good day! i have a problem! nothing i can not find and do not know what to do. just recently bought this hercules air control. this worked fine. but then, it is not clear why stopped working faders. program simply does not respond to them. device apparently works. program on the computer responds perfectly to the buttons on the device. anything except any faders! looked all settings completely reinstalled all software, rebooted ... nothing... it is waiting for some sort of help! thanks in advance!
First off, can you verify in the DJ control panel, Advanced tab that the MIDI channel is set to 1 (Default) ?
<img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAroAAAGNCAYAAAD+atKRAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAP+lSURBVHhe7P3517VbVZ6L7r9rtxM1lqDm/Hza2RYsFnUNigqIioI1CAtQVBBBlAUILksWqMASRaS0iqTUxBhNosZoYqLJ3vs9o/d+X73fY8z5ft+H4G4ne6+3tdnmO+d8ivFUY1zjHnfv43/5nM/5nJuvetz9N4+770nr9cSbr/jK+26+8qvi8xPz9ZVfff/N//YVj1vfP76Xi+Xjcy7z+LXeesV3X/24J+Qr1qltPrG/4/f71rKxDL+zfnw3+6j1YjtsM97vu7/KyLYoI9uL5eu7Wo799776N/2usng5fVt9XqzM8bsv7/vw32JdL6d/jnJybPG9f65tTPn3Y3hSr8cynKdrx8Cx+LXhWnFOuFb5WcfJOT+vH2Vl3S77ul++Kq/5uv736fzofb8O9XuVa13fr3p8fr5vHW98jlcvr/Vju7nOen1V7MfOf6yfZYx7Iu+VJ948/vFPvnn8/U++ifvscY+P+zPuJb3yfq3l4/d4Zbn1etxa7r61LvdYbfMJub34La9NbDeeiyi7fY5t8uL3WIbj6nLrHqx7eZUh3lWOWD/3tb7nXoptRZmmXCoD92682745Lo79/ic8JY+Tc9L/r/3md3qm4j328fgnzItrEduI88qxP+EJT72J7+LzE574tLXO+n29el/xObZ1/9p3HKPOdWzvCU986s0T1zr3r/f71++xzvaK77U+ZY1lc/vrPda/f+0/3nnltvR97lflzeWetPalcxDLPOnJT795Ynyn/fS79sny8Z7/a7uxrdz/+u6JT3q6ff+U/pzrxD51fmK/Vd71vr574tp3lC/W5/v8f60X5zJ+Y7/xf92nT871c595HLVMHEMeh85LnqO1Tu6LctsxPinXV1m29Z+a1yjOWZaJ7XBOdc7iN78GlJ/7qq6NzpddQ65N/Mbvvq28Vus+iPe8z+NeifOga1z3aD3T3Bf+P/dI3Le9vu63fJbUPnGf8+xTD3hdkOXQvroOyWfyKf2s5z1tz2j+r31k/ak2sesC/cb1ZH9VV6ouUp3D85Z1l7Vf1OPUN12vq53tuoL1Luo+7Ut12Fd+ddS7VQd2XU9dqTqy6t0o353q3fWb6si4L/P8H21vbt/aBOqDrndXnZ5te5672h71fFwzZ4VihPs2tqBdpY2L35Nh1MZ6O+vtM23bV2QdXfyTbWm2McMvtAWxnPMN7e7Zdve6V9iCffLufMP1hrlgGfYT+6fNj9+2aydO8/skjoOy5bpWBztTnW19tuk6BydreZt08gYcEeuyXHKizhvtnZeRc8WxOqedZYTr+N6v2TVOOZ+Z/yVAN3ekC+Ogy0ku0N1vsP3kFehysw3ozoPU0HcH0PUT7AXl4Pxk+Uln2TuB7lzQqkT64TJwooxcbLbncH7tAvjDeJ70s3LqSuroGPgDeSdYZzmvCP2h4Lz49rYHV50SbioedL9xzpvfy+ydmAZfYPEAVSq4gtEC2blRC3Tju6j8ch/xAKuiZF1ANx86VapTUcQDXNcS0M2GLyrdrbLXfqnc9R7LsW5X2Aa6PLQFnwa6a9t5frUdYNvfs7IWmHPc3hCeoMv18ka0Kz81/nUOCnRjOW+0AVsH3fg9YNLh9jbQBRQGdGu92BeA4aAbIBJlALaA3dy+gW6UeToeBcYNYgG6wC7/A1sGqw66DclXQJf9Ul5A12EsQHcDWGDQQLeBk30IXhOsBboJpPodWG1I9uUB3QB8gS7LJfRGedZvG+gKNvP66/wD0XnO1zoF7AW/gDQA2CBuoOtwv4PyAljBNOcFoC0wVucAiLVOBtclz9dtoEv5ev2A9uocFVQLLuncqGOUcK9OFKDrEErnK+63/J/1DZbp4NTzUvcy/xdYTac3nh86Z+yHOiQhVZ3a6XRWneWgm8+klts6n+pUDthWB3v2X/XLVdBVGa+1n5uYAmyzHdV/uY+sd+nwS2AALtf3We/a8nEuKF//f0VgyE58g250aHfQpZOPmMF7LMe6DbUGut0uUD9LNIvzM2Cqel/t6IDu41Mwu2fQFRR3m2KguwHb2uad2lYHsGqPR6w421MHXYdfrj/tqi83oFus1R03takn0HOe4vteVx2hk2GcpWAfP5763TpFVzphDbrWRrPvek6Gu3zbfqwnx3g5nYlOlnMg93W4J+LeHtBtRXfdJKLyWCl2Duh6QQJ8aVTj/VQoz5PTDypQo15U9V733tS1Hk+fLANlLhAgdhvoerm9ZwDAsr+roEslqQrDKxd/EAZA54bwC0IZ/f0ESD7TwDnMAqYn6J4PhZfJt9+9JQPd+J0OjPeqvBznDU8F0tuWkksP/YTbBlcptn0jLvD1Co1KkZ59g64UAXr72zXPDpqBrsDTIZffc79SK1zF6eOTOgLU+gOPmpr7VmWBIoP6kttWowSQUom7uoPik2pFlFfKbgCsb98rH8CW+5SGmMYZ1ZrP3mih2l5VdE0FK1go1czBNo59+7yeVcAK0EWhQ51zAErV2tQEVNELRTdAF8VWoJfgdqiMqI6t4pryOIBb8OSgGzAXIBfKJqppK8JSXFsNlbqJqtiq7Am6KLhSfxN4D8jNfQgOC3SluErJBJKj8c/fdA64DzcAXtuJzwG5vIBMjj2VYynGm5rcKnSpw3EegN8L0LXzfqrgm7IulZcyBJj2OVUHq68zIJzqtCnRt4BuKv9SplFRa8SBaytlNTpWuta7Glv37ajEBrkNvZeg66rxBrrULVKYWyyRuuvPaI+2tWJbZfR6gI5ydvQF3dQfm6KreqXqxxkl9bbK63bqp7if8n+puD6qlYpujFQJJLNtNfDvOhPI1mhZAUUpvP2/Rtz8GR9gk7hxTdFVe5B1ZIJ2nJ8C52kXpPLacbvQcq1NDXYBdL2tHv6oEWGuH8s2Q9wCuj7Kzfq0Eed1OXljOEBiibHEtdHb8xizze1RdgfdnTWcYxr283zcN6Pv3fEZ0cnbVG/f4T//vdvvTbQq9RgWYXkv951GKfx8ntv363aO1E/n8JK5fDs76KoBzxPkoLv+P0E3dp6gG8OdAsENEpvqr/VqbDjCeqF5Uk0yv0bpKEx+g/vF3UF3ehDbjWdgfQ4RO9R5zxG1mwsJbDpU3hF0BecnNPbDpWGWewFdHl6A3W+u82H2/c25mZ5w9pCl1J+9KX94/Xxz89Z3Gmqy4f9+KGQ3SLVWam738OmF9rDG9PBZvi0NqkipWAHW3H8P4aC21nDcbYpuWxms0XLQzcr/UHSxM3hl1WU5FF1/mBNc46XGAqgFdPPek2LXYKyeM/d07zMb87AKVMNMg95WB8F+q7VSZ2I7DroMX6FKpYorCHX7QMBSrVevavxL4UVBS7hd3wWMOHzGd8ANQ8f+3MZvDTqyA2AP2LdTUIOqCPS2MmmAWwrpDN3P/6XAcr5SyZSi24qsrYeSi+WgQfdQdF3NLVuBrARSZ9tWIcBlmSc9+Rl9zlDAozyxfoNuD9mv6637K20FgsMC3Wf0y+0RWX4HXVRn+y7LEvs0ZdtBl/14R8KhGKuEq78OusAu14BrWudsXaeE+d1ygarPs8e17g4UKm08B1JvgdjuCOg65rWWfen+J5bVo4fV1Va1uiuIrM/1rNwGutQdqL6txKndLBuSlNmjXStbkAQddW4B3YRMqV13Bd0YzTkEl24PFtACuXXfzCjUNPql6pbtqo53q0dN4XZFt9aXRYx6twWrKlPVDdcV3RZswqamOqQtXRr1qhGqAV3g+6LNEFD5efD6MofsDVavQZSzSvAOw+uAq8NeXFcXk2JfLgqx7jUOcT5gn+d3A2tluaSt9faX8tDm9z3T994lQEe5UFSD37hG10B1O386vyx3ZwFvLKYcnwtxG6AfZU3eMzi+xnte1r6HxA7duVMbeu24WGZAN3sL8uiuE4RXFvg8rQt5AqXoMhx0Xhhu1AYfFdAv5vQCLxXdrkhMJmdfDl4s5wCWJ0VA6zdplWUA+E6gu0P33ID7TTfQyAVGJfYT79/5BeWhOXtRVUZ8Wu5TGosIF/5uoOtw7jcLN+Y10HWYPm+23h9+qgN4248lJXYqgAFjIPkrvuq+8ugylBWVvlkX4rxFhVsNgFkfqOwBXX2OxgjYAwpH0S1/bnt0BXF5T8TwXfTyVflzjfAAZwOsin7Oe0FsNygGvQWu8pcDulKDS/kV5F4F3fodhbcqtfIoxrpR8TvotnorVQawpdFr0BXUZoWn7aUv8gro0tjXcvLeap24Pq06rvXTCnCoqgwZoyIDvHEssWz6RQ/PJx5YV4MLvsez25B87A/QdVgHWi5A1xRdlGlgEaAsWBTAS+3lO6DW/cF8x7lw/zDnJpYJQOUYash+nT8pqwAaqnZ2bHRP9Tq6XrEdYBWIzs6Jyhq/Y7NAUXZfMGow3/m54ly6R7n9wGaFaNAVWFLuXBbftiwNWX6pveWvPkDXRhF4fvs8YEngPjVrC2ptdNjSK859rfftOzp1qQpfWgWyAyf7TJ4Pdeyivoj/d9ANtXT37F+Ariln1WEc0I1n8xJ0DyuF2r0GFD37VTe5Bcz8pFJwu/1rNbfU4FJ11yhexkZUPAP1u48Cdb2rjnW3AV7vmoDRoCvQ30bjss1ltGsHXSCbOg7Q9XaBtoLYjlE7L/27HBvLXGsbadtgCEB32sOxPVBugNE/9/rEalgH5FR0vRx3Bt3djkE7BIDDBbGN6hReerkbHgX7ca1P0HVBzNt3ynlVtLwi1jncc15djabTAaA7szjDnefLf+N8fXZAV56SBK+QutUb4Mb5/27BaAUFcYN0TzWA5NrwwhWKRx3Ng1MP+zbrwnlB8sLqhG9Enw//biD3m8IVau+9sC3/jpPsF2y74aS+ntDIxcJAvwGi3STb/tU7dNCt4zLQ3Y730idzPrjcGID3baBL+dy4f61HeZbXKx4qXIazNj+tga57uXydDkZbD+1YF6REqPdPgBsVXSsLUpE9qMQbI/8e/y7WhVF45KnT/dMViMB3runeMBZ427CnGp9WLk/QzXNRnS9AtyspPSNtXVCjMKA73sHyy1VjEYDjHt1QjxP0UY+kKnmQGVALEKTqpiCSDRLb86ggM4aoBVon6G6BXYKhUZdLmWVoNIfCLZjLt4V6u6mz2t6FomtqKUP0HAOKNFYEoBJ/bQAeIEvgGKCIYty/u3Ks4ff6bV58TluEfT/BV6X4ctwBmgRgDeiOVxVAA0Yc8ON6PekpS9GN19oOv3mAFwF3foyp4AqGy+O7YFkWhw10db4dlPN8aV+c0wZhPLht3yBITt7f3J6CCPU/5/i8bt4xcssK3+d931aWOl88C/h+HXZr1MEC2aT0XgPd9EI76OqeBXTPZ8c98TTk7tH1erN9vRJf4tmnfu46R3WD26poYxgpOu1RgGK3hWorAF3asg6kPYLRUHSzDGl1mDot2wfrpF/UuxIf3KrWFi+Ch7uzL9UXG1OqpAowlvWNc4d1oQSQGg2ssmh5a+fje4ckuMSVQoc22jz/jhFs2lE+n1aB+D7bVjopKfAUB7E9zrd/dnZg/97Oco1PBqEdZ506zuEfRj8cBDkfDqyAbvx2Cm6UzVmFc+ccxHGfUOzHyzHfGXR3n66vQ1n8PDjbnOfDP7t/+LzGPJvp0XVopPfiPZxUdDs6UaC7Ps+QDL4XKbMML9wBdHOf6qVTUI+A9IvgN8MZiXn2KnxZfgN0/TjrRF1aK65dvOwA6Ji4iU51mfPlw9d90XUeNvgFaBTleMr4Z2+N89WVF+BkUv48SFVev1kboI+emQ9xXDuXZ5mpXPt7Ka34qrpCwrulSq0DsyiXQBVFF8XW/bBkY6htElRRQEc5ACgg1n2rDbs29IaXzlVG7zx5hYuajGrr15ZGh+8yq4I1Vpuiy2iGPQ9z75FJRB5dA2KH6SrvBFEm6EaWiATa9X0HqVmGBbMfYFNgWPccpr0OuvJEAr4NuhNB3zYELAsCH/dTkgUhjgdFdxvS7uwGh1UhtmWwkutiPZCX1YfuPeMBSvQAUPlfU800D2uXQzA/ECaQZchdkBsQmgBpsMvn7XstA5i1KrqO6cmh7Op8+fc9ZB92C3ksT8CPz08W6FJWABv/7AXoct4EiSfoYk/BL9zWDY4z1ejJFOFqb3cubNm2kkSQm85rK+Chlisw7RwJcEjFIkGHCagdD7NlSAg7BioxoxSoyVKEWzHXvZzPTQz3SzWPd5RcyoGlgREK6hYfCWEUKUFYVgBGU2iM6dQwyhjv1A9pv5JnuJ93szJ4+TwrDZ1tD9B1WEjPa8CYtQOMXGFLSEVX9erUL5aNYQPda/XuZFTIcmLdEAS38iyPbnUWyGpT8IsIkipylFdBvB3AJkV4QHfqScDO22z3554CkoMV69D++W++Hue0LQoBurJ2nqB7DRxv+87bahfNKJe3uxynC2AuqDkcnpAfZXVFl2V9nw7mDrp+HrqzdfDGCfk+Ep7rk4VBnbxrsExnxbd1AuudQXfYwNdz3ttAlxPqvZT4fwfd6o3Ghcej2w+YIIoTdLWXgoIF6Fo03qmicnADr3idxlDOb75PKP68SX17gC7rX+uVXTvx7Icefp4zDRPE//SagGOU6/NmbhVbCvE10HUYd9Dt4zBoPcvqvdY5N5eRj6QhocfqcOwPBTdNq7P0tLNnqwpKcNuBY6QI0+9UvO7tpYK8AF1LO7YrCwO97dFVhXxaFwDdBFbSgwkkiZY+zysqRwbXqZKlAr8NdAksc9DNB+5sKLJzM2p9XsejAuiGzWwWNMCl6FaEdA6nZjq0eia49+L/gtp6ZRYFeQ8TGlC1+E72BE+JhQ8SJdT9mrEtTxU1flt5c1tx29N85Xldx09wk6fA2sDJFVx5UwGPDFBy0FUwWMOWwW/CWyyfHt2yCQC6G8wKshlO798MZjl+FFpfvxXV9Okq7ViUA0AWrBMARkDcAKyyQASACQzTbnGAbqUHK7gL0A1YbtDFb6tORgO3wbinVUvYX9tA8SU1XNsyQoE1cM2y2z78t742puji820F1rbnNoZWoeXVnvtugiJRWalvKSOp63L/Al1PcRfLu2K8jWJkp3GGfXmuCcaMZyitC/LuArpAt3/eQJdtHsJGpyQzRbcbZI1sdt0RbYjAtwNW1YG+Drp7WsZu3NU2UPd5e0CdxzMZZWnQFfhfq7+A4r3eNbX2BN2G7AHiFgZkSfORvLMdQdFtjsC+Zqkrz+M6BSkHN2/bOP/u6XVgBr7w6MbIJ+2xjxB72jHnnbPtdMBz+L1mP7gGwS1Uya5wV9AVYMZxBL9l+3BkPrgG2JsiKzaZdurSC3xykwuinFtf/1x+IH7Sxp6wynXx88Z9Dgud6u/Oksq6cBL9VdDt9BoyZ68TWWrS7iGl4D6ksF+4fXnv/V5LLzaQq/QrBsoOrhwoy9cDVWUF4uZm4YLtAWt+M6LcngB5DXS5uNxMlOtUdPcHYdTvC7VYQHQBurrJKRPn/nyIuDH8wa7rMcfL+WLfF6CrKM+5kSwQQkC7WRcEht3zjgfNhrBGWdiD2FwJyQhkVZZU6m476OOUCnGCbiic1xTdTwd0W9EVwDd4ZgNwaWHAfuMZFPq6GOh6Z227p/UM5b2RED4qrVsxaFw55gDT6iSUgkvQXCmpVU5XwwjeOVUzfLhnQJnnN70KuoKoDe4aNDVkDLzJInEBugdQ4cu8tB4UrPdwukFVwp9e+zEUkAODqJ1YCEhztkFrABPgK3BtYJWim2W0ZTrALfZ1qp4B7QLs+C3hVBkT+N4tAH2M8pt2oNX6jE0h1ovteJo0MkkA/Bvo5nFMtgmsI4Bv2SSqkwL48j9Qme8OuoB8nIfDuuBpz8pWUB5ryuQdA9T6zbKCAqsOAts/Qbd8s3XvExTJNea+vwa63FuMyLHdeF4GdOXRFXDGvgDBOqbxtrM+inM/vzYC5bl3HS6y4T5BN6xJlmO77UlSP7ueUH1B9pcWbASQQEG2eYdXN75r379+8xEjOtTYFe5e7wp2T9Bt5fNeQFeKro301bFO+skpx2zPgQf2ONu2E4YvVEiN1jronh0GQDeuN6OlKWZZ4D7ilm/f4cw5qNvwKz7bO4KuuOYEXdiiBTNAV4ruCbreBjk/3Aq6ySTzgo985DhZyzzLzlC17m695Bw8+anPkLo/OXgddp1nnrKW9fPjoLuNYltig7hmreiycqq1glog8bQuOOydfhOHK+/VOJROQXd1i2GHfmgt12yfZIHu3GwM/VaKi3O52Nfe6/JgtJlUwk+Sw/ptoIvtIpe1m90V3Ybv7slbxgM7DgddfwA4Z5xTQJWy1nDPTD5xLu/H4R0PyuU3Yk0AYvBtx4TaWg9tqbfundoiY6X0koIm11UKGZTeVnQDbNO35dG/nrN28jleWhdG3azfNHwRDZb8ZgmKNCbxoAUIKzo5K/Y8nn2ijEpzo+OUoss9RYCQ32PuiW1lF0uMKTs76Cqnp9TlvpcMdIHe9GlacExYFGI/gG4pWgO6KLg05Ki50Tg3GAgMUQgziMm8qKzDu/tOE8aAXAcw82FiVQAI8NzG/lPRtIj/zmCQ29QkEBZBjzqYqp3g0wGMctcx1IQFCTxK4wW41nD8Dn31Wb7agDatk9+TmaA9t6i0NlmFgLuG9Qd0W3m+V9DVsPuo5dVRGNAtJRvoc9B1lRuvNBYEf3f4DTDGG4x6DIzu1o2C3wRlZYfgXnGbQ98TBsTkWa4yCaKPDkKDLtfMMycAulq/Rijq/skykr5MwZKp3F+xugC7aTcwO8MJuptaq2eKEcsGXXUs43jcz8q6Jfxo6N9Al9GjEy6qbkJNFQTIgtR+TO0z6yRlXWhYpnPsAAI4q94D2Bz2Eno0spN2hrVOe3QlFmBvuPd6t7Y5ZTvaCUbHLI1YtydqB3ykD5GkrW05QjZ+3YsOg1hhgx2zGzrMXWvT+e62kVWYCNBl/z5Bgre3zjuU6W6ge16jGf1TDJSNCFxTdLM9tyA0ykN6MVd0TzZr/ousFa22O1PNCAjrOns0+GJVUNvqnYITdGOfr3zVq28++clP3rz4m17SeYrZvgNubP9Nb37LzYc//OGb5z7v+ZOvWvdVsxb7/XRAF4jzXHPea0E1HRAbkKsHbDyw3tDvPZYBzw10j2F51nelNm8mU3jZZy5rkOFq5fmAnD2H84LfE+hqiKYqkLkhuPiupHLz8Z1DJ//XQ7LfWN3D1IVkX5egu6cowZrA+lyrfrB1Y5JUuh9WQNfsB50mDIuCKp9Wdk3p3bIlOOji8XFrgPl4J70Ys5oRYXxkMgjgzkrdIFd2gQFddYJkXfDZzVBBN9CNRsU8ZKdaEo3l3FuC1XW9GWp064Iv55UeDSyWBRShGqY7MkPoO29IA3QTLFrRLdCNfbRaSw5NIFmqG+o5KmiARm77FtBFvXI/KsPECUAOuqi5WA9iGF7KV+5PoIJ1wSdZaNg9rAeUC3W5gIshd/PKSll0OwTw5dYKgtHG5wucahILQNeG7Qu+C8JLsbWJIgTsmeUAyNPyZD4AsDMl2LILsBzHtiu6BeN5HLJbNKALdKMcBbq1rQs7B35clQdg72NWZ6FAt2wTpBcDaF3FHtBd+5Q1Y7OAtF2ittXWknV/5ixu6gC5PcWvU8F7wXCCbweM6Xu3wqz7nvJcA10PYEsoZt1UiUuFxaJDgFi/Sx3OTpnNDljPR40oMHqTz94xw6Jnaeg6iY5rdqq9PqddLBWzUgceoKt6xYNYt3rEIJfRLzrotEFlv5qcsXh0aTd3gWGyPhALUG3hvde7V0GX+t5sYNkGndYFsjhI0fUgZFKPnYFpCUQIKwpS8/baBSQH3fP/c0SVNtCFI2aCPRVdF9EaLE3VdF5yuDyFOkSXbd8Gts02tyi6tOsOuoBvz05mgptzkDOQJyJIQVMju9xTfk68rLCLK7oIonPfXgbTv/Od77r5nd/5nYTdb/mWb2u11qE/yvrjP/7WXO43f/M3b172su9sGwnbdoGQ426OOhVdTrYPxZOAeTY0gVneQzhB7HbQtaAi64lGoe4Eun6y/Ka4DrqV75PKw4/He9Xec/BeV96c6tk4fPbNhHKsymlb9wBdh2+H6PNGu96b24cKvCcF6HKzTY9mDwg8PUh+U/uNirXhPMYzXdiFR1f2hPblasjfK7IMVDvtDoLfhC+BbixXoFvwyhBaB3apgvSKCkDs7wR3DZRxLQW6LNNqBmpvd5amozLHKStBbFeqKGoLai5DjYBud/DsHpxKzgDZFCCOA/BlyBJLBA1tAm2mU8K6MKnH3JaQx690aefw73hOB3Rf/M3fevOxj3/i5r2/+MsNzAm67TctJTP2EYDLMDdqpg/pA7YM57ZyLEWNKP62IqDkSq1rRVjfjzVh1GCUPQcoHx5v0L0SRDVq7XhpUzFVjldgEzW5lWZXnQW+DOvnObE8uoAuQBuQG95aQA11sW0BUjUTXAXu+IpZhiCx3I55lbfjSdAdoOY3zx98fjegO17czhhh1gdXe7eplGOfAmdSn7Wiq06U+3rPDknfj4LuHlEwVbc6O3Xf1/kpkHbrxJmp4QJ0V92C6s09xRA+753OLkc9SkXephfWaAptH/YiQLdHYjQT2VgZLJOOjfhUB7VAlzrCPbqu7AKoZxt2DXSjHD4MnesKWqOtqNRs1UGO5RjJ+ozrXbXp0R4wTXr7cGP0Lr36M+kE7QbQStaFOaays11Tc7v9Tu9uDXt7W+zq7Am3JxB32yzRypXIWLaEoLKK+T6ugq7NogbobqPNlnXDveK04b2ssQTtM8tfU2cBvByVV/KAHTaHiZx9Wp3WaL6fyz4PJjyeiqtzyTXrAueW/fi5j+frbW9/R0Pst37bt/d15Hz8xE88aL+/rJ8T7zg4/3C9ELEurAu3g25N/wts0mu4puiyDQfdhlR7mAdcxz6wTdJgfg7fN3K+r++wR8+5I1llLXAQP9d1cO5jtGEP3z/7ypv+LqALNDrU5s0oUD4fPpavMtxd0XWrwVzoPYkzvTK/uRx2uTEddLvCMNN/rsPEDyi6Brm3gW5uy0FXSq5P/ehTQnpasBN0U6Fo9Zw8lii/Zl0g2KQBVjltpS7QqHHdgUwP9hiLxnQ2olGtbAtqtASyDbp9zaTY6He//tgUfJiT/92jOw3mKLXcbw66QEE1mAW9CZjm2wWQgGj33MZ3z//6F978p//0n27i79d//Tc6bVMqcgEWBrYNulIeHS4LDJX3FkU3bBf4LgEVpbdqWBXQAs9EtZdnV0PSbV1QxgMB2Aa6Bn95zK4wAuxSaxtKE14LUntYXsdLJD+gS/n6nGg4360UpNIaRbfOHynB7h10a4plwK6sC9XZyKwLoWyb0nwB2XacDZ/2nVszGiDlHz7V11R6ZXfgmnHdsQtghSDtWXWKND0xCrlfA/3fiq4+u9Umf+vlqpOVanIG5mmCEI0gbCqxPLUNvrr/6Lh10JssPNgaGCkBnhmRQOGt58f8u4wcarIJH5XxzrqP2sxInrK0bKA79UZbokgpJSuEd+AHHBQ/kaN91lk3RbeFFNWf49HVjGu0zVKhva6953oXy5iUVgJ6J+DMQNcVXWtPHHSB2yhrZ3DAwqC26TbhhraU9tbbWm8L+d3hzsHWmegE3fiMd3drU5VyrK5PgfEOujPpxIDu2BBn2bG4NejSxhhLOWheKLraN52k7qDpfoJ3aPPJq89nL7cDqx/vtn/dX6co5+v6+acj8NYH39Yw+9KXfYfyTD/hxr//Zim+DtreQYE5AX6OOc7x5tFlA50zTsrmGVm4ga5gz0FywLAu3u2guw/zexDceTDcNDzonxbo2gPPjbvBh130a6B7XuDs3WloyU/qNXif7/bAt9PO4BesLxC9Y/VUvcws4zfkedPSs/PhCF+GsnOz+Tknx23v0ywM9NRzefNNdcVmtgR69q3wGuhGWRhOpyKblGCXiq4ruz2kpoq5PGx1r6F+cq+ckA8MosA26Goms7pHlJqnG7OKxGYo0WHX9+fnFzVmSwuTjSUjDswoVJ/duuAdKXy4sUwOdaLohtoksEW9rWWVt1aNKKDGNlG1ANAffdNbEnLj79d+7de3CSUIEAN2E3QBJvySGiI+t+uAW+Uk80EN43s+24LIUooZZh7IKc8twNXeU3y0UkBH5awgqRpi1xC/D+UDyVIHgc+K2h9fKsphHjvwq3Xdt+rpvAi2CnsB8IUv2RXdBvGASAFzH6Og1n2zGYym4L0nP+WZdf6ugG7ZSWrCCJTgXNag3CecAEhR1135pQPgUw6foAuMXgVdgWrbDdT5aKtKXHOsDVdBt+wMdKDi/ue8jw9cy5z3oALsUKZRXDeV10E3nyV51WXH4LnG6kMmkwRgSwGWqm8qpDP832AlQcSXoZ4l8HU8vPV8V9uiSSbUzlC/RV3SVqkOTq4ML1itGGbuzDFZbyjdpEa3HHS39ubKSNo917tXYiOA3AJwdcBV1q5n0085eXXPVJUIId3WaNk6356Pd9JZ3Qa2ALD/fs26gILboKtpdGOfm6Ir9dbbb8/QENeL9tfb1+alFkMGiC+EPe3TobitLm0NmSl4adcBbMpbbe2R9YcOFKynmVKbK2RdcF5xDjlFuxlFuLQpOBz7+S+Bc4fal337d928/e0/edXWwHnceKUBezoMfo4vgtGiACM/Tyoxh727ga4f7E7v58HvWQA8B941am9wEFyfJ5wDA6C4GSgPEOLLXTv53Ny+ni/noOtDA3cDXX8YroHuRU/kDqCbx6AKDJuFHx/lOmd+8eMAhPOmtiwLPexkii7nOm5IQNen981zBsQeoIsiQMXG0BW2iFIqJ0fsaV3wh8KDzqiAa/hwKvP0ilGB2Pd5fjScXzBYgWcdgOagu/4v2B8FF9DN8un7ynpQQ4+dR7Mr8kubAg0iKi5Dn/jiOBaC5hLc5RlE0cW3Gfts0F37LC9hZSGg0XX/7QXoyorwtlWhOOjmNjM1WTX8QFDBVs3mlfCmiRd86DnLhtombyRl6mH8UAc14YGroUAUSlori3FMoS67QotKqPeEwlZ0JxuAA17vS9DXMGjAThk6K4Epx2dZK8VXeV2BwQLdlWFBflxALX4PQGV5oJXPmb0iVevKzuCBZcCdgy7QDESTlaE+G+jqsx97g66sGK28yo7RNgOp9hegm+dv0qJ5JgUPlEPtbbuB4Dvvp2PCD+4xOkcAdI8+6J5u0FUHz2043Kv5nYOuwDWeCQ9Y7PsyoHIByZ1Al3KlKqyyeB7e7uyqbsjpvxNa985spzwU0GZbZSNQO+gW7BLkWmKBsqwIquM3APcCdKOzLjGh6itleVDnnVGfai8VSKZg3csRwBkx2+vdERjOOs0VXY4zAV5WNd4Z3aNdiJnRXMH1mTNbEIl6W75eb3tOKwFge0ImI6Cot3xuRTSDs3XOlLmJ+vPu1oVJRRbrnKDrYluds4JPH31l37nPvMbKcqWOk4Mu2wNOUalP0N07STNSCTckDyiNGkzgoufeDtf9fQ10bxux5hqc95ZzFl7c8OPi3SVQba7lJUS7xcJVeq7ZDrpS53IlQU6DnH6LBxWLgdsDsvDqXX0ls5cAGax7yOX10NcJ44YbSB4vL9sGXrw3ncPbZkSf3vL4UfrGbFVyppWlMsqL6H7TsBiQ9cGOnZNIBcRn1s8btHOgnpMA6OYQpJIV4ITPPPd5809AVg8h6JwV6Nax5zUy5Ty/0zk5E2JTTpbJiiH8VNgpuO76vo9HZYnKa6ZorCjjr7J18lroPOYDGHYHLAeyPrTNIY/TopTXZ1dFJs0NOWm5RlJ7OWYgk+sUvdZsIFblrUqCe6TAcYHTEysKuzywk2kBb2wCfZwTVURfHVOBhnUhzr9e+VvmrR3QrfOFMlP/u4IL6Drg9v2SjV5tsxqGegd0aSRRA2M5b4B7SDaPrdQOYOP+J5UfN75PEFifM/hnwfFV0JUy7N7KJz2l8sQS2AQA9dC+eVSBJy9Tg24MkTPpwZMnqKxtEPgx12/4ZPHc5r71fb7bMjUcH+uUfSLBcZW5lM3aT7yfEFvrVMaGOC/A4/XsBTVLWOwXr2ycF16A7ZOf+swqm+Axfn/K+i73nUC+9hNl0ue0JrCs/udzpiSLcy9F9MlPe6b8vhMAluur7EA2x+yKc/4f56TPu7JU5LYr4A4ozuua56usEpEGaPf3asazWG+B73d85/fcvPzlr7z53ni94lU33/O935fv376+B8RDqfneV9QyL1+/1bL1eukKMrl/3btxT770pd/Zy+W2Xv59N9/zPa+4ecX6P16x7fj8PWv9eL3i+x7I757z3K+9+e71/Xd+98v7+sQ2UWHzOve9T2o6eXHXcqn4phJNSrF6xihXdmzj+bL6uTq7dK4tiFZ1ZlsXlJc36o8E0H7Oq55iiL4V3fAIBxgq2JT6qKxJ6/nWTIhZv2adW/DSI1QCXeqNBqxon6gfE8wnrWPWX6ozq61QG8321eY4xNOGU48BvATDVd1b+4hjYWQq32kfAvwF4rQv2U6obLmcXrTTKLouoJQavFvVXNhyVuB/4BgGiWNzRTfa0s2jawF+sJKzz//2lZW3lvNB++xtKe33BDKXnaH5RwyR7aO1B3zmu9rPgB/rN+SKD1iuLTHKSOQxOC18GQe26Il67pzkoJttu1gk2006RnumDFhv4xDxS6wfz9oHP/irCbnx+uHXv6ED1Bp0ETrtHHHcdAoGfOv8DegCeSp8wdY6+eYppZfRUXw8uLGOQSE3Wq5vng3vyaBc+XBE3OBeQAfAuXGoVMajCbTRMwE2uAEalK2HlkB8Avjx2eGIbWYvJs38BQ2+b/bPueseEOCqix/rn5DLRczfBEsXDwbgq5uqFV27URz8eUATdnk4BaUcBw8wDx7nxa0LXaEA1kCwA33AsoYgcriKTsUBul0haBs0AlSo+YDYDbwNm6GW2HnIc+2Vth78E3T7Xmr4K9ClxzwqrSoWlTvvISnG8RD659hHqqo5lKlhuVaXp6Lrhi6XrYreQXf8eLVvKokB3Wpo6fwAPDn8qOFXADYa4SpPDaOyLKCbHsho6K2xf8dPvnNXdBVlnhYJH6oX6KKcbtCGGihQALBPP2RsLyc8WNBUoOieW2UB0LlsRVfKMIpuwxiQiHVBUJugqyFvIG+DvVyu9lXHJ3US0BWAAkUOd0BuAmACY6m3Bf2lpMZvAbXxHsfPMvHd057xnFGeD9AdKA7bQ0Gkq6mo1gnM2ndcx/bbSvGmQ+JKcyu/az3O+1g2wkctqwMdA6m9uUyC/DPymLj2eILjvoz/H/mVX+176Pznz/7sz3KfcU3+6N/+21uX+8M//DcNmv/m3/zRrctd++H/+D/+j5v3f+BXbv75P/8X+fMjj3zw5ldWg/lv/+0f37z+DW9MAM5nRPcGHaHuKKoDiLVh4FgBbwLwVHTXcbTYIhCpgLXqpHYjH1CwfgdM294g0C04rpGY6ZSPdSE70FG3BehafTSwUvvbUoHdArqtTkrQ6PpK7SDlpvO+weJt9a6LFAZ2DbrYJSRkVX2FxaPqR6wNtJnZnqptQDDpADYYRe/d2ZCg0jY57c8VSK6Jgy6wBXPQXgK8tL8n6LaoJxZwlshlmVxC9fwJr3ktxQDU97ENWGtjAIkTgCrtVdnuGDWYTEsXoItHNzsMxSzexjjoBgtkJyPuW3HggO7EUnEvsYyf2xY5JWoiPLqg6FzlQl2U66GHfrq9usBudGjhI86bn488d7KnwmQcBxbTBN2GyLhZdZOMMlUBQAVm1eti6Prx8VAHdLBO9sriJAWs1f+xbPw+JweQIwXYqJ6ALvvJ9fKkR9LrAYfcr1F9/N5wnTA7s8vwW28zHgorX2+XMvr7tm/5KAX+VF4zLF9l5TjzfOl8+L7zXLVSaBkodA6z1w6sAUR503BOZzilbrC6PvRk2a/fqK6SV/n2Gxk47rLHg5hRpkoELvWieuK1rzzH6hWy3AxVMatY3QN5Y68yxvKAbm0/ct6OP3VUAob76vhcaa9KRaq5XetsNHTv8TAzrJ/b0LUZlVNwGg2DFN1Y5r4oU36uc8TQUjaSDFmqMaHCQC2i8auHrdaN44v7lUaubAFxzHUM990f+1Plo3WiDFWOer5olAHz+1djUf7RUqrKsjAR5aVG1TNSwFfgR3l6qFmK7k+uFC9uXbg/YDhea9sv/uaX3EQkbNgUnizFFkUyPpe6W1CWKiFeSdkeJvBNCmuAbsDhgqaAXdThTWFs0JViiDobw/A2/S1K5xOBQoe0VBnDXlEgCzBu/0v9zX2jRjs46tw5bE6argoKA2JrWt6aJje2BxSm1UNwWaD7bDtfDsl1HsnOwDndIFrQXMow525gGLU6yxj71fWpDkkp2U9WWQr867zE/VRKfS1T5yxeOodSrCNZOzOq5bGu35++juejH/34HaH0T/7dv2vQ/df/+g9vXfb3/+AP8v6J1x/8q391z6D7p3/6Zzc//wsP3/yh4Dj+/9CHPpzrx3YCeP/zf/7PN295y1vVuRnF/7QktFVH9zGTSMwzGPaHer4ArbIzWBCoNfIJsrJZsA5+2sx/bb+3cqcRqqpXqjNb9ajqFAOWVvYQbrJuqvqj6zDa6Wj7oh5WHUd9sqt9Uou9jUQcaYFBKnCUHeBS/R77po77aolcdbyapIKOfrYfM0lEtSfVvpRFg0khFHOh44crUoXOdok2Znij4I2XBDFxyrBCtbPZTkoFnqA72rhpa7vNi3NJWyLugIFo61oNVvuY7a86GCVWnKBb9Tz7bz5R25h1OUyw1p17b+wxMFgJQ8VD/aJzk21RtRXNT3GexDnBXwXp4/c9eaTFRNhDwE4bWxw259Z5Y/6H18Y3Hs/Cz/zszyXkfuxjH1sB0i+4+ZE3/mgru69YIz4cD2DdYpE6gbFfnoe6Buo0ruO+BN0NBMcWcIJunJzpjejC8UAAeOu9yTqhRMAm1YsDBwg9aKpvngvQNeN/n2Tt38AyYed4cNhf3UgGolJaNzi1Y3DIzp7FunEAF4ZneGg20BWINQBrP7U+3hw9kFJL84E4QVcPZF44PWQcAxXD1mtUBwEA3kDXjoveFMqww+tXrpuez6VIFnw66GbvUh2geA94dV8WlRXnyEE3K0GAUSBNr95h0FX66oFbtgXdb3hVswKJClcK7wa6UTEKkkttrKFJKmZ6nvQAZz+l0JRi6kOW0zPu9EMoNDpPDrnZoKqiGUV3etj5LOmZGtDVtLkBIhrOB3wbdBNWa9uoUHNskWCf6Vw1W9kqY3kmlS5sbfud73rowqMboPuTP/mum//xP/7HzW985KMFdIJBwCmVWZtKFjhiOt3a9+wf/2oC14K1p6wheEC57QSpllVjW2UsQE418wDdArNRhKssNfTOvqesBXUbDHbZytLAOm2BCNANAAzQc2hMALwE3Q42C9CNgLGEyALR8OdWEFmUj46BgW6WXfvS/3EcAHTm4BW8Bug2WPs6VkbUX4A4js8h91SK/doE6AK7+b8punWMVc7nfc3X33zqn/zTuwLpn/zJAt0FybGPf/Wv/vXtoPv7At21/T/4g3sD3X/8j3/v5t0Pv/fmP/+X/5KZQ+Je/tSn/knu4+MrXd773veB/P/P/uzPb35xpc77qZ/66Zp8I+6rsCqsfWVHNGHVPOk+MqH7jw4tANqdYD171Dfx/HqdD1ywH6wENUJUHVpy9RYQ6jOd2AN083fBbrw7UFKntpKG6NPtr8QLRqBoo64Atyt3Uz8iVlRHHdD9qq9eqSHVRuygO3l8XdEFbDcbW7IHQcAGujnTY4E+EFugaz5TgS3t1ibSNJhKdBGMtXKZeW8LRhlBbFASs+RnmMe3JyiHYaZNlZAX7SKgm+26CYMSQegwAcTNJ9mxqGs9oovuF3VeSgAb8QrQBTxH6NP1SgGjOli5rpUnIPcr0nZxN9A1ASu3gXVi4LoFSm3fy7mr6ouFVnl+/ud/IaH2ox/96M3zv+4F3dl5/bIuoOy+8lUPtBLeiq7EQAA7z2VypwTW/L1Bdwe/6VEU6G6WgHVDodIWrNmFS4LWQy44mwjEuhhIz/RsGt7Us6phBEtyLZVuehIDug6sbXkQJNLr6R7iAXgDurohrcfUAC6o2nsxgG6dQCCuHhqprlLrHNbdqgCMzTmom7B7fvFAqTdXNxHXQKArKAbstgdENx3n+nx4+liiQjGllXNJ5REdFCqjAV09tJvai9JfKnANo43fmTJmBR4PV/6GQi31IVWBUWoTCAXX84BMMMR+fxSEEgiGWk5UcaqzAmT2n8P38ugCum7P4P8ebgkgFyDyICX86iEDdAFnlArANhWzBNVSfkLFBagpewWG6LqrA1Aq9a7oRiOaECPAxTu4g25BbQ2zMqNYDKPPVLoOuu94x2FdWOu9+MXf0kDywV/9UMHaBrqCtAZdVEDNXKXORPo+BZ74e2NbAWsBugmYCZPkmK1h4Sh7lpHJBAS6DtcokADqboUoyHYoR41tNVT2BuwTpWDOOqiLG+gKVOM3shkAse5hxY/LMbuCzTEndGN7kBqd6m94YaUso2CngipofiqgKz8tinGr1ut7LBO1flkzOHcXCrUAr/3LAubquBTkx7pPedqzOsjuG174TTf3ai9I0A1QD9D913cBXanJdwPd//bf/tvNB5ZVIbKExN/vL0h++7qP/8N/+NP8/MEP/tqaRek38v+A659850+lqht/L/rGb+nJJOIe6ZEO3WOVAYSJIwqIC4LLEtQjO6qjsTMk4KViKa+sFFC3LsRzSlsAcLBevCOCVAYQjdYEmKg9zbqY/Qh2Ad2xQzH6WPVw2yyk8mZHWnXmCDMT2Fqq2Mwy2qNh1i4XUE+KzQBd6kTqby9XbC+/PxRd2ikAljaphvcLylP5RrUT0F4DXawLA7nkQC8ucTV3QPBQdNXWloJ7KLqqn+t8VHuP+uwC1Ix4ihHWcqOMDi/VtRzBizScDrp5b26gO52c7nwggKmTsKuqmjRE4mK2fd1xUAyK2CUg9yu+QqAry0MHnute59hTgRYQZ3t5qMicHwTSOSbF7Kiz4ZD7kY98ZEHuN0zHQMf1Az/wQw27D7z6tRJMS62t14yMXwfdJ45H1+GuCyWgavJXz2EH3aF5pOKW0dfBDOiqF3BI+K2ECnRb0Wz1UmZmQWRd+DL+98MY68qjUWWY4eCWu/1mAEjpYakX0EqbbnAU6BlSn8kYUGRTNWWIBtneQDfXNYjmhph9jSUDA3kDpqvSlFnHx1AIFUMry6jTqhh8KKMVdZ2LAV2iOlFow55ioCvl06GVymTumwk661QxqhDo0QKau7KvfSYEazi/Id9HAAqS5xjMzqHKvyseKbD40Nr/S0WvYfms7KMiFRQC4QW62h+K9Vo2Gr8eLuMaq/JuNScrfw3V6V5ti0EqMRNJ7cozw4iUJRtP3ecNyrIoROUwii7KtFsXYmi2EsJX3tGnrSHm56QF4dWv/v6bH3jdD9/80A//yM0PL+/iG97wozef+MQnN0U3yhUBP/x98Fd/LVWwVBVXYw9gBrwBqABtlOupC4hiX9/3ylffvOqB1948sPb56tf8QL5e+9rX5ev7v/8Hb167Xs941nNLqVSAVKiO37Qmr4jgotes5SOo6DnPfX4FarW/N7IXzFA8XlusBGEPeNm3f/cKZHjjTaROe9WrXnPzdV//ot5H7OvZy7MZ3s3ttZavzz8636/v4hy94UfWK97XK4KenrnKXd+t39cQW77W51g/9hvvP/TDb7h53Q++/uZ163x/67d9h6BWKjTTEQtE4zw+69lfk8f7mu9/XZ6zb/+O78rz07Aqz+5TIxhtnfsI5Hrpt3+nrBEKdBMoDuhWIBtg3gpxqtuyngh0TwBG2T5BN4LGAMq7yrlrgc826P7L3//9pQC9+wYbRFgT3v3we3L04b8sZffh9/xiq7q/+Zu/lUOiAcbx+y//8vtv3v3uhzUSUR0bphf2TmHcXzzTrf4G/MZzKUsBYkQ8L2VnKIhgRKY6bHhwsTCpYVaHNdqqtD2oExp1cim8A7oMx2a7IEDNuk2ghDJJ/Ymqy/dtqaL+A9BVvqzDs84kzkBta7djl/Uuo28NOQ26k2UC8Qdhg7Z7RgFnGL+gtuA2QQ1RbL036Op7hJRT0S3QXUPvaidaLGoFtkS0Fo7UeaD9dlEswRSoFsQxNH6h3pqCH8vUugghJYbt9sE6xhGzCn6xbjoU9ggj6qvalLqmZuvUMcI7DvLsCy4q0FUGDrVvsXwqugLdZJGI7ZHwOPfaiHnNVhLXHHabC4KtKKfOp5fxZ3/u5xNiY2rf533N1w0wM7J9BXZfvmwMzaTqVGKXcNB1H29aF/yinvaCvim0wbgg3BgMn4ya6b7b6knUPMs8KPhTp6fFw5jbRRHUResei25ICt62gbj4Asm7g66UR1NeAdjsFazv23OsB78u0JE5QeV0xXhA1xVrrBq7j6aHEvIGUJl0s00aElVo6q30A2jwjzLuwwClZs6wWUOwHlR6YSjNO+jix61r46CLssjDQUXk1oWGYFN0G3h1XQFIHwajks3vpPaiINcQnzoCnCv1JB3aqfwb9vP6jS0AG0IrLa7oCj7b3C+1w9URlNYAslbh2X6CbjVyA6kF4VgXGBL1IUdUS9QZOm8Bt/yWDaopujNTU6m0+F8ZKiwvbiXZx74QUBRq1r//9//+Xpjk5leXehv7j0j3HXQLLNNzqoj9VAilKgK6b33r2zMA6F7+/vf//X+/ec6atxx7wBt/9MdSJfw//8//c1v9r/7qP9/8ygp2+rpveKEC2Qrq8JwOkD1jJRh/+82/+3eXx/pf/stf3/z6Uvhe+I3fnNv42ud/w8V+7qXMscyv/tqHbl7wghff6+K5XBxrqIzPeOZzyq4hNTkg9FnP+ZqbX3j3e27+43/8jxfb/Pf//j+s4fifzs5DWEJi3ac+9VlLEX/WzT9ZtoE4V6FkVqdjsinEPYnlIM/P2l+qstgnroBuga8mo0DV1XIoutEB+eu//utP69gbdNf9eTdFFwvLNUU3FNn3v/+RVHEj+Owv/+qvbn7mZ36uoTbuu19+3/tv/mp9H38xy1+AbfzFPRTZRf7lv/z9/PwNL/jGtpAAYA66ZWkoP/1uCVKHV2oqz2pabOhAR90g0MltS8Ucf2S1DWNdKECOzwm6gunsWAOfAkGAlG0CwTOUi2AwloYOus06djy8Wc+aqINlyOu4awJYMkFAtxTdUHNrJA+hovaRbafaJDy1pD4EBAFaQNdHA1FLc1RO4Ov+2xId1M5m21GgC6CifrfdQZBbiqfiacQz7nGNbaLK0s7Qxrs63u2y2m9fFrsbo74dQyMoTmhG0InrItCt4C8b0e5zPAHsu0f3MnZnRpnrt2KFOlcVL7L7hGmPo4xtXZDdAqGM9vS0YXpZB67lsUbgg6HEJpQvyvVNKwbkVz74wdUOfG13QlrV557X+q957fev5/l9WRfCPwiGrTQLrNsZoH1eBV3fyEbKAj+Xs/ehdQfd6m1s1gX11nrYV9sDVjNtWXtU8Z0cs1rRo1nvPWwQN7gUXW5gIHxTdAWKqKz0ClDpLkFXwVC68egtxL6wbcT2Oakb8AvQGpR1wjeFtx+QUn1J28b54SLSIwS886FUBYJaukGelOq5YbCDzHrdew5PayqYU3EV6BJwJgVdFeReMY1H94TgrcLSdS0/V1W2AOyoEJPKpirQqjQ98IyOCRUVPV8g089BboOhPd1npSjLbysrQQ5FoujqgeJ85MOt3mq8R2PmHQmAHDUGDx5AT8OWoJsqENaFSTlWKlA1kgyLovo26CrtEY1EpulqH2oEpVWDTAATkeNf+7Vf31Ho90omod5Ggxepnxx0UXFvA91nPPO5Nx83Zfhe9hcQEnCV6y4/5d3+/nyB4Cu+71WdpitTXilzwzOXGhrq3d3+Anhe89ofSFj/hRW09On+BUSF4hzAfAL5vWzrIx/92IJNZWdY1/DbXvrtq2NweyYCthlQm6q0bB8Btr/927+TP//N3/zNCt4oxbo6AJXtIf/vfMULdJclwjM20FnIjAtSi1F8CdAjo0OUOZTuv/mbv72Xw9yWAXSjc3Ynj25AaFlNnr55dP/7f//vN5/85G/evOe9v5idmH//H/7Duj9fefPc5RF+4YtenKMG3/u9r8jz85afeGt2AN69Og7cDwHN0dn74z/+kyzXP/69T9187RoiJfAMGE3bihTxBF09/w26UWdkPVC/8Xs8LzzD2BsKnvWSylsBawxVP7HqBCm6jPpEHVdD/OUXxtbAEHACYlskxrLVgoCNNGEdyJEhB1qJVg6KtV0fSq/610WJ2+tdtdsXoLvaHUB3HdfYxGbkzgWSCxuDVNWoX/HyIp7s1gVZCTSKCZwDkiy7KY4GurQjLUI56Kr+b2ukxCe4p8UlE/Pa9pDLFqdMoP34aRl2x75ZWQ8+DdA1nuKY9zZ/vLS0WyizrehyX4g/mBmN7XjsT0I+5y3Pi2wRAvWCXinyLhAi0GXnR17oVsllc5Ro6ddoOE02EYCd45aghXWhHQXZ4ak0c7DlAbp1A56gOxLwRCmicvmBbeqcClM9BPWeundxXdE904u5otoQqQokLpj7Yzx/3tabsovBQ+sem6kArii6XBhdQIB4PLYl/wO6A9WoqnaBbBhklOTxt8Z3njkByI1zwBDCBLwJWPVgtxIswG0gNHM9NyHDKoBoHkucS1VEVA6bdUG9pFKEJygAhbT9VdnZqBsX1Td72avHHxVeqZYCXZWVeyavrykOKKqj6OKBngTl2DeiIsffxr3WoKuKqiu7AHq3Lgh021Cfv8tHp4oK60kpuhMMN6ArL102jKNmMJTpEdvl0Z1GEBWI4dACXvlrMwhlKT+W3zP2GdsY0C2bQkyogO82GsgYmv+jP9oBKoAovIz/9J/+s4SBCNqJlw9DA7qvWLaDAd3w6Fa2BEA3P0vRfdrTn301KCmCg0JJjqj7P/6TP8nyxCvKEEFBT13rBXj91m/99gU8BZT803/2z1cQ0Z9tvwX0fPca3u/h9FWGpz79WTcRlOR/sdy/WhH3/+Jf/Mv2ZvL73/zt3y5rw3elKh4Wg1/6pffdfOCRX1kpsj64wfJf//V/TYX7V9b3H/jAIzc/93O/cPONy98Z673kW1/WoBvnNaAzjuM31yvef2t9/u3f+d18kfKK/YelI67fN7zwxRcqbgyvBwxeK3ecu2cvoK9gtKc36Ia6+c0v+bZtEo6AgwZd+X8ddLdgNN1fnSpNqcsmrdrTbkKp/7uAfRzzBrp38OjGMVOuSEMW+/vd3/3HN+9ZVoR/tu6F+IssCnHNyr+qvLcKHMNbG5DK/RAq/s/87M/f/Nf/+l9z/fD1hiIfXj+ykQCWA7o1IkJdyPOboyTx/OkdVRL/bpVn1qOjW0Pvk0YMVZARItTc2E6PBGFd6BGngs4MTso6pOx7O3wgIFT9VWrcE2S1KEWvA4BbuNB2AV1ArkfS7qXerfrdFd2sJzXsjT8W5Zy6fQLZDJikzAK28d6KrrUvKMTYILo9k7cWtdlFnFxGqm4DW7ZpBUSIVh3MxDlQ21zCGG3DQFuLHwl3lrFBHSVAd4PibG/xaxeQbqBrKmizjjoxreg66KpTsgtvpQzDcx0DkoquVGs6RnGMAeSaGS23I+sCnIXQhxDX51Kg6+exFVYp2LSh8b2PQg8/6hpIsGxIbW6amCIH7OmMYamQWt3CZ233mAK4holb6hboudcBIDv9uJt0DFxkL6HSVYx9wfwrgK8OJoEtezQzXO1y+FgXlMNWXhjsFNXjrJux1VBAV7Ddy+imb9CNnrRuADc59/AEN6ZunPbo6oZAuZ3eIYZ1rA+TxsN7RfQ4OK/jPRmjtcM05xlze/6m88Y14Tz5EEDfhOolZyciz/+kefHKgfRifMdwUN2kdWwoAl3J6Lfer5TUBN0YkpOyQIXT9gB6hFJ6UXO5iaeDogdXFegF6AqyswHKilyKh44VRbeCwtQgWUPCue0AAVRlnSMaJip0VJ2axaqCUDxAYwdd4LWgvFN4oQYp8ITI7lKZZF0wOwKNRU1wUFHj2BQmB+hTb973/oo25++97/2lm2/4hhdVgFp4fHP4vEDh7W+fYLQA3Tg/rzTQ/ZU15E4wWuwLGAmVL/73CSdif+GhjPWf9ezn5TBT2CcCRisXa6wzgVFve9s7tnKG+hZqXU168NT0qP7A637oJlJI8Rf5VgOuGYr3rBGxTCjL3/KSl8rH+7Sl3r0gh7gDCPkLaAzfMgFXAY7xf8zCw1/YKDx92GRAePrNt3zrSxv8ADnU5SyXAsZqkoqn38T55y9sCvF9QLD/BZQFQFcar6evcr9w5ZX8mZuAdv5+eWURYNsoumGL+KY1D3zaF2Q54DpNpoUKfGtFt7Mp1EQV5OzNlG9SybGEBCje7c/P7blsnB+83HeyLpSiWyp9ZEiIzkWco9h2WDjCe/vh3/hIAn7e9+vZCTtHzXZWdh4yikTGkBgxCMtL/IV3Nzoqn/jEb+bn7GyQQkzwSjo1sodgRWoQFcQmZEfdonqGjijgjZ2hR2bUcWXkp+0OskJlx1Vgi6Jbvl0ytQxcZSdZHuGqP6thb4tBtp01clZ2AoGuoMoBkSw0tIFtp8ptuvXuLvWu6uMSPEatbRCSOICiuy0jsabazQliBnTjuxN025qQ5xXLG9aFCiKbtkyTc2g52lsHXUatBxIVcG/ndUQonW9TJ11Aa1huBhlFF66CaRp0xSYp9Il/AEJYpmF17dfTg/X3eb0m0KtEsbI7zDIW5K77w/knlqtZ6ZSiTEIZ1tZL0J1OEB0Fyt3MF8eG0HlF0b1Q9C9A10f2Jy0ZnJXlB/jhRkF7C48Oun0DCAAbYtTbORVGCB3VlRvVL16eOPUQOFhOOuooNxkHXBd6skB4DwCQc1sC+x/7QCmUWAugfyBm6ylwAeKGvga6uhl6HVP4HKS5EVp1FrjtCjI2CPPsxvYEjQnryO1I8rqInjmB80z6jOyFacjDOx/c4H5e+oY4KhSCpxJeVSlfgq4epLyp3M87FU0+IAC0OiEJ8Am65EMc7xbncA/8miGzHYTpxMwkJNwn1aCsiGX1gqlwAV0ffsuK3kHX7hUajL6Hdb2j7JV1oYYaU52J9VSZMV1rg+7KqsDxulqTkNlevoJdoDeDWVrFUV5cU3RTVeqGVsFo2bgLdKOxVMP99ct/+LcGRwGC6ellfwm6AQUFujGsy18ququcEcDFXyidbV04QPeZz/qamz//8z/vZf/JUoufuQAX4KiMCzMbWcKipsh99vKm/sVf/MUGsBF4lhaMtGcwU9dT01Pp+/nRN/1YQltMBPAXSznmLwLrCFSr90qPFft901rH/354BeSN17dy4kbQmMPwnie3ADSgLUAahTOG0yt1WGWOAHQJAottfP+KHObv4fe8N4HW/0JRjuUro0L5bWM78fl1P/jDDen/438sqF3WifgNUA4QfMkqTwAyAXmZmSOyJShjQpZL1oWA386ZK8Av0LUsELne0xM27/YXASXRubntD9CN634n0A2rAZksPvSh8uEG4KbivpTYv/iLus4BwdgJuL/qfgN0n5bWG0Y0QlGPEQSyRMT3kRoNq097YrEtCPyxRHlQWoCHZ104R1x268I83/ns4+NvmxLpDcsOEfe8g25lasHuUPUiVgZy8I6fVtCrTvmAbnmBS9mceskDubLeQhhoSAR076XeLYtCApyDbrQFgm2gy+M9GlJNPNksb2pD3LoA5FY9PpNPsB62gU20yXMyo6c9Miowcjagre/0YmqfPSir2tnJ4nCCbiu36lwgRsE+zTzqUDAKmcFgpDpDoJPYcg10pz2fYwNSG5RhEbEGoxQo/gP8UrTFIJfK63Sqql1VwKKdwxbTEBy9A6b7IrfLvaLOjXcw3L8LG8FVxRKTJ9g7Y2N5rXJ1buQsiym6ACM9gQRFSFnDGvQa3a+CkpkXC6KOi6N1w7pQJ7/gqEHXtu83mnsrXCV12KTn6UAMvdNrctClB9XAY71VHpwB3ZkkIMvL8IsqAoa4HXRJEH1xc0nR5Ngvhk3ojevctR8mz6OGmo7eyfYg6je3NnSvS+d6bqrxMdFzrmGDOt4TDsf/jM2kKj6iYkvRVW/LwNkrIob5URams1TDWl355voH4PK5z8NUuPTmUO8B3bxfpAozrMgwof8G6LYXGt8cHR+uSyq0k8Owsi6owREgx+8JmPLgti94basgt/x7+O1y2l1TdKvhqiFPYDaPZx1Hg622Xw1fKbLhJQQmiQqnoY9MA/yF+kl6qd6vQDdhaG37nQ66S72NfTywfI8NumuWqZ59S6BbeVmfcfOqNQTMXyiPAWHMnsWsaqT5AnDTZ7rWddU4oCbgpPPMRtlSDa1JKALoHVR/Zyl9oWC+/OXjJY79Yy3woXlgL8obtg3+QkElfReA+G0v3UEX4CylsyA3lnXQjSCyVz3w/TfftSwVMQ3ud37X9+Y0tN8Vr/V/eEg9FVdkZQillr//9J/+8ubZz/na3P7TlMIrVe91fKGIx7v7n0MFj3I46EZ5WkVe6xboFriiNAcIZ4qwpZpO2jDlHRYoct5C7b7bRBBR/re9/R15nU57hkNv5dEttfmcMCI802Gj+bUFtgGjZPL49V//jbSShIJNkF5YWUKhDUWcYDFAdyZBedrNC1fqMwLmwnry87/w7vQxx9/vLotLZMNwPzsjLwPLFeg5UFnWpAoes9EgOrp6jur5rby8NSIzoMuzV77dArTy7VfGhezYrXWzE61lBnTL8pWgq+3OqFOpvQ4wXucBx9NmSnAw1dZB19XQai/vpd4ljqaEjipPCSDYJxx0XfnN+loWC7e8ZdukOJEG3R4ZLvWW8+hwHG2hj6wxq9q0cYy0iknEKgyhE5vSPlu1zQAkAiCg2yOwiCzGTIxIulDVCmu38aOKougmy8gSCcxtqizWOngqgXL4Ct5q1VNtfI/CCsBbVFQ7nsDZoLt7abHNMIoQ92hznRR7Pjdv0Z5aW+7CI8wIuyWgHpaD4lJdK4NkBD8SCZxMynbgpbYu5IlS76UULE0rp6HujjY0qgb6gGPAw+XkDXTNFuEgzYFA9qfqyokApHmoWe6i94FK1w/qnvmASsP3UwpcDUsUkMnHooew1UWBT93E8rWQcy9v9j0HcCvl3gPUeZ5hJ5nGgWo6DCq/93JORZcHgh7NDC/MLDNjHakKAsBt68KqbB100+9qlUo/3MCzfrvwRyVoAtRVMee1lX9rU3DjvsrKUAqvHtQdeD1HHgF1Souic1MNClPe1sPeXt/TlqAH8lRlaAS608M17gqiGpgNdPHZ3gF0GY4si0GlK0oolrKD184Bl7y4pf5WOrP2CGJv2NQrMi0oQG39FpHn/MUsUUyGUOqQJl8IGJJy9a4FGPwFSMQ+w8PIX6hpPVWvlELyssYQMX8x9IyaioeY7BCn3SHgy9cNVTQgrFVQHWMCtnLxPv/5L7z52+Wvjb9cfsHTm948UP/7y/ZQUfuT+5XcsaisDvX/fHlC+/fIXRuK7goO4+/f/NEfNSgy5A84hoKKovunf/qn6c29l79QsCPLwidWcBV/AXlYBgJsE76lwAK6kdbMr1GCroLRopMQoJu5emU7yKF8BaPVLG01W1tuL5eptGPYFOiURKcgMlIEfN7pL7zEkU6N3MNxLm/7i/MDhIc/O3zbcb4CZCNHc3hzI/1XdELoeDz88C+m3SAU7IDT961sC0wEEe/xTESn6sfWbGfRcQhlPzpKv7TsCgG5odpGZwL/dwD1L62I7Vj3+9ZoxUxmUs8j9oMBZ6mpWAg0YsLzyGgOajDp/qpDW6M9PqsaMF3+fIFuPN8CXTrDBaY1Inkn0GX/tFNj1yu7Vrfn2RZqemI67erYZ10bAg7vGq2q9nWChmnTsIrtAsOk+USYSouCxJNWdNUGjH1thA1gGjBGZOG9rQu0m2pjbgfdCfZ10HVrRI5Kanu0dYBWnBNSqDqM5f90EGjbttHn8fqi+sIIHtQFEFa7irXxiZXeS6AJdPaIuY2QTntV7Wsr1NY++7E007QQWWzTwe95/T09aIFli4fYHe3+AHQZ2Wf5Vqvt/J4WxY3vUmybmW1hHRdObwVd6yxg5YRJ6VxQHgNd5O9SYwtsFfREg68LQ2HahK2LFQUe1a4OgHQVdZOMogvockBI2puq2VAms7puTAddV5TpLWSPEr8tJ9xOCh5c1uVG2UFXCuYV0AW4kdIJ8JobztKMsf9+MEb55hxTHnqN2dFQr8vhP49PNx0XNt63CMNWIwW66pGPj5ae3+QspDJABd1BdxTdsjjo2PRwAM3cKwBzZ1MQ6KJGONzW/9ZjY5iFbavDwXFT4XpAXVaqDM2pB9kVeDQWGbRRqgH7i3eyHHCvOMz3dcnrIKvC2hagi9cM+0JHb4eSk69K8A7AojZtoCubwhboIv9dewND4THQzUZUyk9Fh9esYyhJQGWoWPy9850PdaNOw0lAWZZr+RtDSeMvUmDF/iPnLX/vX8PXBQA1vFrwWbN//ezP/kIvFwojNoUG3bBIrHVOi0AATXgm+YvpX8kQkMoaQ+mp6NYkFJFZgdRRYWMIsPuJn3hbbyMCkCrFVg3710QO5TkFaH/sLT+xgXl+H0P+Ss/lloJQYXv63pjFLcGwJnR4yeHRjbKFf/ROf3/5l3+1ct8u1XqVz2cU+7k1KxCQ+tSnLe9xqMeydwSYRgfg1StTBH+hRKd1wUD3JS8Jby/TKpdn1Wc0O0GXczITdZR6/s3L60t2gtuOJaA0ciGPav60m7h+/hedgFBRQ40NX2xMDhLlC7/vRz/28bQwRLBfpAwLSI6UYdEJwX7xOysILY4vZjZDhY9lY5a+H3njm/NZfP7yMH9y2R3CbhPZLPgL28PPrv3E+Y6/zMKwZk8L60P4djMfNLYYBVjmiErcc7IvNGSGkqscuYzKVD1QsAqQtmceJVgAmz5bKbc16jPBpnR+AeK456tuKTiN5wZAbkVXVgYmnsh3tW0INFv9pToQBZisM133CnSpM3skTKCKIpvw17BVdWlCa8KzpZPSSN8Emi3bGnV8qLBq11B+N3uf+IARwAZdZV1oJdhBVyJNt2+p6M5MnkByQ2WrnzvoAmocI9ZAB93kIpWf0Wm4pkdz1T4ySk27SOrUC0XXxLGcglcxTbT7iIjTyShBDlbZ1VuHRp/GWL5ttY8u0rnqO+ldzaMrlbUtDrrXYv99jBciHr5alGY85IefFnHLlNwBXWVM2DoU+/FVZ2IESVRnuMxH4y9BV1J+g656DJwcgLRPkBU2NuygGw8AnhMehpLg8XgImgSwCW2uagIuffPUwbt1wUEXUBzQrd4SN6urnR1lbyBMMFpH3bd1YUz2pVJKOfRy0QmQzM5xjlI+Hl16klMeUz8pry5gg64kfR5Ehh0cdHnouAFaCW+VFcWVWU2qI1O9bNKLFdhS2UzFp2F8Oj9WYYxKPB6t9s/E9RRk9r2hm5dz2dG5DbhSGjRE0x0Y3dj90FOpXgHdqLizEQJ09YAWgI+qUsNso+B37/dQOSrauhqiBt2E2koTVI1SQS6ztE1O2/IPFujOlLau1A6ETj5eFN3y3k6EOUOsrT5pyDThci0bnslp9D+c8InihA+4oLjsAQEG/EXAT5T/R37kTf1dpGpCuYvyA7oBWz/x1gHNAMMAiAzs0oxn+R6gq9RXqSZmINQzbn78Jx7sfQS4xkQPpegO3JKzN94jUCwCr+IvFLva/9t7G7/7u7/XFosBWEGuYPbNP7aDbgIfoLugx0E3bR9AcwbRCaADdBdYouiGjzSC46L8v/EbH92AL/L3hiIZvtxvXLPNAeGeTi18xQGC6cmNIDvbV36/PkfWA/5CmYzvfud3/nF/FxN0sCxWFQfzOH+RexfFuDsDOQtb3R+RciuC9qI8Ae28Ai4/8pGPpQobkBr2DLeGxLphD/jYShEXx/+hX/9w5gz+1QWvYbn40Ic+3IpupPYKkI6sFDF6EGp2jAQE9Ia/m+C5n1sTQpD7ObKChIc5si9ENoZYPv3lOYvdM9a+K01cbPunlor7e79XUwD/5V/+ZYJylD9sLTHJRM98F52p6ESZVz2fqwjSVOdxrD4FnAm6WQ9I7d1AV89oPucDwPlcpypc1gc6wlHn4Jsvv3GBLbOWAbpYn7zDjWIMFDOcvAWTqV2b4DW1uVFnBqT4SJraGvZR26l2buIxyHIkFfEW0GU02DMqzL5GNHFBpNroGQk9QRchxkF3guqkigZMxwhrg67sIwLhzaN7wC7c0HCJoitA3z2901YAmYxgwxrb91JZURjbvgk0a2QyFdZUdCt4H1hD7Ya3EMGcz7qdBzjFUJ0LWG1fM5sYr0VFBMVgDLMO+HlxcE8mSNCdJAPbqDvnV1wHC6Byt0IrdkS9drZ01XfO5wTbbUwXHSQxBly3AfMq7w66wIBgEt9Ke28FYZuiK/+Fq6k9BBw3XhuP3aOrrAmSrH0I4YQzenwNsQIVekajCE9EXqddYVigVVX1Qkwt9V7JVdDFo6Tj3FXs2SeKoN8cvWye1x10W7XVxZ4e4mSOaN+Q3YAXoGspQKgs/HzS0/Vhm37YBK30drkhE3Tz2lSPrEz/u+8KTxDbzXezKOBl7UpMw1koE9MTJpChzpH30lqFkJLNOlS+Vdkp2ILKG1VYqm356lB0q4Kn8qc32H43gTYdnbZRSGUhqGMH3bEWTD7dsoJgDQBMgUwAd2Y/qoZuG65c1wAfIqDLBBGXoDs+4ACASOrPXwBEJccf32H6N9WYf+3zX5BDxPy99gd+MBv1gAr+fmzB4YCupshV0FXMQAbwlc/2lZ0LFdWsAp1GacU7+u3f+d0bFMYQdE6mIPDChoAVIeCHvwCvUGw9a0OAH3DnAOuq7Zve/OO9jRhGdyCO/YUFgL8TdIGwUnQHdMNGEdkhUC0/ssBqzv9f5wxmZBPA8vGuNQkEf6GQvmhBMKBbmSmYdreU0CgLfz/yxjelAhzQGVaISN0WnYAC9nrFOZvyhj92gW5mwFjWiMzMoMwXyoLx9WsyjlDkw0bQrwWUAZWRCePf/vEfp93i6QvmmVEtbA51jZ528+sLbv/Dym/7pysdXKSE+/M//4+Zti7KHcAc5Q3QDkU3U9otO0Mcd6iusY9QqV3RjTLE99HxCisOgYiRqu6tq3PF/VjX75k3r3zVqxeMf7SD9kINfnipuMBynKdvX/cqk254hoWyDdSrQLc89+5pT/AMiAV01VlGcSUgtSC4fPT7NL7VwSU+IOrY8vYrB6/KQBDV45/gv5NdYNTe8gGXRaBH4gTVTBBRdTczuQG6ghS1ja7w0oa5n7egs+r+ntQhxaoZFRuxqcCnLFLkvg1Fd0/J6J8bgrXNgR1GDieG5E6gSzsUaTEZ8S3FHVveqItjr7NUmBKtACZGTIEyOMOH4R3ufMjewYy2thVdiWdtbZCKXVaCPRjNA8kddJ1vKEP9XqIe+59jGP4o1bOU1QFd+yxeY7ttgUAN1nvcIyN2jpd7gLi2OZxQ4hUcNL9NEJwrsX4OHYy9XC3scQ4lWsGifi52j66pswz94/1sCAk4AlAZJlevpHY8qVAY7uibwMCqpG9BHQCt7XLRPCKwl+2hAy7oJAVuqVqKMbJ/q6o9zMMJpydZNwL+oVb4OIGAcl+oMbSzT2DxTqDr1oYeBpFy6Mb/ONbx74xBm54PHqJN7XWLxaHgzvSKFSzglVap8GZbyUqt8upSIdwZdJW7Me4BlQHIRRXghmTYqlVx64FSKbfpXUDK0BhDaJStvLjVeWJokOG3rHizwq1Kfrcu1PGVP9bz5c6DSCAjDUjeG9HApXKsoBC8dtpHKzcaWowyoN4CprvXVlkWsrFTGiHto6C38uJmQ2qWBVKKTWL7yqZABoVYN2DmTxb88BeBQl+zJo/ojA9r+QCdyHDgQ+ihTOaUvGt/PonBS18WOWfLJjFT/QrEFmR4IFIASQR0ofpWGjMDXYFVgGikHPMJBAJ6Yl0HXawIMS0u/tw4rle84oEEwLev2a74C5VwJk0oi0FZF+r/ANHI1sBfAByghIr6LZYNIQKnAFSG1COILvbroBvBVk9fk17E9uN4n75mP4tgKv4ih+urHnjNZGVY67/4m751SxsW1yGuB7mFCdiLbf7kO9+VEBnQGJkJYqKEKE90RgIIQwl94crvm6Ct6YFLsR0FOqwQcV9UWjZZMGTriCmhQ4n95Cd/a6m2v9V5gMPfGtaA2Oc73vGutAp887e8NDNIvHL5XMMTG9MhxyvKEvaDUG8//OGPJITH9YjyhRIc5yzKFt9FByPU38hn+9FlOYjz/N/+29/ksnipY7a3UMIDhqMj9U/+aU0C8WtrnTi3ZWep2d4YPXjop382g/5i9rTIv8tfWCdilrS4N0NFZlQBJRvIremtC3R9Sl+eT0DXZ0Lk+ZxZCavTyjNcwFz1TVoe4nnWCFTVDw665cnHxzsgrLpKo1SAZNZjAt2so5Rfl7y9pbztSjJgW3YC2r1SKWnzr4NutQm0U1nv2uhVQVa155S/PLdYF2rdFkBSgcW6prYGMUhwDQfEcRJPAjjdpugGLLYyncckv7JEjBF+JliOtqWtgVIIASXniM26YKPPtymQDrqpsNq2aesAxmvWBaAN8GtFVyzzdwXdhkpT0j0QzGGx/a+IcgJKV4i9nPBWK75qM12ULCCWN1jWBc6/wyzwDgvuoDt5jbOMB+jGOiw/oKvCDIRMUuEsMA+UVq4NTw4/YHbgocBhi6IT6BKV2qRuoDsUblGR9D4ph8rSyrJAFMikRzdDIjzUKLo1fD2/Ay+V2Jv1R/lULyiBcKwLgCaAT290g3JdzLF+yCtKpyBunr4RJnVGPtzWy+RGIhqUHmJHdAK6sT/dRD6LDOowoDueXaVyExyjVvYNlWA8nqf2bTM8kZUVQWWAtCfVnkrsVtBlCET3E8Myray2qq7efVe4VVnS8HQ5VIGiyBDZW9dA17pB12wLqvhRNrIyV8cqvss5wht098ZsFJxSZh10aVAJOCnfniKypepwz2XDd8UTmEOfaWFQzlNlJCj1aUA3gs3C6/e6lXvW/0Jle9dKMxbDzqFsRUoxnygilo00VgEN7gcN+AUMBnTLmhDAFADzPSu7gP8F2P3Cux9eWQdefvPSl31nQmEMrYda+pJve9nNi77xm8o3u9aNjAT+F0P9kQ4tFMqvWUFRL1nrharneVpj2D/BKUF3cgAn6LZaWaDX3mCBVkwz7KBbmQhiWzX17bcsSwJ//2oBGIpvBaMV5AYwRrlQshN0V5YC1NJQLiN7AjlcY3sB6QGH0UGh7HFc/hfgHdkuImXbC5YK/+rXfH+m1goQDDiM4LjXLG9s+nZXOSL7AOrr87/+hQ26FXxmAXlSiANyKxhtOikx+UaUM2AwbAah2ibcLjgNVTQgOjzfz37O81dn6RsShkNVjfvpP/7Hv7iJSUGigxJ5jgPG/90KNIupeAPKf3+lHAuV/RfXMeAfDgtC2E4iOCzsBOG5/hf/8l+uaUB/dcH0OzOdWpznOOZQYWPfYaeI/ZI54UMLdPG94zFO7/h6FiJALbYdf7GNsDVEhg7+4nzFyEGci0qxVnYfMqck6KrzSQfyBN0OJpVy6SM3nVUlPfgFmQ66ZWMYZRcoTjV53Rtd18qj69souGSymfIIA17EKgCf1HOj6GqSCQkIDrrUs3Tw27oADKtNBE5ot1u5VftNe5oBdqGkRvtloEvbk4zRbYZGAlOckFhiXmAXZgArhBnOFcAUy26gq3JgyzvjVArEa7i+LQLaNwKfA+bu0R2hDWhEpWyukKIZ24p2muxMDsU+uop1AbDGnjhwJ2EugI4YqkMcdPGQTAS5P3UigOssc6dylapqtgWH/E3sVPuHvRFl+gTQFkPV3vpxtporgc056gJkJaz6foYph50Y6S5umpgujmMHXamLrcwaqG6Kbly47J3cAXSh9T55ivYPBTGHXQSduhmg+bpJ6oJygaB6ejNAd4OuKdEN5alKWhCbwLK3mRd+DOlUIq0iN9QCgoIkTjzAr5ulT7BJ/905AGatF93nmJ6N1OPL495nXuOC5sOT+XMnwXNVRDNckA9p9pxtiOaK2jvWBXrd5cfCKzUVy0Rn9n50HqviZJjrAF09aF0x2cPiPcexElQlifcMtQD/2llhXYBuK7qVqza22x4ene9RdEmOPopDD+Glyj/pe1D8K0DMQbfgtBTbquSjzD0cGt4/eWIJKGurAopuNGArwIVUYe0JzCFNDXGaVxcrQPkJAd0abg3QPb26G1Fd+RAwErAQAOCpsGKouVM3SdV1GwLZCN7xkwOc5+YDCOMVsBqvAJwAqBe8aAHvAoufXiBz/kW0/V8vYD4nIoiyBdRl8FaA7oIj/gLUEmw1bL+lGBMYv35Bzga6Aa8Cx1g+grEadNcMZW4HCGUY0A1wb9Bd4PcMQDeWCeVUacEC4PgL1TKCuFBew9P7sY99IsEwUmfFUH3AWYBfvP/hv/k3AsY/yM/haQ5QBnRDpQwADngLNTOsHZEhI4bwQ6EN/2vknH31q78/z0uoxWRdCIB/+ZpO+bd/53cSIlFuQ8UNMPy95XeNWcji+gdMvupVr13l+4MMHIvfAmBT/c0Z4GpWuHiFCvvP1ghCBJvFqEIEo7VSuzoUofSGeh12hjg3EUQWgB/2mX+xjh+F/cGVQi3KTy7csOBEGX/xl3755h0r0wejJN0Ji2mMpcRGIOUHVkq831j7wJYTFobIyPDxj38yL0ccI50iQLUyVSjIszub9VxjXUjIFWDSKXXQJWBtRm+wJKkDSxYHeX6pM+gEE5iMJaK8vcqle4BuKVjVca9RKvLuMuVvWRfoWFf8QH0GdMe6wDB/QRR1YIKmw3G2f9XGXIIuii51oHKeR9twjPa5ZaEzMwC6ai9pTxKSkiMmjgR4Rb3drQs2YYTq4hxdtHbQ1UTauVZ0Y3/RZqmNd3Dt0V4tA1h6loatTQugVFvabXcKN6Zo6tyQdQHewbrgHAM3OOg2M5iqjiA1o+86pgTPgkEC7oDQHTIvLRB1ziZ+ZoBdMT+H7YFYml5PvNXchSqtTkALexK2uvPRQlhZJNxbTEdvOkHGfXEf6RpeAd0CTW70mRFkIukg8FzGQLVuPkGOlM8xBe+gu/UwclnvWRnoolBqP6222U3IidwgUeBIjwzvZ8vtKLPAoaCmb8AL0B0PKT1aenLeY0JVnoss8FTvZXrF2p6BLtv1G4R9bD1ODX/kRBHLwO7KOA8wlQP2A7Il7JBYALyDbn2OHIZVjsk84JUDFQsjAB7c0NcICNbwiCu6Cb2rEsqHa7NdmNFd91JWNFHZoixQYan3nY1FerHMkrKWYXrd8nNz/UrxZphvG4GIe0DqdTce8v4yHJffy4PnAWQVLDagG2XFTpBD9+Hvy6CxCUZj2BM4rs9laeiGVUE3lQKpALa8hAqkkdcWuI11Y1iX9EmRZcA9uCdQ/tc1NBxQUUFjT01Q4i/Utkisn/tN20LtE9DdZ9p66s2bf+zHe6rVu4F1/E46qSh7KLModretG0Po4SkGFHNY/yd/qhf/4dfPBBChzvKKcmM5+LoFyeEfTcXvD/+wwTWB/QDdUCULqCtzQ9oJYpa3BbHfavl2Qx2PbAmZo7ZBt2ZuixfKbkB7QO3kvC07QQBq7CtAL2A3IDE+B9SHhSSG4QPowxIRZXha7GuVK4LSYp04jwGLofhGsFasF//HvsJbG7AYQVoFuhX0FgAb0+pGporYfsBrZCf4veWfjWCu+BwKdOwn0ogFOAeUhzc6/o/3CFoL5TcAFBU4PocqHAFgYTEIK0Moz3iO43OMEoRy/zd/87dLEf7LLH8otwGwcX7jXIelJc5X2GIC6EPZZhrggG3uSWa0w1IT93Co2V+/ZgEMxTmCFyMw7v3rvo7P8RcjDuEJjswMX7dmzatnRbmH5Q+fDCd6rqMDGSn5Ml6hRoEINkUR5p3nuDM3dH2hURyN6LRynB3kyaOb2+66oALZUqlVG7XVRT3ipJGtAF4sWarbPdsDWSCyTsV/m8vXetkeZFCtAtbuVO+actsjhqs+ZyQtviu4k3iFTY4RTL5XG+hiSQ/xC6wQbfAwI7QQO0J7FO0WyyT8Hx7dsUAc1gUB/JZZIr6jbZL4tnl049j0/e7pHUtme2Gl6lZbNFMeA6RxPfDoIuwAdDBFD+Or48E5n+0V2CF4wV7FJxY8JhGwg9Wk9rIfRufhCiC+j133oZeLdpyyxLuD9Ixomxh3Abp1XmA2eA4O4dw16Eq89JH3ZJdtGwXsDbr4cwAqPjMlnQ+vc1CtyqJUCkRmWZf31UNaF5ygr1FX95yvm6IrIM2T31BWsDIQq56Gbjqn/F5GoMNFb4VavYzqobq1AZvCzNI23pPpKfTFvjjBpgTrwXavz6jmgDCeZSqHOkZ6MOf/ZFvwrBbeS3TQdbgt4B2j/4AuPl0DXSXsvlB0u3Mjk3uqxMqHGxAZDxWjA9wbpj4ULFblTadpyj49ThTePfWN9cwNdF15LTB20LXrqnKiWpzDf91RU3k9QDGAlIqVABaGMX34k3RnwOfm0c00RqhElcmhGlUFr/B/KD5qfOc9GuQCXaAzZ0bTsG03zoJSrAYxU1qophEEFCpbvP7pP/tnmZ3hhS/65s63+t5fnGlqAwgidyv+R/ZX7xVYxkxeTPIQZQnLwXvWdLcBazGs/VcrJVSkhYpXwE29/ku+R7qniPTPWbsW3LzkW78986X+8YKzyIUa/szYRoDY69/wxl6OLAkBRW998O1r2PxPC5I0RF/D9oLTBZ4RgMQ6AZZh3wiVMZRFwLUA6+k3L37xt3b5AvqwGeT6BrpxnAGDb1kdiZzYYUEkoBveY6YoTs/p2mcEWgUgxjoBp2HniN+e9vTn5O+hbge4BswFNAZUhof1rW97+1KwXyC/cc10FqAb+4y0ZKGMhwIcym4AY6iqAaChbocPNl7xOTowYa947vO+Pm0rv/mbBaShcMay8R7Lxnsowm9Z+Wkj8Oy7l/0kUn0FcEa5A8Dj2obCHB2FP1hAGvsmaC2+C7COAL0/W57YyHwQCm96stdxRoaPKGP4eaMDEPuKaxGdqgwOVAaMAPO4F6LspJSLGfCis/NWdcyYtGT3jk9H7IXLIhP+ZlThVHLXsUSQGunQ4li+4YXfuINuP5NlA8Kvi1pb0DmjL90RZD1BKlODo3zWu7I2yLPbQWzZQa0JI+LVanFalgp2C9wGSiPji4sHeH+3zrr8wQWvEyBX6pkEBIF7wa1lNXIFzxVRq3dRFqv+L8Ab0CXnuYKklo2h7WOxPOukcEH7MZNO+Igi8NL1tcSO+TzgyndZV7dHV3E1CbRj16vtzoinq67bcLvUUiwhQOauvjIaPX7lVlZ7FPwE3fpMOz9pza5lQBiI9fRiA5zTBl8ouqZSc63GezuKbG/LGKFBV+08Ys8Jug7mCbouwgUD0VlocVEpbEOl1ci42w5Y/irotjhWI7Kw5Am6yYlr2QZdh89Y6V5At3sJBoulkOmlk3WePJfdGZ5GSvfeBIXvoQM9hPR4TiUQ2wMqXQendfnqYewy5oMs0FzL5INuvQRuiPbl0lvS9vy4cnicnprdJD7ED5wDzHme1JtF4UbBHaguqZ4Hi5spZ0PTi05AHpuU4wo4O60LY87uCFp1Hjz9Cv4bZqZxldhvqlSLswLcldQNdDln3YsvkB0f1+QGphL06zBDThoy6QqybuBYh2jmLdAiGgv53OrajLLOiAVRy8BtKyYMBdKwrG0R2JaVZ2ybdF8C9hN04xzUjF6V7SAU3U43JgWnLAcDupNdoZRhT0KfywKwUlhrmHWmPXUwboWrFeAAvkqDFuerZyBbv8eMXiTjRx4N6OoZzqIRloLMMV2CbpUlh4NTyXz6zbNWbtnnrgCrCLJ6zvOev4Konp8Kcf3/dTfPWwFyAXmxTbywOcS+oDOC50J9ffaaCCDVQE3ogEqaUfxr3WetGcUC4AhimqwLVY7yXGqGMPlrCdh69ipX/J8KKWrsWib2/bxVvpii2AO82EeAbAa5CagDhgNsc7sLsB10AeV4D4/r166Arq9/wYtzJrTYRpS99l3qb4Dv09Z3sexzn/d1ua3cnwLravuVgizKGcplWDmivKEqp7Ism8YzVoBcnL/YTkyoEMFkobqHHzcAEiCOGdA+tiwFAb4xpP9DSxmPYwnVN6wH4UEOG0XAbIB6qrgBycc2EpKXFSEyMITtgOC097z3F7tDEfuKzkt0YsizGwptfB8TlzAzGrlzA5TDWhH5b0MNDoCOzgAjC3HOAN2wrFQe53nFPRdljpRmUY7oRJCijns9/MURhEg2Ep6pHB0hA4OeG4dWAkNJ08czV376ysvbM6yZt5Z0YnSEc0RK9QmjYR2kFtAsBbh8uLIfSHWdDv5M9evwS3m7ztVxtPKnESogmjoU6EVkiDoPGGXEEbCmzUQBdNBl+B3wyrYUYQS47XakgBeYzLSUjOJp5O+eQTcBlwBzCTGCY0Y5N1hllDDVz926MCPGshv0aK/gWTDlFodmAUEYPl3a+YHtmX0VOyJD+Bv8HRbQS9AdK8SMGo/3mHbbR5QdYF2JhSeqjBLejKEIXDxB17cRxxKg20JjsM6m4I9rALHLg8fgJs5FcpKuCzPBjvNgWADQbXvEWi/uwQvQbUVXBWtF14YQUHTHfqCeRqh5egCBowFXWReyx1f2hlF0639m6nBwc+BrM/gJ0OotcFIbdNVTGsm/eloNukBYq46u/E15e30t796Rtg34kIRu/Lw4DbITXNagqwc9PwO9rBvnWz0gejQ8LNwYA7rTWx0bwqSD4abhus1DKOvC0ett0FVFw7BQKeqTR7EqOIGuVVrjZZ1e+wz51LGiMPSNzDnIYRnP61sqQ70KMluNSNCd9DkNuuqhp+q6XgQecp430JUfjeEuDz6rwI66VyPdT1bsKsNAaynTHrmN+lLgVzaCBN1s0EqBvQhgibJGoyofLo0nQ5oJ7TnEOtYFGnSC3doHrOHXnuRBaZOevcAzQDMA8tte9h2ZgSAg4vTBhncyt5llF0hvUF05SHMofwVeFVACukpbJQgk60HndF0pwXoqXVkCUHTJfEBaMfyaDrphQSjgrCCygOLKqlDBacys5dkXyNubQJowWNPqkolh1NhQbWu7gCfZApjZqz476JZvt0FX2STIntCgq7Re0UGo9WMfz2zQZTm2U+e29uUgDEhPEF0ddwAz6jD5dCsATJkY1jkKJTOUXFTegNWA1lDMwyMcNoYI5orzEvaKSIsWyvMrVnaFH11BfDHTWCjDoTSHHSBeoco+svywYTWI4MZML7aU3ABkXgGasc04tlg/gDhAOOwKH14qd6jFodoGSGeg3Fr23Q+/Z9kNHlmq7gdS8cUPHZkTQsn2iUEadMnwETPjHbPjvW5llvCsHac9JtOPfcd3d05hUoxdgu74YLOTms9sBZLV57IouZ1h0g4qv65GdHheT9CN+tf9/qi7DbrRAV/1UVkYlDEhOvwxGqTOOZ33Cl7TSFQquqXqtngj1ZNhftS6Ad3LehfQrZErhI7JorQput0Gj0fUBRLq9R4RRDSR2ouFLG0Wsj7QxhGoxigbwWXMNkdgdbV/sl4ibAm4XfChnQGWUAMHugqCt7ZsE73U3tNuSzmm3cYqkO2XxCsHUJbzIXv+3zMiMKHXbvnMYzQxDk4pnkJxHzj3bAowAQFsrmaPLcNsmAhpEpBOyK3guwJdD+Jz0bJjrdSJcSuGB/axDUap4Z7eLip9XhtZNJrtapa7w7owgWDAwfTI6gI7LLXiiVqm4X/UYAdEoC8uJqCbF0BADeiO6jnBYtD59BzHw1vbmGGTAdkZEkDp5eJ5MNxsGx+L4M1u4PM43C8LyKPoAr6ozT0krwtAL6kjD1tpVFAUD4FJ/dxoAC7XIDoG+7CC+23pORck9k0kY/w8aJUnd4dZBaMxtXH3wienYZ1zsy7Y0FaCrnq9VGCdVmat08No4Z+ym7xGAnSzCqqxx6AC1DUcz1crurJLUEHH+cVe4PA/ajETP1SKHk8bliqCGpEsq5QBIqizIULRVbBINXSa6z4ak7VMwG0puTvonp4+4LZBV6pLQNEGuqEQC4QJpAEwaexpdMteUJAdMBhwEtHooaT97QoGu/YXv8VQLxNg9DakTCf85v+lVJdnFdCtfKp4MVt5jfRP8f2W0mqmn63gMawFqKSTc7fTeknRJXqfoDC8tQApoJv7V+aBzF2rIfFQRxMclW82A8fCuxqKrFRTsjC4GuugS0DXqNdlXcD/WirsKKuUFW/zBIQtQM4gtoLVXE7reYaHUpANvhU81xC+1k/QlTpMPl+2+YKlIIdfNm0NC249s0J8F/lzwyYQE1rUuamy+Lt3Dny2OK5zwGdsNxTdTC+2FNoA2vguYJhz8Nu//btpYwk1N4INA4YDkn/rt34nrTRct1iXDlgorqEev+99788As0dW5gafgKRtPALdttbESIDuvzgun4nv2v0f3t0HVuAeHUQUXnzzdFIZjQJ0y5qktGQauWF0pm1JGvkhTaF3ZPHuZ/qxqItixMgU5AJdTS2MheFQdqOeKmuFph9WXQpkV2d9rAvdpgG67cs1j64EA8CubW8SQBJ0pfRWPW3WhchQ43AV7KDhZkAXdbfbkfQMj3iyKbqyDlx4dAXxbKv4YoLhxqNro7dqDwFb2j6Or0BX9kT5cJtLuo2amKVtuB2gZnRXEJYKZw7Pe/zRtMtpXegR2rEsNkBK0d3EvBZ95AnWvhHSGNH2UfLmE293KWOUAUtAWzVG0UWAxPaZDHEn0D2tC30/jFIPmMJFA+fjN74Kujofzo/uDnDm20C3/ZD0wPLGtZnLDPw2RdBUUwib4ZfTB8sNgexeQ+3yaeBh0T6noEcZBLVcRIYA/AJWb3bSTHDyGD6hF3z2GnI9KbDsf7ZfNx89pv3mHlkdcN5uMht+md7VWCZKlhfkNehO+rNWdPXwALou4dNjdaibB7gqkHyQcy7t8egyNHRn0AWWJ0F5D0EJcOtzwbWDLgEGVJZ0buj1X4JuRfz2jDytFFtKGinweLhqfzMZBJ2qBt34XfdvBVxMrzyVDL2wLtTQ2ZHGh+AQ7cutCjSI1bjVNL1Rpp5OVIoP0HqCLuvxng3bWr9y0JJ1oTx8DrooxtUw80JtrfyiAaWRrutOf5EFITyh37QyDjCTWTbeHYHONku1Zb+ltAaAaeKAUHnJ3SrlNUEjQF/QifpbExZMCrAempclIJXPUG0BUgWLlWo72Q9cvQSCO1NClquGtoG2BF2BHKpozmomwAygBDz73dTiSH9VVoIKXiNNWtkGSumN/9Oju8peU/hWABsA1v5dKcEVyFbKaym6BeJPjZnM9CLLRG3TwDi2re2wbsF87TMmDwkbSqi4ZFcoT+4nMgNC+IZD6Y00cKWmjgoMbAOpPWOblHjgP445QDrsAZF6LJTdSD+W6caW1SB8saHEP30dW8xUFhAb0/aGqhtWggieC8925i2O+2aVIYA5AJwsEv9ubZe/UIjr3A/Ikk6t71uNOAC6dMIicwXq8G3PRMyel4FnaV2ojqrbjhKkUG17xKPSkk2HczKlZH2QKmylFWREZ1N05dG9AF0LVMsANfl8x8JQo04DumSFqDoOXzD/9ygXileD7szomCNuav/PlI3ZdghImZgiR9JYPkdsK1MEbTBiFJCWbatGiLd2pH2XxMeMhziWj/26dSFHGE/QXdsuBbu4Yqa3V3vbiu6Mgno7yT4SuGmLjX1OtoETBgIZoh/4bFU2hCMHXV0DLADTnldA1ulbZbmxV8r7DIOZ4Bj7IZEA5x1u8xFpHzFvCwEdgcO60MCpc9sin47Jt5uKboKuRvtbuBNHpZCl7B7GIyUMOmvJuilRjfMymReqw8Eog9tOuCbRwbCsC2MMLktBQV8fnF1sh7wNhr3wSPxHDyfWTdDUCUj1VzcUOWK3B8LAFyBE/e19S11sWTwvhGR9g9O8+PGwaLi6LQQcJyqlypa9LPlAR3L3QLiJKHVVmf1wHO4zGtCdiE0qAlfM6SQ4CPrwQAajSZ1laIahnLIY6IFTb+0SdOfBZ2iLIZpr1gWyFmSF1lYCU78BXVU0KLrdyZBSW5VPeXQzU0L3fKti5ubnxi3FYK8YC2rXd6pw6bhUIAUJwiuzQk6riWKdZRMQ274Y7mOYD2vFRDvX8B/5bbFLoLpkgyivrUdSN+iqwXTArQCWUkYbdPlfoFv+0oLbskdo+Zz6tBTUUJIAXRRcZh5j0oaAHILAQtUNj2RE8wdMRDBXTF7AjFAdfKZ0TZWyqfbrkNvqbYJuQLXKIxVtJmsI0JWiq99yWNmGllGBEzwFyA6zQGrs0xVc4BL1se0IBrIx1J9ZFwSHF0qr1NfKMVuQV+m7ahaxsjeUCoztAIgFdAsqDXQFzgmlUpB76t113Begiwe3wVegu/YZ66GmAvUFzwXb/A6s4+mN75/17OfdxExwkVUjsm+85ccfzCmbI4NDBCe+ewHue9/7yzlzXtsjBLp0YLqDsI6PnLX4aEflXTPUvf0dmS83thlZFuIV/0e2hMiDGx2OOEexTKYuW1ki/igzQ/zbDHAL33CUkRnt3vijb17WiF/NdGVhaQhfbkB5fB9WCodu/OM8LwRMxj7jfsLLzjPzA2vCiyhD+NIjIDFf8f96hTc4fgvwd0UX0CVrQT/zZu0pyFYe3rQozWQvA7pM5b188tk5lZUprUs181qNGNX3TPgwgXDqgHdwmvLjrnV8GYQFty6g6MZyo+iOjayy4FSdPvU8ooDEI0EFQWuAqrcLUb+T1rHbL40Gj41gvLjtyU0Arv27lQF7BDEZM1o4sESMCUIL5bkm/GDBG3FHgWxSOVk3fvdcs4g0eHbbJmDq5wiGA3hwio/MOuM06Erso50/g7toKxt0xS1xXkb1HCXU8/DCWCyLfQKw3AAcVV3QSYBcK7gmym2gb9yER7cZqztCBr6Arhil70mYRdtDCWfUPCwRm9OADokEqlGH61y0R3eU1bEAoG66PA1p981rJI9ixkPSN4OBLj2A+wW37bGgl6Mhke4dCa6958AQifd2UDO7J6De4ii58pVqP94r9G3jceGi+0Pq2/Lf50LOPripetunoqtybMupYzD7mZ4NcMy1oFwMBd1nYBv/A7r8370kKqnsAWo5KbAOxhnIZhAd2ylfq6YBjvVzP/OZ650dmbyBLWuF1m3VWR2NrAztXJCvkf1XOjFViL0/cjwSgTq5buO4c1Yg3TeAbvrG1YnpLAqhdpiaG/dkBZwR7FGqRKb+SmUkGpJKYxbniqAuvLkJtXj2CPgSHNYwZalCgGvBIwA5/1fAWHUCsmE+QBd4xhZRw/MDoczuxNBuAmkomg3GBdb52dYrCJCKq7I9KT7HDFQ5C1VtJ1/aFlkXUM18OPm0LqRaCASzPuCr91AmUVtL0QTk5MVdkFgq4vhiE+x8KD/XGVWWsuV3gCQ2gYBZZUhIUNR24h0lthRaps6t/zOATIpuZVUoJRZFF+is4LJQd0thTb/yOoanr4AzfMbxf6nJNRlFfB5lOGwV9arzUv5kyoZqG59jG6GYhgd5XrNeHHvm+o3zo/OQ21THos7hrhYTfIcHOZX7yFEslb3OS23PFWifkKLvg3WNOY91HJq1Lf3WY8tA+e9OjVle8l7PDlKNBuDdLq+6RhW4d3VPXQPdDFpT5w1LTT1nMTPa+Opjmdhuj9g4lMZv6nDyLLM8ncO2HaneIMCMOoDnCD9uTvmtOonRqOzgpnqsiSckEKSNqhXb8uBmnYTlSnV1flZ9TMe9LBIl2CDC1G81ipijXNFGMxRuosDACJMWlKKGJSzXF+gCn6WSWvtoai71O0HHtCksP+LNWl/b6WWs7fJgahRd1sW6F+1JljVfEe8x/zPyiKKL6BMjoBuPsA0JSbQ1tNEN4WqDxr4xQde08fBBK6GpaGvSKLMY+vKMFDufNTOwT71vjKR2NlVe7Yd3F/z6WLPdLUaYHMG739Z5idFxtnWCLuVtJrq4p0o0bOA2ywj7r/tT3l8dA2XwTlD/rw5IfE5F926g2wdvoMRwegMuwAKYbIBi6TbWchegawXqk6eD3oYPBHQnaPdJ5mE64To+C+wSxFB0T5Duh3/K63DpN/wGpOoF+7nYbiJ6yD7EoPL0ctdA1zsSGrrxB2tAt3rgPMQDuiPrJ6w66ALEa7uVNksqqaB0A904r3nuBbbmtQIgB3QrvRjLPi4VdSwqqmjid3r9eIW6gq1Km8qxe+r6nU5K90RX+btSXutFA5CVTdxnGl5EsY6eHtBL+XY1twCWocCelUgVfzUk1SDQ+DDNb6ozajxpuNqjK8WXLAs5ZHkErHRjmZAr60OD7lJ6TNEt6FSDjyUAaKWxBhCi4Q7Q7SwB1ciH0ukqbeUjlUWhgbbWzQZcsIz62h5dFF3bh0MuoIlflnKMIlzQc+GHFXQBUw2WmeZrZijz388h/afI1xrH5crnQF1M7FCAGC++JyAMuGxVVYFqAaMJZ1mOesXkDwWz4buVdSH+d9Bdy8c68TvHUEFk4+dlhrUB6AJdwLjgeZReoBe4nveatAJLRCz3jJWHN48lZm6Tgr2D7nQQ5vjqO1TsTLGma16WhuqMdIdAHZH8vPbTgL7W885A3SOaoU2dgEwPlwBbHau8V3Qft9Kv+30H3ZkBDw95b/tQdPP+ZaQk91EWiLz3E2zJZFKd0lSJNSLTPnw9u93pE1wP6GqUJuxH6uBWTu8aFQJ0q+NQE74QbHoBup2ZJQK/amQJ+E2/rz5351sgTP02E1xUFpqeilgd/6i3y2pQIB31aqnAEyVPnYs9AVV2YnHIblBxG2yPNukrV1qxAmvBjEQLF8MqU4+Cow9BxUUTjovvsm6XkIRC26AbbYaprQQyA3A9gmn8UXl469jj1aBr4NojpsAg7BPrqB0H2gC85hiNNDs/OMj6/60m3yaMre+dT5w/sC7ASrw76G4in7NQXx8pooL9ET1NfBLH9L7tXH7FVz6uz+MF6Oqabd+f5+YA9qsip5hv4JaUdnioywIyoKsbu3sMoue4SZ3yt96I3UStpnLx7YI7KAOafZPZfssycWkaR9pPtdiWHwV3ogE3KG+/sXqTKu9khjA/CDepvZ/qapZZ5Tt/qx7tPMgXoNsVh5bRds7lzmNiP7H97lzEA5iAWPOIN1Tq/3oQq8fK9hx0kfZZjvyw0/PV1Ig6HnrbeFizTDoX3RMH1Nf3VJRcK3r8VHZZNqmnWZnkfviuQDO+czWXoTIg1K8FwY2lyNb6qLupkqDoqmwcR5VjptWMDlg0dgSi0TCh9KaqIuVjbAj1HQEsE5Q2Kbzyd/n8Uu1JZciyKOg7fIFEYVcDXA0vs5+5P9ZTLPUEEmp08b82YAZEoHqlIlZDuhW9XsFafPb0TJ01AjVWCiDL4ovNdQQp5Z0cjy1w3O/sU8sRaU8WhFMxBNZin9gbyLiAeuvveErx98Y5C+hL1VNAWios3z1H2Q9KWWzQbd+sUnwpo0KlBCuoxRIxoFsgmp9TOa11czllWeC3+C7BNn6PbYWi29tWVgnb1vh45cG1bQPUDrp5jmyZhGqp03Eecva29MSWxeI8lyi6qXoD8mlBsIwVDbqVFq6zYKxr29YPwW9sozzStU+uewf/abvcR+21ltodsDtBjbrH1jp978V9FaMP7f+uDhH3eAdKOujmfS24TutBrR/qbjyncQ4CdBOAw7erSWEyk4rU33imC5DN1x7PdNYL8vcKdCtrSo3g0LlkNsSsX9SpBogLTGtEKOtVjTKh8M4MjTXixKQ1W2dd9V+qu6qLvN7uka/1G6Db7Vy0JbG+Xl7vuhpbmWYkiGj0q4OWvF339l1tRtXHMeHPAbpHG1OCHLOezb5oT2jvKEu2IWwTcN1gm9HPPcje261sY30d45ttOWMNZxhfJrfTYpx8qMfnDXTPfautZDu07ScoN6SjDts7PHdtnWaag8HCKnCVhXRO2R/nKaE6lFdAV+39tg19h0ob5XL7p5/z/E33oYO7n0+WaY+usU/8lqDLRlKmRhJOTwWRghrqls9iekQA5EQg4lHp4CpR+pyMSY0x+51ccm5D8OFwfDxE2Z03DUMGQFMs74DsF2FAt3qg9ZunDfGIyhre8WEc/i9VsX7raH47wft2xzdMjzjW27NaVI+apNVzI9c543v8NQnJBrr5vw2t8D/lrOEZvVTOVAlM0c1rktdsvDRbpRhAr8qjbCrmoZVK0NYQvDy6qVEE+D3VV12nHXTLK1Y96wlC2yvcChhjvQweU1Qxvm98dARkEDSxgy5BZ7V++twSZkvliEau/7ffqgEjSCUaQoPS/H58tJWPs4JaBlzLk4dPN7/XMCnBKmxzpvmlIS4Fq72IAsdcX/vwQK8TNEm0n9CcilaBRwGD3uX/JVNAbLsUtpklrIKVyk8KRDu0dsqvUDK1D1/efbykwcKHmoogtgSsAxrmDihEZXVPan9n1oPYXpStABCgLY8rn2NIP3LOZgYJ5akFKhOaycqQYFvWhfL61nbI3EDasAZDlNPO6rDWXfuJV3qA1/HF/2RViO8yc4JStvW2lU2BYwXEq1zav5ThWL+AshTmAd0pd+5XyzfMymPs55AOQ2eREKwDq719AfOZCm0D3VC9+zzIqiBl3s913ku6x8Z7XcCKkpz3nTpcdc0Eq1JIuY/JtOGduhpRWPAqqMVOw/NZ97ugVapy1iN63vDle75eRjwKdPHMB+jqGZfflg4szzye5y3VINYE2aAqJ2+BcdVvqpfSykA9VQFonalBnXE66OWXLUU3g1zTuqDJIQIyo97LQLk1NXBaD5hCeNq2Ad2qd3vqYLV9BIUlKAvOs/5e2+822Uc+vb2VUp2go++rXZm4DdouRI32INsIXLUVE4yWbYi+Iy3ktNnYF2o0lBHMaXcYAa1MCd1mNwOJF7IdtXbcFd0sP+rwsNJAXG0DTgAEz+Cx4gBew2LwQXNOg2ddt/EBT3oxhDVgdI7NRt0TdOdFJobmmY2VYKCJ+eE4ApDrOmmmvWaKSY2XHZz1ffqAL9RuHYdGkBlBqO0Ptw0zlRDpDMh5KNBVj6oumHowB+g6lA6MKsWU4KpM0jpBQI6gaRvalv8HP0+qehiqG7I4GAdRTUTR8DxKLTe+HyQX87yZcmjDPEgXF1AXebshj5vIb4SGLd30dcEmunCUaO8Y1HnqdB66IWKf3TvJG7wU4EvQldcmQXcyFTToYs+IGx7vswCVmWBK0R1fapZZ4NxQHBWZKp2t553Lzm+c//F4VdRtw6juh+qVVwWYFfABukQTA6VzLtVBkuLh55RrSTQ0FXV6YwNOZTfI6yRbBfcA2R/IvVjBZPhz8cbJJ6fGAAV3cuLuoFvqLaBreTZTuUWhVa7N9ukW6HpgWkAj2RTa9pDKUmUTKDiemaCI4s5hX/O/xrIMA9PoYyno6HXznOZ3EeSmbZAtgCAkJmJI4JCvlXUadIHSVNQqkr6gSjlsBSqdbSFABqVQCl6l7NIwfQ/fKw2Xvu8gLCm2UZ4BQOXWzQCwsghMCq5SKZ/+jOcu7+p6baBbEFpAVyDZqmtaAApO+X6sABPElmnDBLq13wLjhtuE2mevbT2vJoAIsI9j0HrMJFbLF1gXKCp12Xacta1cZgNdzkVlcojjJGcwSnJ1QGZmt4JOAXwo0gHAAlS80O2JNpAuq4WlbtPxEMyXSnnbNMrSkL8JYFHGJwhO94xl3djSnkWnQx0Pt8pUh0vZP7T9AV2eA0C3AJlnIeoLV2npEAZA0rHM51AAS+eO9IF0HBuKlwWJPNRYnDwItaCb/NpMTlEwmp1seYKxRNEBr4wPdMBlO4h6POCYUSfFGmC1irqvbVfy6FLXA88Z37CWyyw20QZq6Djr16Pe3UA3QQb7m8B5lYO6dtrX4AOBn9qsEpjKktHD/i2guHq7Z/QBgivDjRTnDXSx2w1oRtu4tX3RHqhNSPGI9s/EnFJ0r4HuiFwFWii/O9zO8Z5Ayyi0cvcbM8AwBKV5Gwjk0a7WyC4ZHiZu5TroDsyeoDsKL9cIjrO0cAiCJ+hK4BoBsMoTWRe2lKEunskes4PuCcuyjwh0x05DEgAA3mbJFbc2nwl8pegOdHDBUCiZlauGLDCoj8LpN/H0TAx4rWfAyR8yHxP7mS7CQRH1lt7BDO8bOBooupTu3g2Ad0DXrQsoumPC3wAY0G1ZH4vF9HpvtTaobN5B4P/OzNBQOL2b6eGUHWBTq0nFkhBc4J6+Vp3v7IGrUplgAPVS9UCjABOARX7aVmnVcbkVdOnYXAwnEQk8quuAMKBb6XbynsihCeWuVQXtFSkz8gDO9Oq5j3bQZbrMqnAddAFz7AplUVDAmdQSbAWouaV0EBCi1GGp0ErNFRRjXcghTEA37AGp5CqhvKA2o6vluSUHKH6/mMVrVFlmfVrKr3yBHWGeKm6pT/gOaTRRuHKIWJCL/7Ea/QooaotCNPYNuii3pUwFTLRai4cyG+gZOsY/m9PuSqVDKfRAI3ynrdoyhJ3vFWw1L3LTGujmMgVJzAKGUgsIDuhOyq5UdGOoXi9XSgO+AlwbdFGSgWzBKWnJYr+lwtYsZPkuJTY/Z7aGAk6CxADdAtlYfyD4mc8S6KYnWVCrKX4BzNwWsGnQCdCzn1SW5Q9GPaUjULaI53b6spmRrTJNANF0XDhe9/6eoJudEMBbHZWyaNR95xkncsIIQFcZMAp0yzLBfvueTRAuGHZLiwNyZZ2gAyWIJaNH3tPTwWLkotTiI0OI7meA1kdn4v5v761GXFoNzs5aBat1kKiC5Hpq7vV84udnpIb6ANDNPLpdp1THfPJ0F/DGs9igKxDe6qhch/SGqgPVwSeGAT9vLJdxEBIdSjWueq7qYVN0s46/BF3q66hTGzQlHkW9GsAN6PaslLIiwBIF0Jegiz1hH60shZe6n1FF4i+yvQN03UahNpB2kVHQEj0MdNMWICuD2SiIg+lR7FY795HeUiSLe0ZEG6slsOrD85wHB2mG5l3d9JHdHv5XORAIYQNXrAdex1Lp37kyekfQPRRUOiczeu+C5yQ0KNCdkfIZJZ77CV94n79TJJQI6qIo56u4cNKwltCKhXRAPZZr0IWWURi5WFxoNuJKJjDaQ+Mayt+U3QN0U9HjBm94ruH6DUqlZjbw2gm7CrrqGXaPR+tfgu4+e1uffANE75mcyq0PRQzY7jf3PqSgB6IVzYHrVpy3B6R6hwyVcPwJsuk5GjnfH8xMDXMBukqb0lGv6rXqgQaAPRhthnsqynVU23qI6Xlz3twzVR5cKcwo5nQM7PgBcyrWmmpYamtCOxXu9Hb94QKQN5tMDJlpKI8Ze9qKoO8HdMdz1gFneN+2yOpqgCqh+96IEFDGcGApteXVK1VYvj4FnhUIz2xjGXwi7x0Nb/lhHXSl6Gp72eApWAb4bAUrh0zV6B5+2lK8UFaroW/QVUAOWQESRjV7WeWy1UxmCceahewA3U71lKCrYCUgBgXXgKVA1yZASDVQnlcpdZnP1oKuQllE9awh81I3y3crtbaH66WgmtpcSmcN66PE8l2Aa6q0MQQvdXOG2U0VNYhthVhZEoDIgr9SisciUJaJ/D6sC+u3tECsdWO/FehVx5S/K9gNmGfWs9hnA7bKsgF3AraUXSnAfhwB2PhkC55nhjYAuf3EOncb6MprTN7fUdttcgzZG9x6kvsJ0FaZSI1WnRuC4/bMEmNbUCaOvDaj8qIEF+iWusuoBTl1UavbWtMWH2URIRhO1hsyllSGkoLhKKODrnc4UZIddPH7lgWqps7uDC2otGEfkC2CjnAuSx2zKboFsEwh3sFoUm+Z3IUANVIgMjJGTMGkRCyoTfFC7QIjYdSrWL9GFROYSJjAugBkENzt9Xbtw3OimypqdT2KX7UrtZ9sR8y6UP+XSJNg1DDEaOYEJANE2O9a+DEw7FgUwFzb79ztKLqh8soemG16WwPNyqiyMPTeYlzzioSzbgcHBN0yOu29UoUJ2AZga4Tb7ZiMhA8c2+i3AeOMTJfii1LM92zTR8BdlCM2aFfmd+bp36TupqKb1gWN6rbqOx0nYmHGejDn9dKC6kJrMRWg6x2BBt12FtRyDboNtqJ3l8aBR++pnD2OOTF4O0397V5Qkf+2Hd0Abl2oXg9AaHnXGppHot9U11xvctsi6/sQOqDtsN29oO6NjR+mrRgt189xNfyj2Fpvb+shCcKnN3dkddC2OS8+DR8XsUHXz5d5VwBdrgOKLpkWPKsCqcHKj1Tw6r93xWKgix+XHrQHo1Excd3KmsADvt5N+Z3zP1NRbqCbw2DV02dUwYch4rv09qpTVduufQ3o1vGgmvI9FQt+s8pRWcCZacRCicggkvLm+jAgPjr8ug66eHAr4jtA11VcZVjAtiCYZfixhjs1e1j+JkiONE5qmHs6Ujy+qLhSlAg4q32XZWKGcwWUBpatbpkP9xroFrSWB7IB1iwRKLR4d/FXzqQDpOliyl1Nn8twtbyWCS0ERgWwyO5AmiwUS+DJvafYD0atLWAE5PC7FuQVEKNCDvwuEE3QLXsB3l2m1EU1BpALas1OYL5dh29AN8AV0A2wJbNC7gewNUBO0DW1NJbJZdN+UYDKfga4S2FG/UVFBnRLieb4AWKC4KrD4J2AUb3LMuGKb/t/SWWWfmVP6Vb33GZ5COuC7CPAdPmy6x4hhVrnQpbqW/eGK77VYRsFeCYAKYVUGRjaGlOqMCMmOYoR9/16TnhGarTD7AzaRoFujaoQ0NYqqq1faqzAWIouoJuWh0wZWPVJ+e0LgEn5hwWKeqMU3fLlouyScxf1lWBYfLlRlwHU1FGVu1fq7qofPb3ZBeiGGCAl9E717iZqBYxJZfW4l7LDOegqBsZEL0bTqn0dX23bHc44EFnlcqj7Cuhih/N0ZKMkT5rKTdFFUAF0JRRVO+xZiup/4ld6OD6Pp9ryGfm2kWG4wLgFbmIkl33dBrozSi7Q7RiqYh0gdfy4rjRbrI2ds13pVSpRbWvigzRivY5hB10sFwJdOiUd51TnLoPRIoOFbC/baHbD73h3G2zpkHQAoMdaEedkI/EG1giP7QAQV12A7v/6v/6vN4++Hj0Hj94Dj94Dj94Dj94Dj94Dj94Dj94Dj94D/3e4B7asCy972ctuHn09eg7+n3wPxEP9/+Tjf/TYH33+H70HHr0HHr0HHr0H/u90DzTo4j31fGQeDNXe2h7CH+m8/JPlr7jmqXX5+rQatJRvWRfawCwfxvg/bEjcMhzU8IFFdOo3/CgMhbvf1X24Y5LeZ3s55XSGWcaD7Psc8zPncozsE5Q11oqZAYVhC4boGVqYz2X3IHtCRo/K05xWkPA8pYdXkn5nYtg9unmuZe7e0pBh5LfgM/dFEYw2qVvGM5VDTWY1yHOWtoPyXJHkuby7sq5oSI3hrT4uRWISHIfVYxv+0LDYdm5if7lNRSKnFUOJ0GVLqOmGFbgXy2o72AJiSCwe7ADd2M4//Pwvytfn/cMvyNc/jFd8l/9/4c3n6/daZj5//hfUettr/R6fY53P/4Iv3taN777gC9d36/t4r32s7elzLq9tsk+2E8t/Qf6ul/b7+fH9F33JesV7bTc/x/vximXj9UVf9JhcNv7/wvg/vv/8+H+tF2VZr/xf24p9xudYL96zvOwzt7F+++L6jVcsW69Zj22wbLzHK/ZT/z9Wr9pWLTev+PzFXxLL1Hq5fb7T/mL5L/6SL7354i+O1yybn/P7x+Z77WstG5/18s+zbduO748yaBuxPNtlv1FWL2/9PsdWv+3HM2XUupzHLqOWj/1Z2TlmP67434+tro3OnZW/r9VxDfo8a9la18qr6xP3whfbMnXt1nK6/l/4hXZfaB91XeseY/+5fb7ve0n36Lpfc/n+XvdwPGe6B2t7uj91T8d9nc+Q7n2eiXqu5vu6x+uZzPt7vXiu/Rms3+uZ51mc57ie+/7s9QB1gdUPtf2oL7yOqfpg6h/VRb3sF9187ud9ftYb7Cf+j+8+L7//gpvP/dx6r21XvfY5n/MPa5l/OL/F9/Hd53zuP8zvPyf/r/fYZv4fr7Uu3+c6a9lcfv1W/9d3sa1/wLJat/a59h/b1m+fG59j3fVd/b+2n7+tl8rD716GKqv2bWWN9Wq/9crtruXyO31P+eJ9lq/yx7L93Vr+2rb6PPTvOl9RjqMsXWZtN8sQ51/7zs86H32+KCvnycuhc9LHc/7GsW/nXtfMzsFcg/qt923HcFGevma6F7gf8trpmqo8+ZlzYcfD93X8+/10fu5jZDvcG5wz/8wx9LK17SOPbqUX68Cfw9BcEY9uLpZx+vDObh4J86e2gZjlzd8RsNP+EIzcAroL0MXYre14NN8eXKaZQywQKgO6zDeC/xjvkfuHC3T3bBMOxZsnxI7pDOQ7wR0wH2+PpWS7gPtJk4JvOc5jg64M8umr0v89uUJ7jzQzja4nQWvbJAz4ohMaCQZQFCnnL7xUSudC+jGSdXNf0Dlo+FVUZPqbDHQrnVcFRRQcTyQmHlqM5X295NvNIDY8uiovoMsMROTKZdregOf0gilnMGnVMv1P5mK8HXQLbg101Vg1zDboRoN0F9DNxnZfhsbxCx10aYij4QVgVwPdDa1AOEFXoJyNtMB5QBc4LciNfQRkROMP2J6gm9CrbSb0CqQLKgpoAYmCkFo+3wM+AF0Byga6G6gO7AR8OXRF+QaqCqQayBqYgdqCRUC3QO5La3mVD8jdQbeWO0E3YfAE3wDQhtoAZAGpQA9gBc6/+DGrTA26A4Px/VaGWE7HflmOOqYvCRjv1yXUOnzWtus1YD8Av4GuAaR/z7XgeL2z4fuiw1Hlt+vTHZW5bnHPNBDHsga6DcvbvURnqK5h3c97B6nuub0jlZ2uA3TzO3XweFbiOepOn+Aa0G3wpbN5AqzBanUIC3DZpkMpz6SDbgIxz6w6tnSEB3QNkAN6c3k62g66VZcUPBYgJ/AG6GYn/QBdwXBBaYFWQXJ16ON7B938XwADHDe06TfWA4xjmwnXWi9ABSAFVhuoGzoLdBOKAFt+43NszyGyt3tAubYzcGrwesIv0J1g/HkNxQAy24h3/geaG8Y/S6ALJOZ+boHePiaB3G0Q6mXr8wpo2ruDqcN+XwfvqPj6ed4AXToPde0A0z4Orqs6Hb7tW0E3l923N/fGAcYN7gbadA4E0RfBaAmbDZpEt5XhepI1Ywomf9t1RRcwA/xa7ZXiugfAzVzQrRDLCL3Bk6nHLLcrtZ5LTrNuKVgJ8/aAFBGQE604QWqWeJggM2BQ8Lspu2a05zx16jD7bcC6OgndsbhYhutQ5u6edSbU2wTdlUeXvH/xXQYGWIJspRebYDQZ56V+dyJtZSTwSSFmEghmXSMNDAFfE/maqq06DkwIkRkUOqJ1z5yQqqqUXqAzlWid4y1VTVw3qbAEAGQQA8ForUCXclwBZTOdZQaXoegG4Ga5apkOVlMAlyu6EQDSDU4rulJLpIgM0KpxMSXWGytXfFtFOmAY9TYa5G15NW6u5J6guzXganRbwTVFN+CzGvACA2AVVQtIRUlNCJZq66ovYIHyi/IWyxdUFki3UmuwCTgBtA4pAVelzKHoXoJug5eBbqz3JSc8OuhK5QUAdxAsoC2VVYquweym8G6giyoL/LI+yqg+S2HdVGIpuBsQCxR3tXeANo9PZczyU8YEclOAE6xNsZZafYIwCrGrpaeSzTUq+N4VW7YH3PK7K8MOttxv1QGpc+T3QB2PQbE6Ta3QC3S5p07g7Y6UtpsdxwOCuYevgi4QHB3F9apREIPj+K4VXUZnNJpioOujMz4y4x3bfpZtn6is9duoudt6NrKTI0xHZ7lgE7XWQXfgNX+XqpvQKvV1QLfgZVRSqbsNukvRNagAPHIdV3EBXX3f6i9qcCqwBeKbogvEmoLZkCZld1RmU3tXmfbvC8AaTPM4dSwOuvo+zklC3j+4BXQFsg66ee5QZ1s9PhVdwZpBm6vAreJKkTyV5YHr6pRcgKgroQ6hfZ53AO1rd4Cuq9yb+s71QBU+QLfOm8rGMga6c3ym6lI260CNgot6v4Pspui6OgxAH/fkBv/a30V6MYaRGab3If5R1gp8Oh3FNUiTeujQA5B2WogE0EmZsdsaSuEL8B6l98zji12igLujJTtiTwDboFufXSEkPx6Wgob5gMmOJCTtheXO1fHPeZpoR/IWss0zJdukw7gC927/SIBF0a13rkfOg232jQZV2RNQWgt0a/7uc6Y0shB0JgXZC1BeK4JV+XizHGRoUFkATUG12xSwbzC72W410MwozMiGOpvbn9RfwHIquLqGHa2rczOznFXC9JkAorZDqi9SqHVy9MzeoGl4MxXQKLqxHQdd1NxpiFBbRkHJ32Q5cFU3vqdhykZUSo43VA66sQxWiFp27A5nw8e2tkbcFV019tnot4oL6MruoAa3QTeAVYpc7BtbQpTRh5CxMoyV4FTXdkVu1MEdcgZSStFle9cUXYDIwSbhqUHXrQelqG5QKKW2bQSCuOugewAjoCuYBBYbWLFApEJcCmxZKPR+fF9g+aUD6QnFZqUwm0Uenyu6Oq6xIGAJKOtCQ+s10NV2HCI5ryjhUY5WUNVpGFX3sIkYXDvotlWhFfywMuxQzv2Uyjf2hxwdmA6Pwzj/T6dq1Fy3yiSUytbgHbMewZBlYBTd6gRiK6qO4tiJ2s4Qqm0+42NRcEWXjuxYkL7g0laEGgzoUm8wSiRVNrdlMDuWJym26nBTj4RFgXqmrFZf2LYr1NOyNlBnlZ0h1clWdAt0WZ53lFngGMBl+LnUY7MP5PZq/0Az+9kUXSwKqKqu2AKkgmwsDKjNKJb5WaDrqnEpiwOuDbqoiqEG3wPoAoenolvgCYBeGXp3RdHhDii2YXwgNmE9obrKfQG6pipvdoBt6F4dgAb6w15wqrpdzoLiC9A1W0KXR1Db94OfB++koEy3onucp762fD9KdltWBM6tDjvo9va5FgJqfe/Hcii6Gupv1XTgbQCx1LpKQWKKbtsI9F2rn3uOO7cZAIk+LR3gyT46Rdip5NpnyrGDrvuF97QUG7ArPQg2hc7n57YJs0q0fSCH5KW6bn7hSbsxk0EMKHvaNCCfY/ZUZkB/K69SbEl7AuiO1xYQLkUb326DLnlt8TOTFzDTcFXuwjNBd+XN3WetcSgmBRgKaSu6nULucjpJplis61sTXTDLTaUIm9Ri5Oxt0JUPm+kmyeFLHseZ1SysCHVcDrrty8XLGxNKZDL220B3Hyo8LQc9TGiNlA9j0lgBrn830K0GF//fKLpAs3kKBcYouihgKLNYDwIYULZo7Aswy5MYUJOKb6pb5W8EdPH9zjbHhwu4uGUAALnm7XRgzeFv7ApS8FgnQVRKJu8OVQ2BB+RtSqa24bCFWgks7wounl1UX9kjNiAdy0TAodsFTtCd39wLvAAWSL8KuoJkQDfe0+ogywbw3N7XUXSvKd2Adyu0Uob381RQjV/WYXrz/17Z5yj22Bh2ywnnaNTbsSO09SNB9/R4l3VhFN3pdGFNcdD1jqOPXgC6DrG1r/GuA7WAL89BK8ECXew8A7rjwee7gL0G6NNn35ajUnE3i4OsEJsn+Iqfd48TUCyBdayj3iHGAI8toNsQa9YFYBXbwQWo4qsVbDTo5j7Hd1vWBfZdoHUNdB2c8ez2chega8DW/l2pzwGtDsn6HzjC93sNksveYYqutnU368IOuodyCsABYnm+DjuCgLM9uumJLoU7QXdTkXff6yjkeJDn992yYArp4Q12/3PbITbQlX8YcNX7hcf58NieVogGcmDflF9GFC48ut4J8P2ewOxKM8d3lJfjTNCd3LamgKJYJsD696O4TfLiUmZdqXRFeKwLM60vsJkBY8oNx7C+5ztt1TjtFOxnZtvwYLaB791ygRoIZI/XeI6Nfbt/16f1G39sbZt9bXl2da4YZm9F13zNky+vgHTmkZ7h+/Eym2VBIIq/N0AXS0O9zzWY4K7IOShFVwFngPIA9EyL27PcYF0hyCsDy/aZachfi8LaQWkKiANS+9qrI8RsPGM18ITa0ynCYhDnskB3cjCP9UBQrHL69L1lccC6EBM+rEA12RtytjPljczclndTdLErbMOF44XDX+fKrQetfHqgG1BbgSin+ltKcf3WNgiWkyKFGjW+2PIsYgtgyLgbcqlXM5w8QWQouqmQreXw7iY8WDBaBJc10OLV1PttoDtK8ARC1XD3eDIHdMfX6srf9vumXpqVwDy0m6KIj1XBYQWcglVXPaXKugd3AtsMWjvYbff8busJTAcsXY1WwNymAEudRc09QbdV5Eu7QqrDh6UjQVfQ3IquBfANCJcankF8reiWvcBhl45NgrOp5/P/gG5ta86X32/shzIxAjEdJ7PCZCcM0B0P9lhluDfLM94BblJ4e/QDnywWh7YSELxZoykFxepMor4ey3oAWkF2PXPXQZdOK6qwgtjw4KqO2YLaEnwnoI36ZosHUByBjzpVQFhZGhp0CVhb9QhKLYouQWKALu8EezWMAjcaft6gVpDnnt8TdNsy0UPfBskMl5ufs32cJ6xdAVr3D1+A7mE1KEVX+06rw25dcBU3fhvIK7B060Irzgq+iu1ugV02zH7CIsowvumriq7gz33HDbWANJ0DH8p3G4Op2XcGXQXwEUh2zbqAin5H0D0sC2yHc3Equlz7K6C72SBQmV0xviPofv5lMNpkL2DyBZsFRMAGvBSkKZAIkCF7gkC5Idr9rQFm8nUO7A0EO+huMK3h685SIF+nTwwxyZA9qbB7imdmjjPLwQB/HfM5cYPv9wJ0TfW9BF1Bunl96RTMDCBH0Js6DhPAJcVV1oQBXXlz2baU6Ay80lSGF9YFgTEzhY2iK+uAQHcUU0C3wDvhXqptqbLMUy5oXb+1yoti26BrHt30yw7o+hSPF6Ab62u7lLdh2kFXk0AU6NZkEOnTzWkvmfK3Zjtj5jSSu5N1IT539DJDfcdQYgAnQ4QdSCLvnKsz7q+NaO87WxeW0mrKz3XQPZQjb4zbmzg2goDQM0OCB5uhaAEewCaWhVzWQJdAM8B3gLWsCj0cbUPWp5rrHs/T0kBkvgOy2wQ20DU/LQFbbSXYlE8BJcqwbAMVrGW2gNtA9wBUz2ZQ8Ga2A/P8jiWilNby2mJpKO/rfLcrx1027BaxXcE4avYG3Ju3WFDa+zNAtTKgvF9TdLfAOwNUB91RfUft3nzU5rud7AwD5ePR3q0Lu/877ivPDBEWF2XksPutj6UVYZ4BZXJQZ8ztCwRsZjnCLhGwiZc9ADc7iALeDgYr6PWO4g66svsYFG+ZU3p0Rh1ZwFZeX4fYDmrzDAwKfD2tDRWAtqwS1hlHzU0/rOwEnpkh7A4ejAb0XQfd8fqSIQELg9skCFwjgNcD2LaAtPTvTqaFVo8Zmr4GugI692xiXcj9NiTvQ9gN9HcEXQ3bm6J7FXQjgE/b2RRiFFuVwUEX5XsLNhOUAreegQFAP8H6wqO7Aa1lqbgA3ck+cS1IzT2tA9JkhDC7wWF72OwqgthWqP2z2w0avD3wUPs4QddVYIfaU8n1e+ZQz+mAHFkXNPuHho/JRICK2EFHgpOezayD14DDmgkFlbRhxtJ+jf0BVZN1RjHdFFrtY/Pxml0CFRMFeCwCYy9oq4WV9wRO7A9R/pjZY/a3zzjSoIs/2UBzFGSyNgC67jG22ddcCeaYAF3z3OLJRaXdgs+6E1AZGUgF5jOjjVcYpbg8wBNkOKAL0M7MaaXoegelVFxAl9Rv6zwFkPa86XswmlsXyhahuap13Amv8gJjWUDR7e9ltcBGMdaFBbQH6IaSy/S9lJfZhGp2sjUT2oWiG8FoFmRGY3QlAMQDSVrRNSjeQFcWABq+/k2wClxOYzcpjS4sEaYyMRTL8KoHeaVNQam/3FrgDTVQScM/Pln5dZVmCRguUBbYShF0f60HGu2+zVvSWCkd18BQDVW3lcACuG5VdAE4gM98u61uSnXdwPQa6JrHdny2AJoHsI1yPB7aAefJ3iDwNKWYwLMJNAvo/bJJRyZgjm0Aw/27QS2w2/Ar8O71yCoBxLcqXJkS8PN6B4GMEXXsHox2i6IrG4Nfa+/AbGqvpTDDVrCXoe7XUWhJSTd+6wBS32ZnfBD4tvVBgFz+8/Gmuy3BvbwegDbLjJfdU4jdCrpKyVeKrmVXUDCZ25Da9oC67BlWzJu/ZWS4FXQrMwxKcga1rkafILUB3fLvkn7MPboou3cD3U3ZFUC7RQJg7u+AHmAUK8OZUszVXODFVT9955kHosylgB7g5EPY2q+DaQeWtaI7oEug2W2gy1D7aYXYsgKwf6nG/Rv2AAfdzcYgJTiPS/Bq29pV4itw6zC62QUmi8GZuu0SdKVYX0l95gFt2UnaVN8jXZofOyqs2w+8Y2KWhhPwt890gHx7Ds/mKe6yrv1cpBfr4DEpsJ6uCzhFSdvmXVYKqhjuJ5cqQ/djXRhLwTXrglsMZgpYg0WD59PPirK8g+6uSm+pwY4AtfbEmsK4K7oT+LZZFy68wyjGTGM8UwJyHggoI+8wxzK/25SD7Z0dSA54detCe2tNVSd12ASjVfkTYPU+ntyZX3ymYBx7iIMw+XE7e4JlMUDpnXy1ZIPwfY7Hu6bmHdAtkC7QrfRjFYTG/Vae4cmaUAFmE8BWAFsqLoowoJvT+SrbQi6X88oX6KZHd+0HRTd+L5WCTAsaXjxA1/NSZoofFN0L9XfPsUmqIFQZgmfwA3pmhVjWwbdtCxbY5mnCLr2z5ce9lpoJAO5MB/IqtrobAWgRmKbhWA8eapvBlSh690u6WriBEMFH5jedoKQJTBvQtPy453D7grdWRvG6Sv3sACt8rmQ46MA0D/SaALJUXjegPNOLjc3Bh/z3LA5lFWiLhSusAlnKHeslyCrdWKcIy+95fXkrwuc+vayA4xfH9sw7nOBtZbim2ibYeplNBW/wlYUB2Mx9YFlRTlyuZWeJaD/wbmfgXukOjAIh+17xUQLZUBqCuQ9y3zOiwL2+w/CAbgK2LAssSycPtTZUY56PBFILIh1FVynK1IHFR5/PY9YVpAXzFIDjt/cO76b6mn3B6wJPUUbHtxVceWI94wuguY0+Wa5dIBfLwmZdsBRhAWlsi2VQbuu3Gd3yTAy1jry1oZTKD7wFt0lBbb/uOWxtcHwRgCVQYqi/Vd0D8Pw48d5iPShYk0d386gWaALEbjfAanA1MM4AfTJK2BD+BroK4NtAV/sU6DqEdiYJ7xAcKusGsToP3jGYnMSXEN3bF4Rvfltg2/Z3u6I7QXoNwp7X2M+Rq7he3rY5WAfkVIbdCtFqvanDdi8dE0YISGQr2Dy3UvMCxkI1I5drB2QJHEMFZTh+870mpB52AuVYxaO7ga4Ck1pVFkh7BoPTeuCZIFhvyjf771zAUlJ7/yiWCa9M0DCZDhxQAbSzPJ1yzD3O7XndFd09swUpuQpyUW8rz2wFl3nmgrQjCAgddJlMwkH3K7/qPgGuvLw51K/zoWF/5gpva4I8uWVvUHoxOz90LNyjOxk6ZmIGz7rA/95hyvNoxwbss108ur2ugudiPTIpVFqxml8d0M053uO7UGwXyGau3MwgEXO+76AbuXQddNO6sDUcDrqTlP20LlxTdM/sCmfO224cyZBAYnipPBeqD/5cA11PHXYtSAyQdl8kQWYd5CPASEtCwmBZHgIWqmHfsyic3ttdxZ3sCZttwRREBxvAbDyhAZWkF9tTd51+0M66sA3Tjz91+x0frvt2txy1B+gK2goOzQdrqijpvXIZXmwTNVZ+4IbaBs4BTwfdSRlWxw7oPuYxAl1XrXXcbmdAnd1tEbvftydvwINsQBzrtR/XlGU8zhOgtk/OMR2Z6hRcLOdZF8LaYtkV5vwuD+6WQ9kmAtE2gVq3K/j9iIe3QVcgXPcok0zMZBM5QqHJUrjXuf/n2Zr810AyQW8EdNazLLtDKrpfIIuDKbt0XH10h2f66CCPdcE9upVa7AJ0sVJ5Z3xLOTZKLsCc/l2B5GRaUA5cB10psBVwdmRlyM8DuoBN1Y0CXQO5HXZn0oot/RfD1GYD6OAvB8UDdPdAtonkvwa6AGSD+5HlgMklroEuv41Ht6D4qnVCuYo9l+2FR9dB12B7QPuwD9wRdI8MBqeSytC+WUMaptOnPIF110DXPcKXiq4UXibpkOKLx3pTqF2BN8V6g22VdVuvlzVQd2VYx7vZRK4ruvhnC4ROCGzQbQ+u5Xtd33UA1+nRtcwEZHCo4f8KdPP0YEzEsMFkw5aCtvh8lGMUXTy/U7494wPQSXozAS1BXQGYkVPYIKwmMNAkCso6sfmF24esCRdsUoOBaws6w9fb7xbUx0QQ4bk9QZcAs2ugq3LnOgmRpf5OVoUJ4OpjETx2/mSBMAFopBibvMGjlON7dRh2r/MGulLLSSHm1oU+z1KcW7mV17byBGOtOPPmFtRWztzy5KIWp0fXQLcmjajgtFZ7D0W3PLpRea9K32wLPixIsAXWhcp/a42QPHq3g+40nOndzeHaGralIaMBPYPP8ASmp1Bqa2dDWPvtgDPy5TIUrDyj1bDPpA8FmNXYYxnI4V4BR2dmMNXuVOLc27upcSh8rcIy/I3SyeQGNZTeAWOtAJoqKkCdYXHZCAwy25bQiu6ovdgLav3xxHb6LgBPfliWa3sBwVgoyKQnY1tXQJeAsM6CIEsFZbmm6J4pwjbQdUuGH7fB74BuWCF27y/b8tnMvIyAdWeJMGifbZmdIa4ZnQC7ZgO6l1kiPGeuX8v2bl+A7m6z2GwNNqLAti4UXVN8x9bjwMu9v+ffzU4jnl1TdAt0ZQmy33nWSw22YDS3JphHF1Du59uAlw7wVucInjcfb4OtYNPrHaUZ87oJ20LPnCaVlfy5460d4CUYDWAc72/NftajXwp6QwF20MV3eqq6zM426b/2mdSuwesekCXrgkCzPbsNeJORYTzCNvnDWq6zLggyc5+CPiBw864ChKfn19VnWwbQ2yeBKCsBKcXGo7tbF3q/7kuN/Ugp337fvKvXc9KOoiulHYvEhZoqG4Kr3EcnA9BtIMaqoG21misl9gJYr6jfPuHE5vdV52f2dZnpogMR6ShZB6IUXSXxR5Ej2Kf9qwF8BB9F5LqGgB8HoKZXc6Z7xbLQ1gXBI8PmFVSk/KwRzKZXZw5Qecrba5MWBHSS61XQlNv0NGf8H5ApiG6I0ncVZDWBUwm0gtJWFF2RDUjnHNly7hfubSr3bm6//5/MBp4pgXK5Wun5bnuiCNKFBdiaCu3ZFlLd1Ssnk1jHRLqvrxLoEqCWthBTdEPNjFeWR9Dd1yrgMpVQpVND4RXwd95aLZPZHLi+AtO0IjSkkrKs/Ln3YxVRh4JzAeii3FK+LGvAbyiz4cddr8qi8KSbJ6bfVsFnS9GNbcdvaU/AurD2g2WhoPjSuoCim9NmMgSJ2tJDf5WWxhupnG7TGyulIto8t2owCVhDmQnQRT2t7wJYNeSpbaLu9kxlmtqUxpvfa4rdmsWslSnLaFDDzJopTUO+AVdsp/8XcDDUS1R8e3XlrfXPW4DTFQW3rQSH7xal1lOJncPxDbFme/BgslIiC5YJTot3h8nez1qOiSbmd0G41mkLgGU3AFi3bQp0x0u7Ty2MsglkVlqzCoTz7TxmWQ1c9eV4G3Qf++VdZi8Hx0G6tIJ4vL3j8Y3fcx+57+rcxKvO1X7sXcbOJmGdCm2f++Gab/o2RdenYXYLArAc5Tm9vm1/aC/32BQajrEu5Pry8F6xNtQ+J4uDQzP3eSnCCuLMILUKVMvnTtBaz5XNrpZKbY32ZAdUwMkzyfLkw811o5PKNg9Vd1NsVec49GagnK0LzNYyeHWl4hogj/3B8+xqZrSov0yJbVANIEuLAu9Mi762kev4bGwVFNajXYd1AaCuZSYHbirKwFZO3FDD374c3ligGWjLiR5cBXbQYRtAqA/BK7CsJ4xgyB7VE1BqaC24ynLq3acKbihXjt1Wjc2yMRNuFOjmvrWfLTBN5bwKulLYx6bg6cV2JdtTd+3nsvZPx6A7Aa3oSqE2hXebcELrbttE1eY3rr2uJaB7sc8jXdzp0WW/+/k15VnAvB0DHZ0o0yrHeHSlpAWUNMgqrVgCXUy0IEBiqDi+K6CS7xIYEgy277VB16Py+R/Q1bB6wmgpqYCue0sbSAVmdwRd0qKhyuZxODjXvgBdB+ACQSm6AHJAmewX2+8Jf7IW3Aq6BteC1TouAb+24WnCroEuadxKbVYWBFN/AViuS6ryaV2oYXuCvTpdV3yn32Z78R2TY1QGBQIKu7y6xoAu6iznwYPKEsATTOualy1hB93xDtc5Dghlv/yf94SgPN6fkDAr0I2cuAm6mgQiVFv9lrlyNUNalAXALZtDBaPFcXnWBYbyNtCVSkNj4aCbHt1bQBdwJfUXoOqBaoCu5+UERlP5UUBYNnBSkaIBxqowiu4E8pBRAQtCg+qtoDv5Sz1l2Aa6pqAVKFmuVPkp98j7fQjbQfdULsejOwFIAFf7XI+UWgSaAbQXoLvgN+AOpXJAd2ZU2ywFZhXYfLCeWuuE5wZd349ldNC64cE94XoD3QTZ2oZnNwB0H/ulX17HonM+3l2W3wEbJdqPj3MxoKtOQZaxUpxlGfIz2zu3z/d1nT5d0N3gVPfQ3AsTdDYeYJ8NTn5c92nnfTfBkRvoGuy6x5xtA745ymEZFzxbSU22okwLev7aw8uzKF9uPJ8Dul/QgJygqw5sd27p9Ob3yvKggLQGXf9sai11Ah1t9+/mpBbArUOvTTLx+Z01BmityR0qN/iALLNfJejq5b/XFMOacc0miXDQdbABdHkPqGn4FZwkuAo2bwNdh5r/1z/43AFdoMnUQiC9rQWmTKaYIcgGKlF08fPG51PRPdOLpXXBAdRmS0N9bbVZQH1V0QWuN9Alh7BAu5VjwR4w6oou/5t1oc9lK9EDunQsNuuCdQq2smvbrc6rw4I6P5OCTA7lzhgBDBsUk+oMkHUrxQVcEyB35lK+A/wfoCsIacV2zzE7oFteyLIVyHJgoFvQWBCWdoQGOcv1GiAjn2+puaaYpiJY618H3YLPBqOET5u4whTi2q6C2Wy7Ozhr3SuKLsCdcClF+xro0gHo5QS9VxXfLruyS7S6PCm5gNkNdGO5BmTlxhUo9wQR2lZZTsrD2/9HmRJ0LZ2XOikDunNeA3SxKjjojhJffmsHXWA6gZQpd2X3KNCd4LGA3rTBkJ2hYbs6DCfo9roC81KDx7IQ+wvQBWJDya0MDEu1XS9+K9Bd3wt8W9Fd29vSi0XlJ3DFe8dwpAd3eEODutHpxZhFSQ1cN5YoOdaIEUmeHl41fK0wKb0XVgUa3myMo+El4X28W8Q6qcAcdMffiKJb6lepZqV2AcSxbClslic3waGW20HXVDaHHwcZFN6AqQPmRtGbySFawdWyrugWiJEVoLbXiq7UzBnyP0AX1Vf+1l2dLYhrldT+d4W3gVRlq/2XWnq+COIKjy3HPeqv1lnrPgbF1s9NH8uX3TjojqJb8Hyqz60eN5TXecXne4K0pz2rY5M/uK0LPnMbHmifuKLU4c2TTUfoUPZPMB6Fu67p2BkE0j79MvYbU6Q96Cxhlowgh5XiVtDVPq+BLh0+B91+rgx6AdmoK+isRj3R9qIEYVka9HyTucHVWyaJoEPbIz9kZGDmtEMNbtC1XNuf93meiWFsVeTiHhgtsGVE6gRdAAlgROl1exfbQiBwVddBFzjC74u3teEyIHSBLuouywFDFz5PLb/lWUXRlQ8UQJ9gtQHErOMtGA0V2XPkuoLL7w6+PUvbAVuu6PYkDweUtnVByrOrl6P+KrjLILhA3wK1XHllSmFgH6VaHuse4jdFl+9uA91tml4D9bxugK6OAWAlEPEsK5+7s9LQaiqynY/N0+yKPMDNcWpE4DyWKMcxM1qpbUAF4IaiiwKJ4jugW9ASv4dH93bQnZy8DbGC3BmGLysCyt+FdUFe31EOr4FugWlbFwSxWCQ4Do7v8nupr6eimzaJAdQLD2+AKOscYD37BCYddBna10xhUo0vrAnYCta2U7G9CrrVQdlB934ptFJ0BeKVX1dWArMs5Hf4kQWzYyPBclJe4wRddXw20A2QFdSToSHhVspuQWqsqywLrYjXeRnQre3TMcK6gG0h1g+ILY8u1oV6n+C0UHQLgmuiCoLWSs19Unh0L0BXuSeZLELpgUotmeCLXVGpocL+LkGXaXwNSOX986hrQHcU3X3GpvqdGcpKYUqrgyDYIRp1yxXdgVZ5E8NnmF7DGeYFggs2Bno30MWnK5jd/Jmm6DbMmOoLwACCHcXPpA25LBM3MLQ+KuWArgDXQVfKLSqsgx5wtym3Pf3uBHvNDGsGutggpKICZRvoCgZRbHvf8vICoaGmosg+Rr9hV8jfFujG9+0ZxoIgiC4QRm2tdGTA9SXojg3itEdsirHl8p1jKysD18kzSRSoc35O0J30Y2072Wwme2Bhq/Sox3rfRgTkH5/tjXd8g2rLuuAq7Tm6sPl7uV8F6OSLJpjN05S1DUiKbYHtdBbbl7uBrtRddT5LtdWEMPbcjnq7pxPMZ/rvouiqzgI+3c7go0gTMFademIMXKFtRVeQhLWBadHHukCwW23rVtDFApFKcCmlm6IbNgGBLttwGLwWmMRMYu7RbPXWLBe5vYaiUUdvU3RTob0Y3t9hzGdQ66F1gSAw7OW/qlACsKaMNlieKq2U0Av/6qEEA+SehaE7DQeQzkxruwUCIN0g3aCUiT/m+PYZ8Lh3tu0ciu7Aruwgm7WkvutrLhvCnllC12OD3LJltFUC0O0UTVJmB3RtON6G/FEF29KA37ZBV4FdruhqfXzAnq8Wr2qrjQK9/txD/JN5AFU2l5EXt+BXKu4V0N0C62y4fgdd2wcQjkpsIJvZECxYrVVdoPoK6G6Bbad/N60aBboouoDsQO3YCca6QJ5aTfurc8DvBBSmFUFgSifhq1F05Xkta4By6xp4ntYF0oh1uq9M81VpwLwDgi+Xa7WBbmZF+DuA7v0F5mFbSOuC0on59L5PXFkU0sagoLOe5jfgOkA3IDj2vd4DcgHlU9FNRUTBHjW/fUQ7F8gSkLEpugr+uABd+elSeVW0NUoPig2NajaYpvhklHhCqXy3pEVK0LU0SZlCrLYP6AKoKLqos6V61TYHbkfRPdXdBoe2LTBkXUPd
Yes, it is.
Please test it as described in the following document:
PC: http://ts.hercules.com/faqs/eng/her_eng_00435.pdf
MAC: http://ts.hercules.com/faqs/eng/her_eng_00436.pdf
All checked. faders, crossfader controls frequency, tempo, effects buttons do not react at all. but the transition samples \ Effects \ loops, these 4 buttons live "their lives." that is, you can click effects, and they immediately turned on. may still may selectively. always different. and the program just does not respond to pressing.
Just to be clear:
- Are you on PC or MAC ?
- If on PC, in the MIDI software, you could actually select both MIDI IN and OUT for the DJControl AIR ?
- Regarding the Sample/Effects/Loop, the reaction you are getting are on the console itself, not in the MIDI software, correct?
I have the PC. directed the video, as the device operates. possible as you show it to have a visual cue?
Not quite sure I understand your answer...
Do you see this in the MIDI software ?
