hercules djcontrol ...
hercules djcontrol compact - external multichannel sound card
hello,
i was offered an hercules djcontrol compact. from what i read in the manual, to be able to have different sound in the speakers and in the headphones i need an external multichannel sound card. since i know nothing about this, which one would you reccomend? which is the cheapest one?
thanks in advance
Welcome on the forum.
The sound card to preview and play needs
- at least 2 independant stereo outputs, so it can be a 4.0, 4.1, 5.1 or 7.1 sound card,
- separate physical outputs, so you must avoid anything called virtual surround 5.1 or 7.1 (virtual surround means stereo virtualised to look like surround).
The sound card I suggest are:
- Sodial USB 5.1 sound cards, very cheap
https://www.amazon.de/SODIAL-Externe-Soundkarte-USB-6-PDIF-Soundkarte-blau/dp/B01M7NE604
https://www.amazon.de/Externe-USB-Soundkarte-4-Kanal-S-PDIF-Faser-Soundkarte-schwarz/dp/B01LYGUGA7
Or Conrad USB sound card with 7.1 output
https://www.conrad.nl/nl/71-externe-geluidskaart-usb-soundbox-71-d-872990.html
and once you have it, here is the sound settings for Djuced
https://ts.hercules.com/faqs/eng/her_eng_00462.pdf
Ordered. Thanks πŸ™‚
Does anyone know if either of these work on the Mac?
Yes, they work on Mac.
Is there a guild on how to set it up on the mac?
Here is a guide to set Hercules Muse Pocket XL LT3 in Mac with Djuced, it works in the same way with another multichannel USB audio card.
http://ts.hercules.com/faqs/eng/her_eng_00463.pdf
