided on the Hercules support site) and modify it to suite your needs:
I would strongly suggest reading the user manual , which is very detailled regarding the MIDI configuration, and if you need more information, you can also consult the Traktor Bible web site :
Nothing special , any mapping anyone have ?
I find some Tsi files but they change all the bottons from factory settings , anyone have a Tsi File only 4 decks to play change ? Thanks
