1
Posts
2
Users
Reactions
7
Views
19/07/2023 5:13 am
hello, i was wondering if you could help me remap my inpulse 200. i found an old thread where a file with similar remap was shared but the link has expired.
i want to achieve the following:
- i want to use the high knobs and have it also affect the mids in the software as well, so that i could adjust them both using just high
thank you !
21/07/2023 6:24 pm
Hello Izzy477
Please download from https://we.tl/t-fjp24O5vOZ
an alternate mapping for DJControl Inpulse 200 in Djuced with High knobs controlling High+MID.
To load this mapping:
1) copy the .djm file in the folder C:\Program Files\DJUCED\midi in case you are in Windows
(that is what completing your profile completely is needed: filling "Describe your equipment" field with the computer configuration as Windows or macOS versions, driver version, computer brand and model)
2) connect your DJ controller to the computer
3) start DJUCED
4) in DJUCED, go in Settings > Mapping, select the new mapping "MID+HIGH Hercules Inpulse 200"
5) Click on OK,
To make sure the new controller mapping is loaded, close DJUCED and restart DJUCED: the new mapping should work for your DJControl Inpulse 200.
