1
Posts
2
Users
Reactions
Views
12/04/2017 11:33 pm
hello people,
ii am curious if it is possible to play with the settings so that you can scratch without pressing the jo wheel on the controller and if you are a instict user you know how bad it sucks scraching you just cant do it.
help me please!!!!
13/04/2017 6:07 pm
By default the Jogwheels have two functions:
- Pitch bend, using the side of the jogwheel (without pressing on them);
- Scratching, while pressing and turning the wheel;
You can disable the scratch function (button Vinyl off), which will only leave the Pitch bend function, wether you press the jogwheel or not.
However, this does not seem to be what you want to do. Could you explain more precisely what you are trying to achieve exactly ?
