hercules dj console...
hercules dj console rmx crossfader hardware problem
my brother broke the crossfader of my rmx,now its working but not always,i clean the contacts but nothing..
where can i buy replacement parts?
please help me
i need my rmx to play music on oktober
how old is your unit? is it still under warranty?
otherwise i would suggest seeing if you can send it in to kaysound to be repaired. call them and see what you can do.
they are slow but you have time.
i buy it before 10-11 months but i have open it so i havent warranty :/
where can i find parts?
i need only crossfader :/
contact technical support, they might be abe to help, but the rmx was not conceived with the possibility of easily replacing the crossfader.
i know how to change the crossfader,i just need the replacement part only :/
How old is your unit? Is it still under warranty?
Otherwise I would suggest seeing if you can send it in to Kaysound to be repaired. Call them and see what you can do.
They are slow but you have time.
Contact Technical support, they might be abe to help, but the Rmx was not conceived with the possibility of easily replacing the crossfader.
