hercules rmx - trak...
hercules rmx - traktor pro 1.24(with controls for 4 decks, 4 fx banks, fader fx mode)
hi,
heres a mapping ive been working on (for a while now) for people who own a hercules rmx and are fans of this site.
features:
*a fader fx mode à la ean golden
*cue-point juggling in beat mash mode
*4 deck control
this mapping is based on the regular mapping from the hercules site so check there for basic info on what does what. ill be working on a version with comments that explain the logic behind the mapping.
how to get to the goodies:
1) there are a few main modifiers;
a. the scratch key cc41 this is a shift key type modifier
b. the scratch key cc41 + source 1 other then (you may want to disable both source buttons!)
c. the scratch key cc41 + source 2 this is a toggle type modifier that allows you go into a fader fx like mode (this disables most transport controls and volume faders other then the main volume and the x-fader)
i. (please note there that in this mode there is no jog wheel deck control only a fader fx mode!
ii. once mod 3 has been toggled on you can turn on the fx banks for deck a by hitting the scratch key cc41 + cc1, cc4, cc2, cc5 - fx bank 1, 2, 3, 4.
iii. once mod 3 has been toggled on you can turn on the fx banks for deck b by hitting the scratch key cc41 + cc25, cc28, cc26, cc29 - fx bank 1, 2, 3, 4.
iv. once mod 3 has been toggled on you can turn on the fx banks for deck c by hitting the scratch key cc41 + cc3, cc6, cc9, cc10 - fx bank 1, 2, 3, 4.
v. once mode 3 has been toggled on you can turn on the fx banks for deck d by hitting the scratch key cc41 + cc27, cc30, cc33, cc34 - fx bank 1, 2, 3, 4.
vi. once has been toggled on you can also control 2 complex effects decks (fx bank 3, & fx bank 4) with the eq knobs and the eq kills.
vii. for beat mashing (cue chords - again in mode 3) you have access to four (4) cue point keys on each deck where:
viii. keys cc1, cc2, cc3, cc9, on deck a points 1-4 respectively
ix. keys cc4, cc5, cc6, cc10, on deck b points 1-4 (i may move this)
x. keys cc4, cc5, cc6, cc10, on deck c points 1-4 (i may move this)
xi. keys cc28, cc29, cc30, cc34, on deck d points 1-4 (i may move this)
the scratch key cc41 + cc20 or cc24 will toggle on/off the cue listening for the deck above/below it (depending if modifier 2 is on or not)
please test it out and let me know if you like it. please also let me know about any bugs by replying here.
please see the attached file for more info (where the keys are). if there is any interest, ill keep updating the file. finally if someone can add somehow to make browsing easier like this:
@ 3.20 (hopefully via jog wheel) then id say this thing is pretty complete.
all files and reference materail are found here
http://www.djtechtools.com/forum/showthread.php?t=9004
thanks for making this mapping.  its given me a new love for my rmx.  tbh, i was about to sell it, but with this mapping, i might not now.
thank you man
hi i read your post, and i think its great you could give me the map that you put in your hercules rmx, and so to see how it is.
i would be greatly appreciated.
thank you man
hi i read your post, and I think it's great you could give me the map that you put in your hercules rmx, and so to see how it is.
I would be greatly appreciated.
