microphone and dj c...
microphone and dj control instinct
hi,
i have dj control instinct and i have a question: if i want to connect a microphone, how can i do it??? i must buy a mixer?
thanks
Indeed, the DJ Instinct does not include a microphon input.
For what purpose do you want to use the microphone ? Would it be to adress the audience or for recording ?
Thanks for reply. I need for audience.
Then yes, you could use a small mixer with a microphone input, such as this one:
http://www.behringer.com/EN/Products/502.aspx
Or use the microphone input of the PA system (if one is present obviously).
Thanks a lot!
how do u connect one for recording?
As stated previously, the DJControl Instinct does not include a microphone input, so you would need another audio interface, like your computer's soundcard.
