1
Posts
2
Users
Reactions
Views
06/01/2017 3:12 pm
happy new year all,
unfortunately mine didnt start too well. upon installing cross, i have tried to set it up with my hercules rmx.
now going into the setting, under the midi section, the controller is online and should be working.
but under the audio tab, when i select the hercules dj console rmx asio under the asio tab, my computer freezes for a few seconds and displays an error message saying error while opening "hercule dj console rmx asio" - invalid input parameter.
before clicking
after clicking
i have all the latest drivers for the controller, and under the dj console rmx, under the asio panel, i have asio selected and not wdm.
i have tried using both 32 and 64 bit versions of cross, still not joy!
thanks for reading, and any suggestions would be massively helpful!
thanks guys
06/01/2017 5:16 pm
Can you first confirm that all Rmx components are correctly installed (specially the ASIO device), as indicated in the following document ?
Secondly, are there any other audio/DJ applications runnning and potentially using the ASIO driver, that could interfere ?
Have you tried using Cross DJ while in WDM mode ?
Also, be sure to set the audio mode in the control panel before launching Cross DJ (and give it a few seconds).
