is there a way to get my hercules to also play through my pc so i can play online via wav or stereo mix?. it did work for a little but now i receive . cannot initialize microphone or cannot initialize wav. in my windows 8.1 sound properties. hercules comes up in the list as a line. but now sound coming via this setting. i can go to djuced 40 setting and change to computer sound and that is when error happens.
Hello AmbushOZ,
Wich software do you use to stream ? On wich platform are you trying to stream ?
I'll propose you some solutions after you answers.
Its windows 8.1
and Its Paltalk.
The Hercules "Line" that you see is the Line 'input' (Aux in) of the Universal DJ.
For me, the best way to do this is :
1/ Use the Hercules ASIO Drivers in the DJUCED40.
2/ Connect one "Mix Out" of the Universal DJ to Speakers (for monitoring).
3/ Connect the other "Mix Out" of the Universal DJ to the "Line In" of your computer's soundcard.
4/ Choose the Line IN of you computer in Paltalk.
It's the best way to avoid conflicts.
If you want the use your Computer's soundcard in DJUCED, I think you should started DJUCED40 before, then Paltalk.
