mk2 firmware contro...
mk2 firmware controller issue
hello,
i have an issue with my mk2. ive tried to install my mk2 on 3 different laptops with the same results. i cant seem to update the firmware-controller and i keep getting error updating controller part: 0x0000010b (fail during update process of psoc).
ive searched this forum for answers and i think ive tried everything there is on this issue. ive repeated step 6, of the manual, many times with the talk over button  and the 1 2 3 button on the a deck but i keep getting this issue. does this mean my mk2 is defect or is it still possible to fix this issue.
i tried to install it on a dell e6420 with xp sp3, windows 7 x86 and windows 7 x64.
i tried to install it on a lenovo t520 with windows 8.1
i tried to install it on a acer (type unknown)
can somebody help me with this issue?
greetings,
miksel
Was the MK2 working previously ?
If so, do you still have access to the older system you were using it on ?
Unfortunately I haven't got the system anymore but the MK2 was working perfectly. Since I bought a new laptop with windows 7 x64 I haven't been able to get it working again πŸ™
So your new laptop is the Dell which also have Windows XP ?
Did you try the console under this OS also ? With the same results ?
Would you happen to have t powered USB hub you could put between the console and the computer ?
Its quite possible your console's firmware might be damaged, but let's not jump to that conclusion yet.
Sorry for the late responds!
yes the Dell laptop is the new laptop and I have installed Windows XP on it, then installed the MK2 with the same results. Then I installed Windows 7 x86 with the same results and also with Windows 7 x64.
I haven't got a powered USB hub unfortunately so I can't test this :(.
Have you tried the new driver package (2014.HDJS.1) released last week to see if it makes a difference?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=177&cid=1
