jogvision fader pro...
jogvision fader problem
my fader is jittering. is moving by itself and will not stay full left or right.
i slowy move it from one deck to the other but it starts jumping around
and will not stay put. im now having to use the keyboard shortcut.
tried updating the firm ware but received an error. have been using it
for months with no problems with vdj pro until now              .
any thoughts
Hello Lonzo,
It does not sound a firmware issue.
1) Did you try remapping the crossfader in VirtualDJ?
If you did, then please delete the mapper file, since it may be an unproper mapping (Jogvision crossfader sends a 14-bit MIDI message, with 2 MIDI messages, MSB and LSB, so if you map the LSB instead of the MSB, it explains the problem you meet),
2) Did you store the controller in a dusty area? If you did, then some dust on the crossfader taper may explain your problem, you can try cleaning the crossfader with an air duster in this type.
3) Did you bend the crossfader with a weight: then the crossfader taper may be damaged which would require changing the crossfader.
