hercules dj air+
hercules dj air+
hi! i just bought the dj console control air + s series (with cd purchase)
but my pc have cd players out of commission. i had previously purchased the
console dj control instinct s (always with the cd included in the package)
but i always had the cd player out of commission. i go on a forum and tell
me to go on your site and download djuced 18. i go on your site and
everything works. the problem is when i have the dj control air + s series
because my pc still has the cd player out of commission. when i start
djuced 40 i reads the console. i have windows 8.1 but i can not read my
console from your pc. what do you suggest?
As indicated from the DJUCED download page, the DJControls AIR+ requiers DJUCED 40 while the DJControl Instinct works with DJUCED 18.
https://download.djuced.com/
Simply download and install the appropriate version for you new controller and you should be fine.
Hello Squart-01,
Djuced 40 is more powerful than Djuced 18.
If you prefer Djuced 18 user interface, you can display Djuced 40 in 2-deck display, which makes it look like Djuced 18.
Djuced 40 lets you choose the type of graphics display you want: you have 2 icons on the middle of Djuced 40 top bar:
- click on the icon made of 4 squares, to display Djuced 40 in 4 decks (2 decks for tracks, 2 decks for samplers)
-click on the icon made of 2 rectangles to display Djuced 40 in 2-deck mode (each deck = track + sampler deck)
