how to set micropho...
how to set microphone in hercules dj consule mk2
how to set microphone in hercules dj consule mk2. my microphone doesnt work...
hello,
once you have plugged your microphone in dj console mk2 microphone input, you activate it in pushing on the volume knob of the microphone (then the talk-over function is on, and the mention "on air" appears in red on dj console mk2 control panel), and you switch the microphone off in pushing again on the volume knob of the microphone (the mention on air on the control panel turns to black).
Once you have plugged your microphone in DJ Console Mk2 microphone input, you activate it in pushing on the volume knob of the microphone (then the talk-over function is On, and the mention "On Air" appears in red on DJ Console Mk2 control panel), and you switch the microphone off in pushing again on the volume knob of the microphone (the mention On Air on the control panel turns to black).
