hercules dj control...
hercules dj control air usb problem
hi guys i have a console that worked fine, but at some point the usb cable terminals have come off the motherboard, now i do not know the correct order of how to connect them.
anyone who knows the correct cable order can help me ?
Here is DJ Control Air USB connection, to solder the USB cable:
OK thanks. can you tell me the order of colors?
- USB VCC - Pin 1 = red wire
- USB Data Plus - Pin 2 = white wire
- USB Data Minus - Pin 3 = green wire
- USB Ground - Pin 4 = black wire
- USB casing ground - Pin 5 = shield of the USB cable
