hercules dj console...
hercules dj console rmx 2 - project
good evening to all,
im a dj console rmx user, and like many other love it!
unfortunately the controller, has its limitations so ive started to draw some projects of a possible version for a rmx2.
i hope you all can give me your honest opinion about the project since its a personal view and need to get a more mature idea.
**the color used is only a personal taste. off course in case of a going project it will be different i suppose!
description :
- loop area - loop control similar to default vdj6
- effect area - 6 effect with p1 and p2 controler.
- sample area - selectable sample from library with on/off and volume control.
- mic area - selectable mic effect with on/off and volume control.
- jog wheels - sensitive big illuminated jog wheel similar to vdj6 default skin (not motorized) - lights on the side of the wheel.
- deck a / deck b  screen - info similar to default vdj6 skin: theme, time, time left, bpm and track graphic.
- levels - illuminated levels next to deck a/b volume control.
- mouse - mouse similar to regular notebook computer for navigation.
- leds - leds on every button and volume control.
- power - external power source.
- usb - usb connection similar to rmx1.
- master volume - master volume control on top of controller.
- sound card - on board sound card similar to deejay trim 4&6 - front volume controls to input
- input - 4 external inputs (2rca +2phono/line)
- output - 4 outpus (2rca + 2 1/4 jack)
- seach buttons - can be used to loop in / loop out
thanks in advance.
adding a new project based on the new 4-mx
Adding a new project based on the new 4-MX
