left low eq borken ...
left low eq borken on hercules rmx
my hercules rmx need to fix left low eq. where i can buy poten potentiometer?
thanks!
1) Please confirm your Rmx is a DJ Console Rmx and not a DJConsole Rmx2.
2) The 6 EQ rotary potentiometer in DJ Console Rmx are Alps RK09L1140A5R (mono rotary potentiometer, vertical mount, 100k, 15mm length shaft with 9mm flatness on shaft, no detent, resisitance taper B, rotational angle 300°). I do not think you can find it today as it is an obsolete component, but you can replace it with an Alps RK09D1130 which is more easy to find.
https://www.mouser.co.uk/ProductDetail/ALPS/RK09D1130-F25-C0-A104?qs=LBL%2Fib7enC93fO3KEVGyiA==
In case you cannot find it in your country, you may contact Hercules support team on support.hercules.com and order the component Alp RK09D1130C8N (reference in Hercules support: code 6000883).
i'm using RMX 1. Thanks
