inpulse 200 spare p...
inpulse 200 spare parts
looking for spare volume control sliding potentiometer on dj hercules inpulse 200. the pot is marked sk458n but im unsure where to get this part? help would be greatly appreciated.
Welcome on the forum.
1) Please confirm the part you look for is the slide potentiometer itself, not the cap.
2) If it is the slide potentiometer, you can order the spare part from Hercules support on https://support.hercules.com/en/contact-en/  but considering the shipping cost from Europe to Australia, it may be cheaper to order locally a pin to pin compatible slide potentiometer as Taiwan Alpha RA4543F-20-15D1-B10K-01, which is slightly better and probably cheaper if you buy it from Mouser here.
3) As Hercules DJ controllers have a warranty, you can check with Hercules support if your controller is stiill under warranty to get a repair for free.
