i lost installation...
i lost installation cd hercules air +
hello at all..i lost the installation cd hercules air + .. now how do i install the console on a pc ?
The latest drivers are always available from the Technical Support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=321&cid=1
As well, you'll find the latest version of DJUCED here:
Hello at all..I lost the installation CD Hercules rmx now how do I install the console on a mac ?
To install DJ Console Rmx on a Mac, you need the drivers which you can download here.
To use VirtualDJ 5 DJC, you need the VirtualDJ serial number which was printed on the CD enveloppe.
If you have this serial number, or if you registered this serial number on VirtualDJ website, you can connect on VirtualDJ website, and log in with your account, and download VirtualDJ 5 DJC on VirtualDJ licenses pages.
