hercules rmx and dr...
hercules rmx and driver installation
just purchased the rmx and ready to install drivers on a mac book pro.  i read the manual which says that i should visit the driver website to download the latest drivers. will these include virtual dj or do i have to download this from the virtual dj site?
i am uncertain whether i should install the disk that came with the rmx or download the driver from the site.
any guidance will be appreciated.
thanks!!
download the drivers from hercules: http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1 and install these - not the ones on the cd.
using the serial number from the virtualdj cd, register your software at  http://www.virtualdj.com/users/edit.html , download the latest version and install that one instead of using the cd.
thanks for the information. i am really glad that i posted the question. i will download the drivers and vdj software and start mixing.
gonzo
yeah, i went through that and i was really pissed off.
patience is a virtue for sure.
Download the drivers from Hercules: http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1 and install these - not the ones on the CD.
Using the serial number from the VirtualDJ CD, register your software at  http://www.virtualdj.com/users/edit.html , download the latest version and install that one instead of using the CD.
Thanks for the information. I am really glad that I posted the question. I will download the drivers and VDJ software and start mixing.
Gonzo
Yeah, I went through that and I was really pissed off.
Patience is a virtue for sure.
