hercules dj control...
hercules dj control mp3e2 nois
hercules dj control mp3e2 noise ,when i try using any knob fader or eq i hear noise like brrrrrr πŸ™‚ sory for my english,i using windows 7 64 bit hp hdx 18 loptop
hello nenada,
it looks like a bug occuring in your sound card. what is your audio interface, and are you operating in asio or in wdm? if you are in wdm, can you try to convert them in asio, with asio4all if your sound card has no asio drivers, and let us know whether it changes anything or not.
hello maxdjack,in first i want thank you for your answer in my question, i download asio4all,install and this help for me
thanks πŸ™‚
if the problem happens with virtual dj you need to disable safe mode in virtual dj pro performance config.
in case you version is the limited in the hercules pack contact virtualdj service support, its necessary a little modification in the windows registry http://www.virtualdj.com/contact/index.html
hello,  evrybody i buy usb sound card for listen another track and problem is same and i using virtualdj but not pro and a did find how disable safe mode in virtual dj
hello nenada,
1) did you use asio 4 all to set the usb sound board in asio?
2) you should give the name and specifications of the usb sound card. is is a 5.1 sound card? precising the details of a configuration, the conditions of a bug and the symptoms of the bug is the preliminary condition to receiving an efficient support.
3) there is no safe mode to disable in virtualdj djc, the safe mode is specific to virtualdj pro, and in my opinion it should be called unsafe mode, sinceit is generally a bad setting.
Hello nenada,
It looks like a bug occuring in your sound card. What is your audio interface, and are you operating in ASIO or in WDM? If you are in WDM, can you try to convert them in ASIO, with ASIO4ALL if your sound card has no ASIO drivers, and let us know whether it changes anything or not.
Hello Maxdjack,in first i want thank you for your answer in my question, i download ASIO4ALL,install and this help for me
Thanks πŸ™‚
If the problem happens with Virtual DJ you need to disable safe mode in Virtual DJ PRO performance config.
In case you version is the limited in the Hercules pack contact VirtualDJ service support, it's necessary a little modification in the windows registry http://www.virtualdj.com/contact/index.html
Hello,  evrybody i buy usb sound card for listen another track and problem is same and i using Virtualdj but not pro and a did find how disable safe mode in Virtual dj
Hello Nenada,
1) Did you use ASIO 4 All to set the USB sound board in ASIO?
2) You should give the name and specifications of the USB sound card. Is is a 5.1 sound card? Precising the details of a configuration, the conditions of a bug and the symptoms of the bug is the preliminary condition to receiving an efficient support.
3) There is no safe mode to disable in VirtualDJ DJC, the safe mode is specific to VirtualDj Pro, and in my opinion it should be called unsafe mode, sinceit is generally a bad setting.
Hello
I have a quite similar case with the MP3 E2 I just bought las Week End- thought initially it was a kind of interference between the e2 signals (through USB cable) and my (non shieded) speaker cables.
Is It a known issue with the Vista/W7 new sound layer?
I'll try it with asio4all (allready installed) tonight & post the result ASAP
Thanks
NOTA: you talked about a regsitry modification=> Required with VDJ 3SE?
Nota2: My config
- Intel core 2 duo mem. 3Go / vista 32bits
- MP3 e2 /VDJ3 SE in default WDM mode
- Realtek integrated 5.1 sound chipset (WDM, no dedicated asio drivers)
Argh ! 'could not even get Asio4all working properly with VDJ! f*ck***g WDM soundcard!!!!!
when asio4all is used as the sound api by VDJ, my soundcard does not emmit any sound, and the asio driver seems not to recognize it as a 5.1 able soundcard
And the only answer I got from VDJ crew was to give them the S/N of my soft πŸ™ (I have it, sure, but not at my office)
14/10
'gave the S/N of my VDJ software, and got an update
Hercule crew shall indicate asap its existance in tech support section
will try tonight if it solves my sound issue
The VDJ update seems to solve the Issue for me, but not for everybody
nopoles, in the french forum, says he still has the pb.
I'll test it with another soundcard (ie my muse LT 5.1 USB and my CMEDIA stero USB) to see if I reproduce it (by default, I use my motherboard-integrated realtek HD 5.1 WDM soundcard)
Hello everybody, i repair my problem with asio4all and for now everything super thanks for solution i using dual independet sound card IDT HP HDX Premium pc
Page 1 / 2
