m-audio fast track ...
m-audio fast track pro et hercules control steel
howdy folks !
i am from barcelona - i know nothing ..
just dont understand how to pre-listen / headphone monitor with a
set-up of hercules control steel plus m-audio fast track pro
the control steel only has usb connection to my laptop and vdj software.
headphone i connect to fast track pro external soundcard but how-o-how
i prelisten next track by headphones while main track is playing live ??
many thanks for helping out this burrito πŸ˜‰
this page will help with the m-audio hardware configuration:
http://www.m-audio.com/?do=support.faq&id=6da103b09920a63e1cf11048d1361234&lang=en
following configuration #1, you will need to go to vdj audio menu and use the following settings:
- input : none
- output(s): headphone  > master chan1/2 / headphone chan3/4
-soundcard: m-audio fast track asio
thanks alot phatso !
i will definitely check this out tonight !
best regards
