hey
the controller was working with traktor perfectly one moment, and then the next, not at all. i have the drivers installed and midi channel set on 1. ive imported the tsi and everything in traktor and set the in and out ports to dj control e2. i just dont know whats wrong to be honest, and would really appreciate some help!
if anyone has any suggestions, i would be grateful.
p.s ive tried on vdj and it works absolutely fine, just not on traktor... ive tried another controller on traktor as well, but it didnt work, problem with traktor?
thanks!
YOu're on a MAC ? on a PC ?
Have you updated your traktor version ?
Hey, thanks for the reply
I'm on PC and have updated traktor. Still no luck π
Can you precise your Traktor version?
Im using traktor pro 2.1.2
Can you verify that the MP3 e2 works as a MIDI controller outside Traktor, as described in the following procedure ?
It works with virtual dj. I think it's a problem with traktor as i have tried other controllers? I have freshly installed traktor again but nothing works π
Unfortunately, the included version of VDJ does use MIDI to communicate with the MP3 e2, so it does not help to determine if the MIDI problem is isolated to Traktor.
im using VDJ pro 7 if that makes a difference?
