hercules dj air wit...
hercules dj air with traktor pro 2
hi i have a hercules dj control air, how can i get the traktor pro 2 full version.? please help
Is there a difference between the traktor pro 2 for Mac and traktor pro 2 for pc? Im using a mac.
Traktor can be bought online from Native Instuments web store, or through an authorized reseller:
http://www.native-instruments.com/#/en/products/?page=2850&sku=TRAKTORPRO2&category=1316
http://www.native-instruments.com/en/company/resellers/
Obvisously, if you own a MAC computer, you'll want to buy the MAC version.
Is it compatible with traktor pro version 2.0.1?
It is, but the configuration files provided on the support site require v2.12 (the most recent version being v2.6).
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=287&cid=10
I dont have a license to upgrade to 2.12. Can i download it? Thanks!
If you did buy Traktor, then you can obtain the updates freely from Native Instruments website.
please help me, do you have a video tutorial or can you dictate to me one by one about mapping on traktor, im stock almost 2 days. i cant map the loop area. and the jogwheel area. but the rest is good. please help. thank you very much!
