hercules rmx midi c...
hercules rmx midi controlling capabilities
hey,
am looking at buying the rmx soon, and had a few doubts:
1. can i program it to use it as a midi controller for using it with software such as fruityloops for production/automation purposes?
2. how good is the in-built soundcard quality?
would appreciate any responses
1- yes, the dj console rmx will be recognized and used as a midi controller by all softwares. if they also have the possibility of handling midi out configuration, the leds can also be assigned.
2- wed like to think that the soundcard is pretty good. our drivers are tested with all major softwares and updated on a regular bases.
1- Yes, the DJ Console Rmx will be recognized and used as a MIDI controller by all softwares. If they also have the possibility of handling MIDI out configuration, the LEDs can also be assigned.
2- We'd like to think that the soundcard is pretty good. Our drivers are tested with all major softwares and updated on a regular bases.
