hercules rmx with t...
hercules rmx with two denon s3700s
hi,
i really hope i can get some help. im running a macbook pro. i have two denon s3700s connected to my hercules rmx. im running timecode cds and im using virtual dj pro to do my mixing. my question is how do i make the bpm reflect on virtual dj pro whenever i change the pitch on one or both cdjs. i can hear that the pitch change when i move the pitch range on the cdjs but how can i see on the screen on the computer. ive been asking and waiting for someone to answer this question on virtual dj forum and it seems like no wants to help me.
it sounds like you have the option "disable pitch" checked in the debug window of the timecode config.
when this is checked it will stop the pitch graphic and bpm counter changing on the skin, but will still allow you to use the pitch control on your denons.
just uncheck this option and bpm counter should change and the pitch movement on the skin should mimic the pitch movement of your denons.
thanks for your help. i really appreciated. its weird because it was unchecked the disable pitch on timecode and it does show up but sometime it randomly changes the pitch by itself and increases by itself. so the pitch change seems to go crazy at times.
are you saying the bmp counter  ?
if thats the case then there is a option, again the the debug window of the time config called "pitch sensiblity" default setting is 500ms i believe.
try moving the slider to the right a little (to around 700-800ms) and see if that stops the bpm counter fluctuating.
