hallo,
hope someone can help me to sort my problem on max os x tiger 10.7.2.
i´m new in using traktor 2.1.1 with the hercules dj rmx console driver update v. 2.87.
http://ts.hercules.com/ger/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
i downloaded and installed the tsi version from this page .
http://ts.hercules.com/ger/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=5
midi settings on the controller setup is 1 in and out, like it is at the traktor software.
in the input output route setting´s it say´s n/a dj c wich def. means controller not adjusted.
so traktor didn´t find the midi conection to the controller, but he find the driver to run the audio engine from the rmx console.
i tryed all on the same machine with the same cables under win 7, and it work´s well !
so iff somone could help me out to get the shiz run on os x tiger 10.7.2 would be awesome !
bless s*
The TSI files from the Hercules support site includes 2 files: 1 for MAC, 1 for PC.
You've probably used the PC version, which is why the ins and outs are not appearing correctly ( as they are enumerated differently on the 2 OS).
Reload the MAC file and you should be alright.
If you want to be sure the console is installed correctly:
http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
Hi, i have exactly the same problem...... and it´s not because of the tsi file, i´m using the right one for MAC.......
Have you got your problem fixed??? If yes, how did you fixed it??
thnkx
If you click on In-Port or Out-port menu, a list should appears with all the MIDI ports available.
Does the Rmx appear in this list ?
What happen if you select it ?
