hercules mp3 e2 + t...
hercules mp3 e2 + tracktor pro 1.2.1
hello,first to say im a pc user. now i have installed tracktor pro 1.2.1 and here are the problems im having.
1.problems with the leds
2.i cant activate the scratch bottom
3.i cant loop
4.i cant use effects.
but i can change the bass, the midium and the highs and the other features...
im using hercules official midi mappers....
what shall i do? has anybody a complete mappers?
thanks
you are refering to this mapping , correct ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=241&cid=5
youve read the included document that explains how to load the midi mapping, as well as the description of the functions ?
yes and it dont works....
so youve:
- made sure the mp3 e2 is set to channel 1 in the dj control panel ?
- imported the profile using the import button ?
- made sure the mp3 e2 is selected as both in-port and out-port in controller-manager ?
and this is a legal version, which you could theoriaticly update the latest v1.2.6 (i would strongly suggest) ?
yes, i did evrything you told me and it still dont works, my traktor version is pro 1.2.1, so have i to update to the 1.2.6 or i have to take another version? what version do you recommend? the copy of the taktor is legal
the latest version is always desirable, but it should work equally with verison 1.2.1 ( at least it did with the one i have here).
can you test the mp3 e2 as a midi controler as described in this procedure :
http://ts.hercules.com/faqs/eng/her_eng_00367.pdf
to test the leds, also select it as midi out in the program.
You are refering to this mapping , correct ?
You've read the included document that explains how to load the MIDI mapping, as well as the description of the functions ?
So you've:
- made sure the MP3 e2 is set to channel 1 in the DJ control panel ?
- Imported the profile using the IMPORT button ?
- Made sure the MP3 e2 is selected as both In-Port and Out-Port in Controller-Manager ?
And this is a legal version, which you could theoriaticly update the latest v1.2.6 (I would strongly suggest) ?
Yes, i did evrything you told me and it still don't works, my traktor version is PRO 1.2.1, so have i to update to the 1.2.6 or i have to take another version? what version do you recommend? The copy of the taktor is legal
The latest version is always desirable, but it should work equally with verison 1.2.1 ( at least it did with the one I have here).
Can you test the MP3 e2 as a MIDI controler as described in this procedure :
To test the LEDs, also select it as MIDI Out in the program.
my friend wanted to knw can u still if it wasnt legal
