equipment list:
2 x powered pa xlr to 1/4" mic adapter
1 x powered sub xlr to 1/4" mic adapter
hercules rmx
laptop xp with hercules software/driver updated.
virtual dj 7 pro
mic connected to rmx
headphone connected to rmx
issue:
i am using the advance setting which appears to be the best place in configuring if i just know what im doing. i cannot get my headphones to work as the cue. i keep getting the master sound on the headphones.
setup:
pa1 > output 1
pa2 > output 2
sub > output 3
im a little confused with how to properly setup virtual dj settings.
i currently have it configured as follows:
advanced settings
master hercules rmx output 1&2
master hercules rmx output 1&2 - noticed i have 2, but it seems to sound better..not sure why.
master hercules rmx output 5&6 - im not sure why this works since my sub is in output 3 but somehow the sub works on this setting.
headphone hercules rmx output 1&2 - i get the same sound that is played on my speakers as the master.
mic hercules rmx input 1&2
also there is a check box for mono channel - which i dont have it checked but i noticed soon as its checked i get more options.
so i need help on how to properly use the output settings for my speakers and heaphone. thanks guys in advance.d
dj sammy
