hercules control ai...
hercules control air to amplifier or mixer!
good afternoon,
i am thinking of purchasing a air control but i have a question, i want to know if i can connect the control air
to an amplifier or a mixer in a small bar where i have a monthly residency, and where i do some partying.
greetings and thanks.
Hi
The Dj Control Air only has 1 Mini jack output so for connecting it to a amp/mixer you might need a adapter to RCA or depending on the connections needed for the amp/mixer in question
Greetz
TheCause
Hi
Greetz
TheCause
Thanks for your answer.
Let´s see, I may not have been very explicit.
Imagine that the amplifier or the mixer has RCA inputs, I need a cable like the picture? Right?
My doubt is if the Air Control can handle a gig of 5 hours, and that the sound quality is good.
I hope you noticed my doubt. Sorry for inconvenience.
Thank you very much.
That cable is exactly what you need.
The Dj Control Air is more a controller for beginning Djs as it only has a Mini jack output to conenct regular multimedia speakers.
If you looking for something to use in a club you can consider the Mk4 or RMX.
TheCause
Ok, thanks,
i understand, but i have a limited budget, the place is just a small bar, i play there only once per month just for fun, it`s for people to have a drink and listen some music, and not play too loud, i think this equipment will do perfectly.
Thanks anyway.
You could also check out the Dj Control Instinct, it is a smaller controller but does have RCA outputs.
TheCause
