i need help!
my laptops not reading the dj controller what can i do to make it work with the program?
You could start by proiding some details about yout configuration so we can know how to guide you
- Your computer specifications (brand/ model, processor type, amount of memory, operating system,etc);
- the Hercules DJ controler you are trying to use;
- the troubleshooting steps you've done so far to try solving the problem.
