hercules rmx + macb...
hercules rmx + macbook pro + vdj problem
im a mac dj console + traktor old user
last week ive buyed the new
hi someone can help me?
iva a problem with my new macbook pro 15" and dj console.
ive installed all the original package but everytime i run vdj, my software send me a message "error in sound card".
i find a solution on the web to add an "aggregate" in midi setup (remember im an italian user with an italian mac).
the problem is solved until i reboot mac
every time i must add that in midi setup.
i try with new driver but no solution...
i try to use traktor pro...nice...but not perfect in midi configuration....
not for my use...
please im really regret how ive spend this money. ive buyed a product not really useful.
if you havent try this
http://www.virtualdj.com/wiki/errorsnddriver_rmx.html
sure...
but i have not aggregate device ("dispositivo aggiunto" in italian configuration) in standard configuration,
i must add, i must rename and every time i reboot, this device disapperars.
i reboot with no console attacched, with linked console...but no solution...
i try to reinstall with new driver with no solution.
every time i want use this console i must repeat all the procedure.
it is a problem if i choose to use this machine in disco...
If you haven't try this
http://www.virtualdj.com/wiki/ErrorSndDriver_RMX.html
Sure...
but I have not aggregate device ("dispositivo aggiunto" in italian configuration) in standard configuration,
I must add, I must rename and every time I reboot, this device disapperars.
I reboot with no console attacched, with linked console...but no solution...
I try to reinstall with new driver with no solution.
Every time I want use this console I must repeat all the procedure.
it Is a problem if I choose to use this machine in disco...
