hercules air plus d...
hercules air plus djuced 40
hi
ive bought a hercules air plus, with the djuced 40 software cd included. ive tried to install the programm, through the cd, but when
i try to start the software, a windows prompt shows up and says "djuced doensnt work anymore". im using windows 10.
what would be the problem?
thanks in advance
 I would recommend using the latest version of DJUCED( v3.1.2,  available from the link below) instead of the CD version which might be old:
http://www.djuced.com/en/filter/downloads
thanks for the fast respone. but even then, de software gets the same error message.
Try the following:
-  Uninstall DJUCED completly;
- Delete the DJUCED folder under Documents;
- Reinstall using the new installer file you've downloaded by doing a right-click and selecting "Install as Administrator".
Let's see if this helps.
again, the same issue reappears Phatso
1) If you meet a technical problem, please fill your profile in clicking on "My Space"> "My Profile" http://www.herculesdjmixroom.com/en-us/account/informations/ .
- In "Hercules equipment in use", please check your Dj controller, (Here: DJControl Air Plus)
- In "Describe your equipment": describe your computer brand and model, CPU, quantity of RAM, version of Windows or 10, version of DJConsole Series driver package (is it 2016_HDJS_1?), version of DJ software.
2) Are there, in your folder C:\Users\yourname\Documents\DJUCED 40, one or several files
crash_data1.zip, crash_data2.zip, ...... crash_dataXX.zip?
If you have such crash files, please
- Accept my invitation on http://www.herculesdjmixroom.com/en-us/account/friends/
- Post the last 2 crash files on https://www.wetransfer.com/
- Send me a message
via the send a message menu on http://www.herculesdjmixroom.com/en-us/account/friends/ and the internet address of these crash files on the message to analyze your crash.
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-fareast-language:EN-US;}
