hercules 4-mx start...
hercules 4-mx start up issue
hi
i do have a problem with my 4-mx controller. i used to have no problems with my old laptop but when it had a crash and i try to connect the controller to a new pc my problems starts. i am using 64bit vista and when the controller is connected the mic on/off button lights up and after 2 sec it fades down. the pc can not  recognise it. and im stack... any ideas??? pls note that i also tried with a self powered usb hub but nothing changed...
thanks a lot
Please fill your profile in clicking on "MY SPACE"> "MY PROFILE": you have 3 fields to list your equipment:
- In "HERCULES EQUIPMENT IN USE", please check DJ Console 4-Mx,
- In "SOFTWARE IN USE", check your DJ software,
- In "HERCULES EQUIPMENT IN USE": describe your computer brand and model, CPU, quantity of RAM, version of Windows or Mac OS, version of DJConsole Series driver package, version of DJ software, and precise if you have a USB 3..0 port on your computer.
