hercules rmx : beat...
hercules rmx : beat lock with traktor pro 2?
hello folks,
i just upgraded to traktor pro 2 and imported the new .tmi. i like what theyve done that you can put the balance to the right to control the eq and to the left for the fx, but how do i get the beat lock to lock the pitch again like with traktor pro 1?
any ideas?
thanks in advance!
iain
Since the Beat Lock function is no longer part of the mapping, you can either modify it to add the function, or enable it through the Traktor interface.
Sorry man how do I do that? I'm a bit of thicko when it comes to anything more than importing someone else's settings. Can you give me a step-by-step rundown?
Chapter 13.19 - Controller Manager of the Traktor user manual will give you all the basics regarding MIDI mapping.
Chapter 20 - Assignable MIDI controls
is the liste of all controls available and their description (you will be looking at section 20.1.2 - Transport for Keylock )
Cheers man πŸ™‚
