ion-ied04-digital-d...
ion-ied04-digital-drum with hercules rmx
hello, i have recently bought hercules dj rmx console and i want to buy a digital drum. i am not sure if i can connect the drum with the hercules dj rmx. does anyone know how to do it ? cheers
hello,
you have 2 ways to mix on dj console rmx and use your digital drum:
- mix inside the rmx: you connect your digital drum on your dj console rmx input 1-2 or 3-4, and you replace one of the 2 audio tracks by your digital drum in pushing on the source button (source 1 for input 1-2, source 2 for input 3-4),
- mix outside the rmx: you connect your digital drum output + your dj console rmx output 1-2 to a mixer (a dj mixer, or a mini mixer) and you mix your dj console rmx sound with your drum system out of the rmx ( dj mixers start around £50 http://www.westenddj.co.uk/categories/mixers/ , and analog mixer can be cheaper, as behringer xenyx 502 http://www.guitarampkeyboard.com/similar.php?filter=type&id=70279).
You have 2 ways to mix on DJ Console Rmx and use your digital drum:
- mix inside the Rmx: you connect your digital drum on your DJ Console Rmx input 1-2 or 3-4, and you replace one of the 2 audio tracks by your digital drum in pushing on the Source button (Source 1 for input 1-2, Source 2 for input 3-4),
- mix outside the Rmx: you connect your digital drum output + your DJ Console Rmx output 1-2 to a mixer (a DJ mixer, or a mini mixer) and you mix your DJ Console Rmx sound with your drum system out of the Rmx ( DJ mixers start around £50 http://www.westenddj.co.uk/Categories/Mixers/ , and analog mixer can be cheaper, as Behringer Xenyx 502 http://www.guitarampkeyboard.com/similar.php?filter=type&id=70279).
