hercules dj control...
hercules dj control mp3 le sync button led
hello all.
i have a hercules dj control mp3 le which i think is great... except i hate the flashing sync button led!
is there a way to turn off the flashing?
thanks.
jd.
The LEDs are controlled by the software, so unless you can modify the MIDI configuration or function behavior (in this case the software providing you with a way to visualize the tempo of the song being played), there is no way to prevent this.
