20/08/2021 10:48 pm
macbook pro 2001
all 3 software configs have been working fine till now
serato dj lite 1.5.6 working fine
jduiced 5.2.1 working fine
srato dj pro 2.5.6 stopped working this week
ive searched and found the following, my answers underlined:
2) if you are on macos, please
- check if you have the same issue when you connect djcontrol inpulse 500 on the same usb port as the one you used before,
same on both usb ports,
- try to disconnect djcontrol inpulse 500, run applications > utilities > audio midi setup, display midi studio and delete the djcontrol inpulse 500 midi instances you see.
cant delete anything here, i can just see the controller if and when connected
3) in serato dj pro, please confirm if,
a) after running serato dj pro with no midi controller detected, when you connect djcontrol inpulse 500, you see the bottom line: "hercules djcontrol inpulse 500 hardware connecting. this can take up to one minute.", and afterwards, this message disappears.
yes, i am getting this message, the lightshow runs on the controller, then nothing.
b) when you click on settings > midi, does serato dj pro list, in the midi device list "djcontrol inpulse 500".
yes, its there after i reconnect it
what am i missing, something simple?
no blocked sofrtware or hardware in about my mac either...
