hercules instinct a...
hercules instinct and vdj and djuced
hi everyone,
basically, my controller will work with djuced but wont with virtual dj. ive tried changing tha mapping files etc but it still wont work. on the audio section in virtual dj it seems like it can see the sound card but theres nothing in the mapping section.
anyone got any ideas??
thanks
The latest version of VDJ Pro Full (v7.3) now include native support for the DJ Instinct, so no need to copy the mappig files for it to be recognized.
ahhh ok cheers, any one know here i can get free version?
The free version will only let you use a MIDI controller for 10 Min. The only version with which you can permanently use the console is the Pro Full.
HI,
maybe you can help! I posted in the German Forum but still have a Problem...
I try the free version of VDJ with the Instinct, everything is working fine. But no
Mixing, so i can only switch the headphone from A to B but it is not possible
to hear both ?!?!? I pushed both headphone buttons but i dont work. With
Djuced 18 it works.....
Dont understand that....
This is the way VDJ works by default when it comes to headphone preview.
However, depending on the skin you use, some additional controls may be visible on the interface (the MIX knob, as shown below).
- When in the Left position, you will hear the deck for which the CUE SELECT has been activated
- When in the Right position, you will hear what comes out of Output 1-2, according to the crossfader position.
- If you want to hear a bit of both (when preparing a track), simply put down the middle position.
Thx, is see it work. But so the information from Hercules is not true on the instinct.
They told me i can use this option on the Instinct him self, i don´t want to do this
with the Software ?!?!?
They told me that i only need to push the both "headset buttons" and i here both....
Like the Mix-Button on the Air.
I am right ??
I think i will sent the controler back.....
By the way, is visit a friend that ist working with Traktor and it work like Djuced.
Push both "headset buttons" and it works.....
As I said, this is the way VDJ works by default, so this is not a fault of the controller itself.
There is a way to change this behaviour, but VDJ doesn't make it easy (I think you have to modify a text file somewhere or use a plugin). You would have better luck investigating about this specific subject on the VDJ forum.
Thx man will try.
Start  5 times to get a registration @ VDJ but i dont recieve any email. Shit is boring me!
