hercules rmx + trak...
hercules rmx + traktor pro 2 - jogwheel scrolling
hi guys!
my rmx has been working fine so far with traktor pro 2, but since i had to reinstall everything, i am facing a problem with the scratch button.
back then, i could scroll through the tracklist by pushing the scratch button and simultaneously turning one of the jogwheels, but now nothing changes when i push the scratch button. pushing it once will turn the blue light on, pushing it the second time turns it off again, but theres just no effect in the software. when everything was working properly, the button was only lit when i was pushing it down; after the release the light wasnt on.
im using
hercules rmx
traktor pro 2
windows 7 ultimate
with the latest .tsi file and driver.
any help is highly appreciated! thanks in advance
The most recent version if the TSI file has a few changes compared to the previou version. The Scratch button is now use to turn On/Off the scratch function of the jogwheel.
Fast scrolling through the browser is now preformed by holding the RIGHT button and using the jogwheel.
Please read the included PDF document, which explain the functions assigned in the mapping.
Oh, my bad! Thanks a ton for the hint! Smile
