hercules dj control...
hercules dj control instinct tool 1.0
hey, i created this tool that may help or you can also download by simple curiosity.
the tool is aimed towards the softwarwe dj instinct control console, so if you do not, you better not use it, can do damage to your windows registry.
it has 2 very basic functions:
  -change the volume of each channel separately
  -changing the asio buffer size
hdjcit
the can use some reliable if the original software lets you working for some reason.
pardon my low english level, because of this, i used the google translator.
link removed by moderator
