how to connect usb ...
how to connect usb microphone?
hello,
how could i connect my usb microphone to vdj pro 7.0 ?
its for broadcasting live with my controller.
at mappers i have advanced :  - master: output 1&2
                                                  - headphones: output 3&4
                                                 - microphone: input 1&2
also, my mic is on ( yellow lamp in the right corner mic so hes on )
but i dont hear anything because my mic is usb..
can someone help me with the right settings?
thanks
1) What is your DJ controller?
2) As VirtualDJ Pro can set only 1 audio device, I would suggest to agglomerate your current audio interface + you USB microphone in ASIO4ALL and to select ASIO4All as audio device.
