mk2 right autobeat ...
mk2 right autobeat button not flashing
good evening.
having sme problems whit my mk2. the right autobeat button is not flashing when a song is played. the left one works and if i disconnect and connect it all lights are working. i have the latest drivers and reinstalled them but no luck. any one got a clue what to do?
hello jensen_sbp,
which software do you use?
if it is virtualdj, which version of virtualdj?
it is virtual dj 5.2
but is this just a led problem or does the button not work either?
please check the following link: http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=6
πŸ˜‰ hope i helped
jensen_sbp,
1) are you in mac os or windows (vista, xp, 32-bit, 64-bit ...)?
2) how does the autobeat button flash in the dj console edition of virtualdj instead of the pro version (virtualdj djc 3.4 if you are in windows)?
hello again.
1) xp 32-bit
2) will hook it up to my laptop when i come home tonight. i have the djc 3.4 installed on that.
i have discovered the problem and it was the midi mapper that didn´t work out whit vdj5.2 i had an old midi mapper.
Hello Jensen_sbp,
Which software do you use?
If it is VirtualDJ, which version of VirtualDJ?
It is virtual DJ 5.2
πŸ˜‰ hope i helped
Jensen_sbp,
1) Are you in Mac OS or Windows (Vista, XP, 32-bit, 64-bit ...)?
2) How does the autobeat button flash in the DJ Console Edition of VirtualDJ instead of the pro version (VirtualDJ DJC 3.4 if you are in Windows)?
Hello again.
1) XP 32-bit
2) Will hook it up to my laptop when i come home tonight. I have the DJC 3.4 installed on that.
I have discovered the problem and it was the Midi mapper that didn´t work out whit VDJ5.2 i had an old midi mapper.
