hercules dj control...
hercules dj control steel and mixxx
hi all,hope someone can help.
running 64 bit laptop with mixxx software.dj control steel and ni audio 2 dj.
nothing is working, do i need a patch or can someone who is good with laptops send me a link or help.
thanks in advanceian
Hello djdestruxion,
Welcome on the forum.
1) You must import the MIDI map for DJ Control Steel.
Description here:
https://www.mixxx.org/wiki/doku.php/hercules_dj_control_steel
2) Please do not forget to precise your operating system (in Windows, you only need the xml file / in Linux you need more).
3) Please fill your profile in clicking on "My Space"> "My Profile"
- In "Hercules equipment in use", please check your Dj controller, DJ Control Steel
- In "Software in use", check your DJ software, Mixxx
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin-top:0cm;
mso-para-margin-right:0cm;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0cm;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
2) Do not forget to preciseyour operating system
