hercules dj control...
hercules dj control instinct knobs
hi, there is a method to map a combination of key+knob to control filter or effect parameters?
for example scratch (keep pressed) + trebble knob
im using vdj and djuced
thanks πŸ™‚
For Virtual DJ, about just everything is possible if you are willing to put in a lot of time learning how to use their script:
http://www.virtualdj.com/wiki/VDJ8script.html
There are lots of example in the Wiki, and some users on their forum that can help you with the coding part.
As for DJUCED, for the moment, it is not possible to modify the mapping, but this is a features that will surely be added in a future release.
