hercules mk4 not de...
hercules mk4 not detected
good afternoon all,
i have an issue conecting the hercules mk4 device. i try doing all that you say but have no good results "device not detected" i am trying to conect with windows 7 and usb hub with power but i can not detect the mixer i dont know why. i am trying with the new 2019 drivers but not detect the device. no lights no nothing on. i try doing everything but not results.
i hope u can help me. thanks
1) Please check if you use the original USB cable. If it is not the original USB cable, make sure it is a USB 2.0 cable, with a thick cable (avoid thin USB cables) and no longer than 1.5m (preferably 1 to 1.2m)
2) In Mi Espacio > Perfil, please complete
Equipo de Hercules utilizado with the name DJ Console Mk4
Software utilizado with the name of your DJ software
Describe tu equipo with
  • your computer brand & model,
  • the type of USB connector on the PC (USB 2 or USB 3)
  • your Windows 7 version (Service Pack 1 or not / 32-bit or 64-bit)
3) Do you remember if the previous time when you used it you had a firmware update problem?
If you had a crash during a firmware update, then the Mk4 cannot be restored via the USB and the solution consists in
  • removing the DJ Console Mk4 ground panel,
  • removing the eeprom from the printed circuit board which has the USB connector,
  • reprogramming the eeprom on an external eeprom programmer
  • reassembling the eeprom on its socket on the printed circuit board
  • retesting the Mk4
  • If the Mk4 is detected, fixing the Mk4 ground.
If you are used to eeprom programming, I can send you the firmware in .bin format. If you do no know what I talk about, it is probably better you ask to an electronic repair store to program the eeprom for you.
Thanks for your answering.
i will try with an other one.
The computer is an Toshiba tecra M10 windows 7 service pack 1 32bits
i think that i dont have any problem during the update, i think that i have never update the device because i dont use it.
Is posible to send somebody to try to check the issue? how much it is more less? the deliver i can pay it but how much it is more less to correct this problem.
Really thank you i will try with another cable.
best regards.
OK,
Good you had no firmware problem, updating the eeprom on an eeprom burner is complicated.
it is posible to do just with a laptop?
1) To do what?
If you mean updating the eeprom on an eeprom burner, it can be done on any PC but not via the USB bus, it requires an eeprom burner like that
https://www.amazon.es/ARCELI-EEPROM-Routing-Programmer-CH341A/dp/B077ZBBMHN/
so it is not costly but it is really complicated, it is a programmer tool with a programmer software.
If last time you used your DJConsole Mk4, it worked and you did not run a firmware update which crashed, the eeprom is not the issue.
2) Please go in Windows 7 device manager (Windows Start > Run> type devmgmt.msc and press Enter)
and check if you see a DJHerculesMix Device containing
Hercules DJ Console Mk4 ASIO
Hercules DJ Console Mk4 Bulk
Hercules DJ Console Mk4 MIDI
nope i dont see any device i just see, unknow device. i open the mk4 and i think that i see the eeprom is a little chip that is posible to remove? Do you have whats app? i can buy the device to burn and i can try to do if u can help me the device would be at home on friday if i buy now, u know that i can do it? text me a PM and i can give u my phone number to send u pics of the chip. really thnks to you bro.
I have sent you a PM with the photo of the eeprom on Mk4 printed Circuit Board and the eeprom firmware file.
